In Dash Voltmeter | Page 3 | FerrariChat
In Dash Voltmeter
Discussion in '308/328' started by Kidasters, Jan 24, 2015.
  1. scowman
    scowman F1 Rookie
    Mar 25, 2014
    2,555
    Scottsdale AZ
    Stu Boogie
    So will this be a regular item we can all get?
  2. Kidasters
    Kidasters Formula Junior
    Oct 4, 2013
    546
    Houston, Tx
    Ken
    I don't think it's something that PAS plans to mass produce. I don't plan to mass produce it.
    You could contact Hartmut if you are interested.
  3. chris_columbia
    chris_columbia Formula Junior
    887
    Columbia MD
    Chris
    Looks exactly like it should! Perfect
  4. chris_columbia
    887
    Columbia MD
    Chris
    Well,except for the numbers being in the wrong location. Once that's fixed, which I assume will take them all of 5 seconds, it will be great
  5. hyenahf
    hyenahf F1 Rookie
    May 25, 2004
    2,603
    i have a whole set of those veglia laying around storage somewhere. amp volt tach clock oil speedo etc, about a dozen gauges or so....
  6. hanknum
    hanknum Formula 3
    Nov 1, 2003
    2,050
    Santa Barbara
    Henry
    Thanks Chris...my clock was useless as it was. IIRC, it was fast by a couple minutes a day, so I was constantly resetting it. It is safely boxed up in the garage though.
  7. chris_columbia
    887
    Columbia MD
    Chris
    #57 chris_columbia, Apr 2, 2015
    My cigar lighter one, which I have used for the last 8 years. Stays on all the time, but super cheap and can be pulled out of the lighter socket at anytime.
    Did yours come back from PAS yet?
  8. Kidasters
    Oct 4, 2013
    546
    Houston, Tx
    Ken
    Not yet. I need to send them a note.
  9. Kidasters
    Oct 4, 2013
    546
    Houston, Tx
    Ken
    Got the voltmeter today. It's fantastic. You need sharp eyes to tell it wasn't built by Veglia. I'll install this weekend.
  10. chris_columbia
    887
    Columbia MD
    Chris
    Weekend? How about a preview now? You can't tell us you got it, and not supply a picture for a week!
  11. Kidasters
    Oct 4, 2013
    546
    Houston, Tx
    Ken
    too tired and lazy right now. Have patience.
  12. chris_columbia
    887
    Columbia MD
    Chris
    Patience is something I'm only good at when I don't want to see/do something.
  13. scowman
    scowman F1 Rookie
    Mar 25, 2014
    2,555
    Scottsdale AZ
    Stu Boogie
    Story of my life brother😁
  14. Kidasters
    Oct 4, 2013
    546
    Houston, Tx
    Ken
    #64 Kidasters, May 8, 2015
  15. hanknum
    hanknum Formula 3
    Nov 1, 2003
    2,050
    Santa Barbara
    Henry
    Very cool Ken...that looks perfect.
    Nice job.
  16. Rifledriver
    37,288
    They scare me because I have used them and know their work.
  17. Wilson308
    Wilson308 Formula Junior
    Apr 27, 2012
    635
    Arkansas, USA
    Wilson
    That is HOT! Nice work.
  18. chris_columbia
    887
    Columbia MD
    Chris
    Looks like it should, which is great. Any issues you have with it? Thanks for the pictures.
  19. chris_columbia
    887
    Columbia MD
    Chris
    Never mind, I see you already mentioned it was fantastic!
  20. Kidasters
    Oct 4, 2013
    546
    Houston, Tx
    Ken
    #70 Kidasters, May 9, 2015
    Installed.
    I put in a "Y" coming off of the circuit the radio is on, which is only powered when the ignition is on.
    Yeah - this is way more useful than the clock.
    Clock is tucked safely away in a drawer.
    Chris - the only issue is that the font on VEGLIA is a bit too big. And - it's better lit than the factory gauges at night (brighter). Huh.....
    Those two things are pretty minor in the grand scheme I think. I'm very happy.
    chris_columbia likes this.
  21. chris_columbia
    887
    Columbia MD
    Chris
    #71 chris_columbia, May 10, 2022
    I'm resurrecting this 7yr old thread...because I finally made some progress(actually just started today). Also, I have a few ideas that may help others who want to do something similar.
    A couple things I've learned:
    1. The earlier 308's have a slightly different "Veglia" text size from the later 80-85.
    2. The case diameter on all the Veglia 52mm gauges with the left-to-right needle sweep appear to be universal. Meaning you can pry the case ring off and swap the internals and bezels between gauges. This is true of gauges marked "Veglia Bressel" and "Veglia Borletti"
    3. All the 308 accessory gauges(the small gauges), are basically voltmeters. Meaning the gauge sees a voltage and the needle moves. They all have a single soldered resistor that can be changed to another value to "set" the position of the needle. For example: you can take a fuel gauge and change the resistor to 4kohms to make it a volt meter where 13V is applied and the needle goes to the center of the range.
    4. The cheapest(and simplest) way to make a voltmeter is to use the bezel from the clock or any other gauge(I got mine from Ferrparts), and put it on a Veglia voltmeter(see pictures)
  22. chris_columbia
    887
    Columbia MD
    Chris
    The last picture is what I want to end up with, once I make a Mylar overlay label(it's just paper in the picture). The Veglia Bressel needle is white, but the construction is the same as our black and green needle, so you just have to pry the top of the needle housing and swap it between gauges. Don't touch the needle, they are super flimsy. Only handle the "needle assembly" as shown in first picture. Anyway, hope this explanation might help someone.
    Rosey, mwr4440, Tonksy1 and 2 others like this.
  23. chris_columbia
    887
    Columbia MD
    Chris
    Also, thanks so much to Ken for attaching the graphics to this thread. You can see, I shamelessly stole it(and corrected the transposed 12 and 14).
  24. mwr4440
    58,150
    Bavaria, The 'Other' Germany
    Mark W.R.
    Cirorsi likes this.
  25. bitsobrits
    bitsobrits Formula Junior
    Nov 12, 2011
    792
    Omaha, NE area, US
    Steve
    So are you wanting to part with the extra one?
