Impossible lock removal | FerrariChat
Discussion in '308/328' started by Spitfire, Jun 28, 2007.
  1. Spitfire
    Spitfire Formula 3
    Nov 16, 2006
    1,602
    Gents (and any ladies), I'd need to remove my driver's side lock, but cannot figure out how to do it!
    Looking from the inside of the door, you can see an adjustable rod that's vertical, and which connects to the lock barrel/mechanism via some kind of white nylon clip thing.
    Question is, how is the nylon clip thing attached to the lock? Is it a push fit? I don't want to pry it too hard for gear of breaking the nylon.
    Thanks guys. This has been confounding me for ages.
  2. 350HPMondial
    350HPMondial F1 Veteran
    5,336
    Edwardo
    Just pull the rod out of the Nylon thingie.. (Pull hard)
    Make sure you rotate the clip out of the way. (if there is a clip.)
  3. Spitfire
    Spitfire Formula 3
    Nov 16, 2006
    1,602
    That doesn't seem to be how this particular rod works. It's threaded at both ends, and the threaded part is screwed through the nylon clips (one at each end). The nylon clip is then attached directly to the inside of the lock barrel.
    It's very hard to describe the configuration, but anybody who has done this before will know exactly what I'm talking about.
    Thanks.
  4. 350HPMondial
    5,336
    Edwardo
    Oh, you have a 1977.
  5. 350HPMondial
    5,336
    Edwardo
    #5 350HPMondial, Jun 28, 2007
  6. Spitfire
    Spitfire Formula 3
    Nov 16, 2006
    1,602
    Yep, a 1977 308.
    I haven't removed the inner handle, but I'll do so. But then what? I've scratched my head wondering how big a job this might be.
    All I want to do is disconnect the rod (part # 7) from the lock. Very few of these jobs are easy on a 308 are they?!
  7. 350HPMondial
    5,336
    Edwardo
  8. gerritv
    gerritv Formula 3
    Jun 18, 2001
    1,400
    St Catharines
    Gerrit
    Just use a flat blade screw driver as a lever between the nylon block and the lock. Carefully pry and it will 'pop' off. There are several other places where this same configuration exists on your door. If you are cautious type, try the approach on a different area first. Mmnn, Ok there are several places on the 308GT4, perhaps only that one place on a GTS/GTB. Basically there is a ball that press fits into a hole in the nylon block.
    Gerrit
    http://dino308gt4.com
  9. Spitfire
    Spitfire Formula 3
    Nov 16, 2006
    1,602
    Thanks gettitv. I wondered if that was the correct procedure, but didn't want to try forcing anything until I knew for sure. I'll proceed with caution ... makes me nervous!
