In over my head!!! Battery/alternator problem | FerrariChat
Discussion in 'Technical Q&A' started by seschroeder, Jul 10, 2004.
  1. seschroeder
    seschroeder Formula Junior
    Apr 25, 2002
    251
    Alexandria, VA
    Steve Schroeder
    Gentlemen:
    I guess I just don't understand - please help. The battery on my 1982 308 GTSi discharges after the vehicle sits for 10 to 14 days. If driven daily there is never a problem. There are no lights on that I can tell. The radio does have a "clock" but surely that would not be enough of a voltage drain. I suspect the diode in the alternator might be bad.
    When I attach a volt/omh meter to the vehicle, plus and negitive battery leads but the battery out, I get a reading of approximately .6 volts which then drops to 0 volts. I've done this twice. When I check for resistence, I would think in should read 0 without the battery, I get a reading. It goes without saying that I am not understanding something.
    Removing the alternator from the vehicle doesn't appear to be the most fun one could have.
    Any comments/thoughts before a remove the alternator for a rebuild??
    As always, thanks in advance.
    Steve Schroeder
  2. jimangle
    jimangle F1 Rookie
    Nov 5, 2003
    2,506
    Haverford
    James
    With the engine off, disconnect the negative terminal from the battery, and install the voltmeter in-line. That means run the red wire from the negative post of the battery, and run the black wire to the cable. This will give you a reading on how much of a drain you have on your battery. You could just install a battery tender in your car, and not worry about the drain. Two weeks idle is not that bad. My cars battery drain was overnight. My car was diagnosed with a bad alternator, and since it's been replaced, my car can sit for months and the battery will not drain.
    In order for you to take out the alternator, you have to remove the right aft tire, and remove the inner fender. Then drain the coolant, and remove the coolant pipe that runs in front of your alternator.
  3. Steve Magnusson
    26,806
    Steve, I think you said that a little backward -- if you remove the battery completely and measure the resistance between the "+" cable end and the "-" cable end, ideally you'd like to measure an infinite resistance, not 0 -- so getting a "reading" is normal.
    As Jim said (although it would be with the "voltmeter" in the ammeter mode), a maybe more meaningful measurement is to measure the current drawn from the battery when it is still in place, but everything possible is turned "off" -- i.e., place a large-capacity ammeter between one battery post and its cable end (while the other cable end is still hooked up to the battery). Something like .050-.100 A shouldn't be a problem -- if it's something like 0.5A, this is trouble.
  4. seschroeder
    Apr 25, 2002
    251
    Alexandria, VA
    Steve Schroeder
    Gentlemen:
    Thanks you both. I belive the light is now going on. With a omh meter set to measure resistence it will read 1.0 with nothing connect. If the two leads are placed together it should read 0. I am getting a reading so that should mean that the one-way diode in the alternator is working. Am I beginning to understand??
    Thanks again.
  5. DGS
    DGS Seven Time F1 World Champ
    71,911
    MidTN
    DGS
    Reading voltage across the batteryless car is simply reading residual charge (coulombs) left in filter capacitors -- which, as you noticed, drains away quickly under the meter's load.
    Reading resistance across the batteryless car would show "admittance" (inverse of resistance) only for things still turned on (drawing power) on an "off" car: Alarm system, Lo-Jack, radio memory, external stereo amp, clock, etc.
    If everything is off, you'd show infinite resistance (zero admittance). But such a reading isn't very reliable, because it depends on the voltage battery your ohmmeter uses (typically 1.5v or 9v) ... which may not be sufficient to bias diodes in a 12v system, so there may be load your ohmmeter wouldn't read.
    The best check, as people have told you, is to measure current draw from the battery with the car off. To measure current, you have to place an ammeter in series with the battery (car to meter to battery to car). A small multimeter is sufficient to read residual current with the car off. Just be sure not to hit the starter with the meter inline, unless you want to see the meter peg (and smoke come out of your meter).
    If you don't have an alarm or recovery system hidden away somewhere, then from the amount of cap charge you're getting in an "off" car, I'd guess this comes from the stereo.
    3X8 Ferraris are odd, in that the radio wiring is not switched with the ignition key. Most cars only power the stereo/radio when the key is in "on" or "accessory", but the F-cars don't have an "acc" position (only "avv": start). (Can you turn your radio on when the car is off?)
    You might have a massive noise filter on the radio power line. Such a filter can draw a lot of power, and is typically only used on switched circuits, rather than on "always-on" leads.
    That, or your external stereo amp is always on. The previous owner installed a hidden switch to remotely power the stereo and external amp on my 328. The consignment house couldn't figure out why the battery was draining all the time, because they didn't know to turn it off. These days, most amps have a sense line from the radio that switches the amp on or off. Depending on the amp, it might default to on if the sense line is interrupted. (It may depend on how old your stereo installation is.)
  6. DGS
    71,911
    MidTN
    DGS
    Um, not exactly.
    An alternator is a "delta"-pole three phase alternating current (AC) device, with the voltage regulator controlling the current in the armature field winding. The three stator windings each use diodes to rectify the generated AC current to direct current (DC). (If that helps. ;) ) The AC "alternator" became standard in cars, because it produces electricity at lower engine RPMs than was possible with older DC "generators", and because the variable field winding allows the power (and engine load) to be regulated at the source, rather than afterward.
    Lots of shops talk about replacing the alternators, in reponse to any battery problem. Caveat emptor. If you're getting 15 or more volts across the battery while it's charging, then your alternator is probably OK. If your battery is bad, you get false voltage readings from the alternator, so many shops replace both, "just in case" (and because it's coming from your pocket, not theirs).
    You need to track down your current load. You can measure static ("off") current, and then pull fuses, one at a time, to see when the current load drops. I'd start with any inline fuses wired to the battery terminal clamps, because that's probably an aftermarket gizmo.
  7. seschroeder
    Apr 25, 2002
    251
    Alexandria, VA
    Steve Schroeder
    Well, the battery problem appears to be solved. After "hot-wiring" the radio memory to the battery, I would still have voltage to the vehicle with the negitive Battery Ground Disconnect removed. Turns out that the radio was grounding to the chassis thru the antenna. That fixed, there no longer is voltage to the chassis with the Battery Ground removed. All is once again well!!!
  8. CarlH
    CarlH Karting
    Feb 5, 2004
    81
    MD
    Carl H.
    Need to revive an old thread here....Similar issue with battery drain on 308. Made a bunch of measurements to get some understanding. Also replaced the battery and ended up with no difference.
    I read about 125 mA of current draw with the car off. This is a bit higher than I expected, but with a 70 amp-hour battery, it should be good for a more than a week of sitting. After charging the battery with the shop charger I measure about 12.25 Volts before starting the car. After start and before bringing the rpm's over 2K, the reading is 11.75 volts. After the 2K rev-up, the voltage reads 12.6 at 900 RPM. (Strange issue with the undervoltage before running up the engine, but have seen this same feature with several other Italian cars so I assume it is normal) At higher RPM the voltage increases to 13+ volts - Did not take any readings above 2500.
    Numbers don't seem great, but not so far out of line to indicate loss of one of the bridge diodes or other voltage regulator or alternator problems. Do these readings sound "normal"???
    Carl
  9. seschroeder
    Apr 25, 2002
    251
    Alexandria, VA
    Steve Schroeder
    I had my alternator rebuilt and "upgraded" to 90 amps. It came back from the shop with a 13.8 voltage regulator. Still the car would run at less than 13.0 volts. I upgraded the voltage regulator to a Transpo 14.5 unit and the car now runs at 13.7/13.8 or so volts above 1,500 RPM (at idle it is close to 11.0). I am still not certain this is correct but if there is a voltage drain I've had no luck finding it. I've pulled the fuses one by one with no change. There is no resistence on the large battery cable from the battery to the starter and no resistence from the fuse block to the alternator. Since the battery now does not discharge while the car is sitting guess I live with it. Still?
  10. Dr Tommy Cosgrove
    May 4, 2001
    36,431
    Birmingham, AL
    Tommy
    When was the last time your radio was pulled out? I am just wondering how that problem developed.
  11. CarlH
    CarlH Karting
    Feb 5, 2004
    81
    MD
    Carl H.
    Thanks Steve - After thinking about the problem, I realise that the draw when the car is off would completely drain a fully charged new battery in 23 days. I think that rather than look at the charging system, I should look into the reason for the high discharge with the car off.
  12. f355spider
    f355spider F1 World Champ
    18,044
    Set up your test gear, and pull fuses to track down the likely culprits. I would guess it is either an aftermarket alarm or stereo gear (amplifier). Sometimes the installers fail to put the amps on a switched power lead, so they remain always on.
