In lieu of a spare tire: | FerrariChat
Discussion in 'Technical Q&A' started by Gatorrari, Oct 7, 2005.
  1. Gatorrari
    Gatorrari F1 World Champ
    16,505
    Georgia
    Jim Pernikoff
    I think I want to take the spare (a full-size front wheel and tire) out of the front well of my 328 and replace it with what I understand the 348 and later models came with: a can of "fix-a-flat".
    What I want to know is: how big a can was provided? What brand? And where and how was it located in the car? Anyone whose car came this way can respond to this thread, please.
  2. nerd
    nerd F1 Rookie
    Oct 12, 2003
    2,537
    Coronado, CA
    RSK
    For those of us with “spare-less” late models like the 550, and where the exceptionally expensive can of Ferrari fix-a-flat is out of date, most of us just carry 1 or 2 cans of similar stuff from your local auto parts store…..and a AAA card.
  3. Ricambi America
    Sponsor Owner
    Not to be a downer, but I always thought fix-a-flat was disasterous to the rim itself. I suppose it just gets "flung" outward to the tire, huh?
  4. f355spider
    f355spider F1 World Champ
    18,055
    Same here...I carry TWO cans of whatever they have at the local hardware or autoparts store for each of my cars (including the 355). I also have a AAA Plus card. They cost about $5 each on sale...the official Ferrari one is like $150 or some crazy sh*t, and after eight years, I imagine the think won't work anyway.
  5. DBR328&330
    DBR328&330 Formula Junior
    May 31, 2001
    605
    Winchester, VA
    Daniel Reese
    Careful about removing that spare!! I believe it is part of the front crushzone in an accident and its weight was factored into the handling characteristics. Your car may be less safe without it,
    Dan
  6. taber
    taber Formula 3
    Mar 4, 2005
    1,582
    San Francisco
    Norman
    I've heard the same thing about how it's bad for the rim, and the chemicals inside those fix a flats are not very environmentaly friendly either.
  7. flyingboa
    flyingboa Formula 3
    Nov 27, 2003
    1,564
    Italy
    Eugenio Dalla Rosa
    Personal expeience.
    I used fix a flat products for motorcycles. Yes, it is good for immediate recovery, but the point is that you must replace the repaired tyre ASAP and the cleaning of the rim is, at least, challenging...
    Dan,
    the removal of the original spare tyres in front is not so releant. As a matter of fact, the reduced size tyre was a factory option and the weight difference was not affecting handling.
    Ciao
    Eugenio
  8. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    I replaced the full size spare in the front of my 308 with a space saver from a 328. (Thanks Zan!) It made a lot more room. Now all my tools, jack, extra oil, etc. all fit up there as well, freeing up the entire truck. I thought all the 328s came with a space saver. I guess not.
    Birdman
  9. Jeff Pintler
    Jeff Pintler Formula Junior
    Jul 20, 2005
    537
    Richland
    Jeff Pintler
    Guys: I replaced my 348 can of fix-o-flat with a space saver tire. Never thought I would see the day but my wife ran over something that ripped a hole in the tire. Called maybe 20 dealers and found spare and jack (very nice leather case) for $1400! FWIW.
    Jeff
    89 348tb, 86 tr
  10. Ricambi America
    Sponsor Owner
    Was it really a 355 space saver spare they sold you? To my knowledge there is no "proper" 348 spare. I'm all ears! :)
  11. Dave
    Dave F1 Rookie
    Apr 15, 2001
    2,722
    Little Rock
    David Jones
    I carry fix-a-flat instead of a spare in a 308.
  12. Rifledriver
    37,288
    Ferrari says to replace the tire at the earliest time after the fix a flat is used.
    Also be aware that if your car has the tire pressure monitoring system (TPMS, all 575 and later cars) that the stuff in the can will ruin the $400+ sensor inside the wheel.
    $400+ for a sensor+ $300+ for a tire = Makes calling a flatbed look pretty good.
  13. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,354
    I think they came with a space saver in the US only - in Europe (at least here in the UK anyway) we got a full size front tyre.
    I.
  14. tonyyoshi
    tonyyoshi Formula Junior
    Jan 8, 2005
    308
    Hong Kong
    Tony Brooker
    forget the fix-a-flat UNLESS you have a carjack in the car too. my 355 had a flat rear tyre. emptied an entire can of the stuff into the tyre, nada happened. then i find out you're really ment to jack the car up, fill it, leave it for 10 mins then lower it... doh! so now i've got the fix-a-flat stuff AND a small jack.
  15. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,081
    Southeast USA
    Mike Charness
    It really DOES make a difference in the amount of space! Did you do anything to your front spindle caps so the 328 wheel would fit? Otherwise, if you have a front tire go flat, you'll have to either remove the grease cap entirely, or put one of your rear tires on the front and then the space-saver spare on the rear. That's the way I'll have to do it for the moment.
  16. flyingboa
    flyingboa Formula 3
    Nov 27, 2003
    1,564
    Italy
    Eugenio Dalla Rosa
    My 328 (Italy) came with space saver.
    Ciao
    Eugenio
  17. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    Just call me old school, but I dont like getting stranded and towed over simple crap I can do myself. Murphys law does not hazard fools, and in the worst place possible at the worst time, thats when youll get a flat. I want to be able to get myself back on the road. I will admit that tires today are almost incredible at staying together and keeping thier air, but nails and road debris can still wreck one. Also, before I would go with a space saver, I would want to be absolutely sure the tires on the car would fit in that hole. Really would suck to change your tire only to find your flat wont fit.
  18. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    Are you sure? The U.S. 308s all had full size spares because at the time, the U.S. didn't allow space savers, so only the Euro 308s had the space saver. I couldn't get my hands on a Euro space saver for a reasonable price, and I also liked the look of the 328 space saver better, so I bought one. I find it hard to believe that they reversed themselves on the 328 and sent the space savers to the U.S. and gave the Euros full size spares, but what the heck do I know.
    Mike, my understanding is that the grease cap only interferes with the horsey center cap on the 328 wheel. Maybe I'm wrong! My plan was for the purposes of a spare, I would just pop the horsey out. Or you can pry the grease cap off and replace when you get home.
    Birdman
  19. matkat
    matkat Formula 3
    Mar 18, 2003
    1,840
    Scotland
    Dave McGuire
    Jim I for one would advise against this as I have a fix a flat can for My 355 the only problem with it is if You have a large hole this cannot fix it as I know as I had to be recovered by truck when I had a blow-out.
  20. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,081
    Southeast USA
    Mike Charness
    I don't get what you mean... I changed out my 308's full size spare to a space saver, but the spare tire storage bin is still the same. A full size spare came out of it, so a full size wheel will go back in if necessary if I get a flat.
  21. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    I took it that Krowbar was referring to the cars that do not come with a spare but with a can of fix a flat. I thought he meant that perhaps a space saver spare would fit in the storage area but the full size wheel would not.
    My answer is throw the flat in the passenger's lap!
    Birdman
  22. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,081
    Southeast USA
    Mike Charness
    That's what I initially thought too, but no, that's not the case, at least with mine, and you'll probably find that's the case with yours too... give it a try BEFORE you actually need it. With the grease cap on, the 328 spare will not fully seat against the front wheel hubs, even if you take the horse insert off the wheel!
