Improved acceleration with Fabspeed headers & exhaust? | FerrariChat
Discussion in '458 Italia/488/F8' started by shawsan, Oct 18, 2012.
  1. shawsan
    shawsan Formula 3
    Jul 2, 2004
    1,090
    Vancouver, Canada
    Fabspeed has done a good job providing information and dynos on its header and exhaust mods for the 458. Impressive gains of 60HP and 45 ft/lbs of torque at the crank are documented. But as someone who has modded many cars and is familiar with posted dyno gains, impressive HP/TQ announcements often don't translate into signifcant peformance gains, such as 0-60 or 1/4 mile acceleration. Problem is that NO aftermarket companies post results on changes in acceleration performance. They leave it to customers who, also, have little clue about real performance gains. My hunch is that real performance gains are very minimal, a shadow of the implied HP/TQ gains. And I believe this to be even more true in the case of modded turbos vs. naturally aspirated cars. Unless proven wrong, I'd say the $14K one coughs up for Fabspeeds mods results in HP/TQ bragging rights rather than significant peformance gains. But I'd also be happy to be proven wrong. Over to you Fabspeed.
  2. 2k7997tt
    2k7997tt Formula Junior
    Oct 23, 2007
    768
    Westlake Village, CA
    John M.
    I believe Ferrari leaves very little performance on the table for aftermarket performance companies to claim.
  3. Joe Mac
    Joe Mac Formula 3
    +1
  4. pride355
    pride355 Formula Junior
    Apr 16, 2006
    388
    Istanbul/Turkey
    MOT
    The thing with the aftermarket exhaust systems are they don't have to comply with the strict restrictions. I used to have Akrapovic Evo system on my E92 M3 and it really gives additional 22-25 hp and 30 NM of torque BECAUSE the system doesn't have primary cats. So instead of 400cell primary cats + 200cell secondary cats of the OEM system, Akrapovic EVO has no primary cats (straight pipes) + 100cell race cats. As a result, here comes the extra power.
    On the other hand, unless Fabspeed eliminates cats, there can't be much power to have. Also don't forget that tuning companies advertise the gains but these gains are not at the peak power most of the time. So when they say you gain 20 hp, it is not additional 20 hp over peak power, but it is 20 additional hp somewhere in midrange.
    60hp power gain over 458 engine means 630hp which means 140hp/1000 cc. It is highly unlikely.
    Do it if you want to lose weight and to make a change in sound. But it is almost imposible to get extra power from an already high power (127 hp/1000 cc) NA engine just with a new exhaust.
  5. Webber45
    Webber45 Karting
    Oct 2, 2011
    217
    Bavaria / Germany
    Partially I am with you. But I think that you can generate some extra power with the complete exhaust system at the 458 too. Of course not 30 hp or more, but 5 till 10 hp can be possible because of kats, air stream, backpressure, lower temperature at the airbox because of good thermo-insulation of the exhaust-system, etc. But what I am sure is, that because of this changes, the torque can rise up by 30 till 40 Nm. And this can be also interesting, isn't it?
    Ciao - Webber45
  6. Fabspeed Motorsport
    Sponsor
    Feb 5, 2009
    3,119
    Fort Washington, PA
    John S
    Thank you for your interest in our products. Although we have proved that we can make a significant increase in power, it is difficult to convert that data into an accurate performance gain. Adding 60 hp and reducing weight by 25 lbs will certainly decrease the 0-60 times and 1/4 miles times by a tenth or two, but an extreme change in performance is unlikely. To test this, we would need a drag strip and we would need to replicate the exact conditions of the before and after runs.
    However, for most customers, the seat of the pants increase is usually enough to validate the power increase. We already offer more data than most aftermarket companies, and we would love to supply performance figures, but it is too difficult. Plus, most of these cars are not owned by the company, so we would need to get the OK from the owner of the car before we take it to the track.... which is not always going to happen.
    Please let me know if you have any other questions. Thanks!
    Jeff
  7. Fabspeed Motorsport
    Sponsor
    Feb 5, 2009
    3,119
    Fort Washington, PA
    John S
    We have sold many sets of our 200 cell sportcats (factory is 750 cells per sq. in.), and we have recently introduced a cat bypass system. We have not had a chance to dyno test the cat bypass yet, but I would guess it will make slightly less power in the lower RPM ranges and more near the peak engine revs. Our headers and sport cats have been proven to make significant increases in power. The mufflers do not make much difference in power, but they save a lot of weight which is important to some customers.
    Please keep in mind that our gains are aided by an ECU upgrade which is good for about 25hp on its own. Please let me know if you have any other questions. Thanks.
    Jeff
  8. pride355
    Apr 16, 2006
    388
    Istanbul/Turkey
    MOT
    5 till 10 hp is possible. This is why I said "almost" impossible ;)
    And again, for the big gains, you have to eliminate cats which is illegal in most states/cities.
  9. Hkpooh
    Hkpooh Formula Junior
    Nov 11, 2011
    514
    60hp on NA car with just full exhaust ? on a Ferrari??
    That's highly impossible.
  10. cam man
    cam man Karting
    Nov 6, 2004
    67
    I develop camshafts for racing motorcycles hence "cam man". I can assure you that the engineers at Ferrari didn’t drop 60 HP on the dyno room floor and forgot to pick it up. We develop cams for Hayabusas, CRF250 Hondas etc... Any highly developed engine such as a 458 will have nearly every bit of power "squeaked" out of it. Finding 10% more power is impossible!!!
  11. HK boy
    HK boy Formula Junior
    Sep 20, 2012
    955
    Del Mar, California
    Jeff
    An aftermarket exhaust on a NA Ferrari is mostly for aural pleasure only. For pure speed and acceleration, that's what modified 911 Turbo and Nissan GTR are for.
  12. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,643
    I have a friend that does heads for 1 liter bike motors that go into small race cars. I generally takes a production 1 litre bike motor making 150 HP (Yam, Honda, Kaws, Suzzies), does the valves (no headwork allowed), retunes the ECU for race mixtures and timing, balances the crankshaft, carillo rods, changes the velocity stacks and ships them out the door at 212-215 HP (on race gas). The tuning takes place on a dyno with an eddy load device so he can measure stuff at full throttle (or any throttle position) and tweek the motor at that RPM untl it runs correctly. So finding 10% power is not so impossible--he is getting 30%.
    Now, he did learn his trade by building Infinity IRL engines for a decade.
    Finding 10% and remains street legal is probably outside of doable.
    Finding 10% and remaing street legal for the 120K mile emission warentee is unlikely.
  13. cam man
    cam man Karting
    Nov 6, 2004
    67
    I should have emphasized that by changing only 1 item (ie, cams, exhaust) it is not possible! If you changed the cams, porting, compression, ECU etc then of course you can but here we are only talking about a pipe/ecu change. Ferrari is simply not going to leave that kind of power on the table.
  14. MM3.9GT3
    MM3.9GT3 Karting
    You are thinking too rationally because you are an engineer. Just think like a Marketing guy, and you can make up stuff!
    Here is what Porsche did with their factory Powerkit to increase the power of the 997 by 26 hp. This was on a 3.8 L producing 381 hp, a motor producing far less hp per liter than the 458.
    Revised cylinder heads
    Carbon-fiber air cleaner housing
    Aluminum air intake
    Modified exhaust manifolds
    Revised ECU
  15. Hkpooh
    Nov 11, 2011
    514
    hahahah so true.
    I especially like the "intake system".
    When someone try to sell me a "intake system I always response with "oh you mean a tube and a cone filer? "
  16. shawsan
    shawsan Formula 3
    Jul 2, 2004
    1,090
    Vancouver, Canada
    Appreciate yr. reply and acknowledge difficulties of obtaining reliable acceleration tests. And yes, when I referred to yr. claimed HP/TQ gains, I realize we're talking about changed headers + exhaust + an ECU return.
    But, without knowing acceleration gains, potential buyers remain in a knowledge vacuum. Seat of the pants reports really don't count for much because those who make the 'investment' to improve performance desperately want to believe performance has increased. Often it hasn't. And then, again, there's all the debate surrounding the assumed 'drive train loss' you and other aftermarket producers use to impute HP/TQ gains.
    Fact is, no one really knows the true drive train loss on a 458, so translating rear wheel HP into HP gains at the crank often involves crystal ball calcuations that then feed hype and expecations of buyers. And so, acknowledging difficulties of performing acceleration tests on a 'fabspeed 458', I submit there's no real credible gains to investing in Fabspeed mods. After all, the costs installed are going to approach $20K with taxes.
    So pls. do us a favor and conduct some. Otherwise, bottom line its like buying hair loss remedies based on 15 testimonies they work when, in fact, there's no objective evidence that anything works to regenerate hair loss. Over to you with all due respect.
  17. Webber45
    Webber45 Karting
    Oct 2, 2011
    217
    Bavaria / Germany
    #17 Webber45, Oct 24, 2012
    Hi to all,
    yesterday I picked up my F 458 Italia from Capristo / Germany with some modifications.
    We changed the airbox to Capristo's CF-airbox with bigger volume and the complete exhaus-system to Capristo exhaust-system, inluding the Kats, manifold, tubes and baffles, all together with the special Capristo thermo-insulation.
    The power (hp) has not increased significant, but have a look at this phantastic torque!
    When I drove home, the sound was great and I was able to feel immediately the much higher torque, especially at lower RPM.
    Nothing is done with electronic or something else; just the exhaust-system and the airbox!
    Regards - Webber45
  18. Hkpooh
    Nov 11, 2011
    514
    wooo post some pics and clips plesae, love to see and hear that beast!!
  19. radix
    radix Karting
    Dec 2, 2010
    234
    Do you have a screenshot of the "before" torque and HP so we can - "have a look" THX.
    what was the peak torque before the change ? did the RPM of the peak change ?
  20. Scuderia980
    Scuderia980 F1 Rookie
    Aug 12, 2006
    3,636
    Mountains--Colorado
    Dave S. V
    you are assuming that they are trying to 'find' the extra power. of course they dropped the hp on the dyno room floor, they left it there on purpose. the truth is that the full on output (lets just say 630hp), maximum output given reliability & emissions, target etc, is known long before the first car with 570hp, is put into the showrooms.
    most car companies use the same trick...the lowest output is given to consumers first, then miraculously 5 years later, a 'Scuderia' version, spec R, etc, etc, etc, comes out and they 'find' an additional 30hp, 50hp, or whatever amount. reality is that it was always there the whole time, only the ECU and related items held them hostage before the lifecycle of the product evolved far enough along so that customer demand would meet up with inevitable increased cost of the 'updated' car
  21. Webber45
    Webber45 Karting
    Oct 2, 2011
    217
    Bavaria / Germany
    No, Sorry. We did not measure it before. We just can compare with the original diagram. It should be 540 Nm at 6500 RPM, as far as I remember.
    But I know the car now since appr. 6500 miles. I can clearly feel the higher torque, especially between 3000 and 6000 RPM.
    I will try to make video during the weekend.
    Ciao - Webber45
  22. radix
    radix Karting
    Dec 2, 2010
    234
    Why then measure it after ? ;) Thanks.
  23. shawsan
    shawsan Formula 3
    Jul 2, 2004
    1,090
    Vancouver, Canada
    Exactly. And when they did measure it, what drive train loss was imputed into the dyno to pump out increased HP and TQ. Was it the same drive train loss as from the factory (though factory measures HP/TQ at the crank) or some other number the dyno mistro came up with.
  24. Webber45
    Webber45 Karting
    Oct 2, 2011
    217
    Bavaria / Germany
    #24 Webber45, Oct 26, 2012
    It was my wish to know the exact data of my baby. I know that it doesn't show the increase because of the modifications without a "before-measuring". But it's nice to know now, that my baby brings more than 600 Nm on the road. Equal if it is from the modifications or from my very efficient manner of driving ;-) I wanted to tell my pleasure to people with same or similar intensions, hopening that they will share my pleasure. This is why I posted the diagram :)
    It's measured on a Dynamometer, where all 4 wheels are turning. The front-rolls of the dynamometer are connected with the back-rolls. So it simulates as good as possible a drive on the road. The datas are measured from the power-input into the rolls of dyno. It was with the 6th gear. On the diagram you can see that the setted efficiency was 92%. I think that means, that the drive train loss was inputed with 8%, isn't it.
    Regards - Webber45
  25. HighandDry
    HighandDry Formula Junior
    Jul 24, 2012
    447
    Seattle
    Steve
    I agree. Look at the Aston's Vantage. Their 20 HP powerkit is due to only improved air intake and tune. Porsche's Carrera 30 HP powerkit is due to improved air intake, exhaust, and tune.
    Intake, headers, cats, and tune will definitely increase HP. How much is variable, but I don't know why there are so many doubters.
