In need of 115057 pipe from check valve to catalytic converters | FerrariChat
Discussion in '308/328' started by F308fan, Feb 17, 2022.
  1. F308fan
    F308fan Karting
    May 7, 2017
    162
    Peoria, AZ
    Tony Pacini
    Hello,
    I’m searching for the 115057 “Y” pipe for the air injection system that goes from the check valve to the catalytic converters (1981 308 GTSi US). I’ve found it listed on a few sites but with no prices.
    The valve and threads are fine but the threaded top of the pipe has been cut off just after it splits off and goes to each converter. The rest of the air injection system is intact.
    Are these available anywhere, or are they basically unobtainium?
    Thanks in advance for any help provided.
  2. lm2504me
    lm2504me Formula 3
    1,121
    Nipomo, CA
    Richard
    Try Ferrari of Houston
  3. F308fan
    F308fan Karting
    May 7, 2017
    162
    Peoria, AZ
    Tony Pacini
    Would someone have a pic of the actual installation in a car? The photo above seems to show that the threaded end of the pipe might mount to the corner of the engine block, while the photo below doesn’t seem to show it mounted to anything.
  4. F308fan
    F308fan Karting
    May 7, 2017
    162
    Peoria, AZ
    Tony Pacini
    Disregard; I see that it bolts to the frame.
  5. Steve Magnusson
    26,764
    Please post a picture when you've got it in place -- you've already proven that the information in the F documentation about this isn't very illuminating ;)
    Saabguy likes this.
  6. Rifledriver
    37,072
    I might have a used one.
  7. F308fan
    F308fan Karting
    May 7, 2017
    162
    Peoria, AZ
    Tony Pacini
    I’m almost afraid to ask what even a used one is worth, but I need to do something. My tubes are cut right below where the check valve attaches.
  8. fatbillybob
    Aug 10, 2002
    28,947
    socal
    It it is metal you could fabricate one pretty easy with a piece of pipe in that diameter in steel or aluminum and a welder.
  9. F308fan
    F308fan Karting
    May 7, 2017
    162
    Peoria, AZ
    Tony Pacini
    Sadly that is a skill I never learned.
    I’ve considered having an exhaust shop fabricate a way to join the tubes and add a check valve.
  10. fatbillybob
    Aug 10, 2002
    28,947
    socal
    No that guy probably can’t do it. Try a race fabrication shop. Racers find solution to problems vs. doing the same job every day to make a living.
    you can buy the tubing and cut it to shape then take it to a welder and get it done. That’s the solution to unobtainable and the Ferrari price tag.
    get a straw out your cupboard and cut it with scissors piece it to a Y shape. Now imagine you welded it together? That’s what I would do…fabricate it.
    Saabguy likes this.
  11. Baltz1969
    Baltz1969 Karting
    Apr 24, 2017
    74
    Chula Vista, CA
    Jose Baltz
    Just saw your post, I did mine several years ago I imported my 308 from Utah and had no smog equipment on it. That pipe you're talking about connects to each catalytic converter. I was able to use the tip from an 80's Volvo which was stainless steel. Had a local muffler shop fabricate the Y & the bends in the pipes to connect to the catalytic converters. The check valves are the same valves used in the 80s Camaro
  12. F308fan
    F308fan Karting
    May 7, 2017
    162
    Peoria, AZ
    Tony Pacini
    Yes, I assume that fabrication shouldn’t be too difficult if I can find the right shop to do it. I’ve still got most of the tubes (all the way to the cats). Fabbing a ‘Y’ and adding threads for a check valve is certainly easier than making the whole assembly from scratch. Check valves are pretty generic and available everywhere. I don’t really want to leave the car with anyone, though.
  13. F308fan
    F308fan Karting
    May 7, 2017
    162
    Peoria, AZ
    Tony Pacini
    Brian,
    How much would you like for your used one?
  14. F308fan
    F308fan Karting
    May 7, 2017
    162
    Peoria, AZ
    Tony Pacini
    I was able to get under the car and remove what’s left of my tube assembly. It was surprisingly easy to remove (no heat or penetrating oil required). I’m trying to figure out how it got to this point; the tubes appear to be cut before the ‘y’ rather than corroded apart, and the threaded end is missing altogether. The tubes were open on one end and the check valve was hanging from the hose on the other. In any case, now that I know it’ll be a straightforward installation, I’m on the hunt for a used one.
  15. F308fan
    F308fan Karting
    May 7, 2017
    162
    Peoria, AZ
    Tony Pacini
    #15 F308fan, Mar 6, 2022
    In the meantime, now that the pipe’s been removed, I wanted to plug the ports on the cats so I could continue to drive the car. Since the pipe was already in 2 pieces it was easy to remove one of the retaining nuts. I took it to the local hardware store and found brass caps of what I thought were the same size. When I got home, though, the caps fit only one of the threaded cat ports (the pitch seemed fine but the major diameter of the threaded section of one cat was a tiny bit larger than the cap). I got one of the brass caps to fit one of the cat ports, then cut a piece of stainless to cover the hole in the retaining nut, inserted it into the nut, and installed it on the other cat port. If it weren’t for wanting to save the existing tube in case I have to have it repaired, I would have just cut the tube to remove the other nut and used it (with another stainless insert) to cap the 2nd port.
