News
Immobilizer problem
Discussion in 'Technical Q&A' started by joakim_adolfson, Apr 4, 2010.
  1. joakim_adolfson
    joakim_adolfson Karting
    Sep 19, 2009
    156
    Stockholm, Sweden
    Hej,
    I tried to start my 456 today but it cut out directly as the battery was a very low on juice, however the immobilizer work as it should, the engine tried to crank.
    I have now charged the battery a little but can't shut off the immobilizer, the light is still flashing, I have tried both immobilizer keys but they both work the same.
    Have anyone got a clue on how to possibly reset the immobilizer on the 456, it's using a VDO system with a plastic little black key that is inserted into a hole in the dash.
    The immobilizer is called VDO immobilizer 2000T.
    Glad for quick help!
  3. mikeprice
    mikeprice Rookie
    Jun 19, 2010
    24
    Hi, I same problem on my 456. It was the relay on the imobiliser, when it was fitted by the Ferrari dealer from new they should have fitted a larger relay. Took the imobiliser out of the supply to starter and never had a problem since. The imobiliser still controls the fuel pumps but not the starting circuit. Hope this helps
