In search of aerial/antenna switch | Page 2 | FerrariChat
Discussion in '308/328' started by flyngti, Sep 29, 2010.
  1. Hannibal308
    Hannibal308 F1 Veteran
    Jan 3, 2012
    7,177
    Arizona / Hawai’i
    Hannibal
    So I did the mod last night...and partially failed two days ago. The key is spring steel for the pin that goes behind the plastic contact. A correctly sized safety pin supplied the spring steel wire I needed to do the mid correctly. This pic below shows the wire behind the plastic contact. These wires go in central to the contacts and before the springs. Works 100% perfectly as a momentary on up and down while staying off in the center position.
    lm2504me likes this.
  2. lm2504me
    lm2504me Formula 3
    1,122
    Nipomo, CA
    Richard
  3. Hannibal308
    Jan 3, 2012
    7,177
    Arizona / Hawai’i
    Hannibal
  4. Jonny Law
    Jonny Law F1 Rookie
    3,210
    Over yonder.
    IT Guy
  5. Hannibal308
    Jan 3, 2012
    7,177
    Arizona / Hawai’i
    Hannibal
    If the wrong switch is what someone wants, then might as well go to Radio Shack or Pep Boys.
    The right switch for many (but not all) cars is a Lucas switch. It can be found but is in $100 range. My point of posting here is that the expensive Lucas switch is identical to a very inexpensive and readily available Lucas switch, after easily adding a piece of spring steel wire inside the switch...exactly as Lucas did on the expensive switch.
  6. Jonny Law
    Jonny Law F1 Rookie
    3,210
    Over yonder.
    IT Guy
    My apologizes for sullying your post.
  7. Jonny Law
    Jonny Law F1 Rookie
    3,210
    Over yonder.
    IT Guy
  8. lm2504me
    lm2504me Formula 3
    1,122
    Nipomo, CA
    Richard
    Not Radio Shack.
    Google Lucas 3 position switch. It needs to be a Lucas and not a Lucas wanna be. It should be in a green Lucas box. Confirm with seller.
  9. Hannibal308
    Jan 3, 2012
    7,177
    Arizona / Hawai’i
    Hannibal
    No sullying noted...
    The Arc-Components Lucas switch (on-off-on) would indeed likely be the right one to modify into a correct aerial switch per richard’s instructions.
    The Superformance aerial switches are replacements but not Lucas. The “Large Interior Switch” they have won’t do, as it’s just an off-on switch.
  10. Jonny Law
    Jonny Law F1 Rookie
    3,210
    Over yonder.
    IT Guy
    Ah, now I see where you went wrong. Sorry
