Improved 308 starter motor | FerrariChat
Discussion in '308/328' started by luckydynes, Jun 2, 2007.
  1. luckydynes
    luckydynes F1 Rookie
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    Hey all,
    Well another thing I want to get around to is a new improved starter motor. Mine occasionally sticks . . . usually when there's a crowd around. I've had it apart several times and really can't see anything obvious that would make it stick the way it does unless maybe the new bushings I made for the bendix gear are a little tight and that's overcoming the solenoid or the new solenoid is just not as robust as the original (doubtful) . . . bottom line is I want that starter throwing and engaging every time.
    Someone else must have thought about this. A Tilton's probably the way to go but which gear, etc.
    Thanks for the input,
    Sean
