Immobilizer no start issue. | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by 98GTS6spd, May 1, 2022.
  1. tbakowsky
    Sep 18, 2002
    20,042
    The Cold North
    Tom
    #26 tbakowsky, May 2, 2022
    You may have mixed up the 2 engine harness connectors behined the passenger seat. You have the main ECU harness..Can't mix up that one..but be sure the 2 other connectors are connected to the matching connectors colors. White to white, and that other odd color to its match.
    Edit... I may be getting confused with the 348. One of these cars the harness connectors can go either way. But it's something to check..
  2. Qavion
    Qavion F1 World Champ
    14,534
    Ian Riddell
    Yes, but did you check the pump was priming immediately after? This checks the relay, the wire, the pins at both ends and some of the ECU internals. I didn't mean resetting the battery to see if your car started.
    Did you confirm the blue plug was on the cam sensor (or didn't you disturb it)?
    Did you disturb the TPS connector?
    Prior to the engine out, did your car normally crank, but not start if you forgot to disarm the immobiliser? My car doesn't crank. Later model cars seem to crank anyway. I'm just trying to determine if the starter on your car is controlled by the immobiliser. If it is, then it's less likely to be an immobiliser/Motronic ECU issue.
  3. Qavion
    14,534
    Ian Riddell
    Do you have an OBD2 scanner? These don't communicate with the Motronic ECU if your immobiliser is not disarming.
  4. 98GTS6spd
    98GTS6spd Rookie
    May 1, 2022
    32
    Middle Ga USA
    George Magruder
    No. The pump would not prime after the reset. Also unhooked the alarm to make sure it wasn’t the cause. I checked the cam sensor the knock sensor. And the crank sensor. All good and plugged in correctly. I do not know if the car would crank before because it had a bad remote But the alarm was obviously not armed because when I would turn the key the alarm never went off When I got the immobilizer,ecu and new fobs back from the programmer who also performed the pin extraction I installed them and bam. Hit the fob. Turn the key and everything fired right up. And no I did not disturb the TPS
    Qavion likes this.
  5. fatbillybob
    Aug 10, 2002
    29,274
    socal
    If you are still thinking an immobilo prob did you try starting with the extracted pin? The pin bypasses the fob, fob battery connections, antenna to transmit issues etc. The pin makes starting the car like starting any other but with just a key sequence. if the pin does not start car I'd look somewhere else especially if no start is after engine re-install. You missed something bent 88pin connector pins etc etc.
    98GTS6spd likes this.
  6. 98GTS6spd
    98GTS6spd Rookie
    May 1, 2022
    32
    Middle Ga USA
    George Magruder
    I really appreciate everyone’s input and expertise in this matter. I have found the issue and everything is fine now. It was a bent connector pin on the white connector plug next to the ecu Bent it back. Plugged it back in an bam. Turn key started right up ! Happy to say the least. Thanks guys. I have learned a lot from this forum !!
    Qavion likes this.
  7. fatbillybob
    Aug 10, 2002
    29,274
    socal
    Great happy ending! These cars are unreliable unless a lot of attention to detail is exercised. What Mitchel posted about mistakes like the while you are in there failing to replace o ring seals, cam timing etc is very true. Those details are the difference between a running car for now and a fantastic running car to its full potential with reliability. For now just enjoy it.
  8. 360Tom
    360Tom Formula 3
    May 9, 2013
    1,396
    Burbank, CA
    Tom
    I remember being at a car show and dropped my key, needless to say, the remote stopped working and was stranded. They should have designed some way to get around it.
  9. Qavion
    14,534
    Ian Riddell
    I'd be curious to know which pin was bent. The pins on the plug with the larger pins have been known to cause issues (e.g. the coil power pins). That's the transparent plug, though, not the white plug. Tom ( @tbakowsky ) mentioned the plugs, but I forgot to follow up with details.
  10. wrxmike
    wrxmike Moderator
    Moderator Owner
    Mar 20, 2004
    7,675
    Thats what the pin code is for.
  11. 360Tom
    360Tom Formula 3
    May 9, 2013
    1,396
    Burbank, CA
    Tom
    I have no idea what the pin code is. After all these years
  12. wrxmike
    wrxmike Moderator
    Moderator Owner
    Mar 20, 2004
    7,675
    A 4 digit numeric code on a piece of paper that was supplied with the car when new ( as well as 3 remotes ). Most likely a former owner "put it in safe place" and forgot about it.
  13. 360Tom
    360Tom Formula 3
    May 9, 2013
    1,396
    Burbank, CA
    Tom
    Ah. I do have the other red remote. That day, I was quite a distance from home. Luckily my mechanic, saw me sitting there when passing by, took my back to his shop to open the fob up and replaced the battery. It was fine after that
  14. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,673
    San Carlos, CA
    Mitchell Le
    Bent pin, that happened to me once. Same white connector. $100 bet it's the pin that runs to the fuel pump relay.
    Qavion likes this.
  15. Qavion
    14,534
    Ian Riddell
