In Tank fuel filter | FerrariChat
In Tank fuel filter
Discussion in '308/328' started by TommyA, Sep 10, 2020.
  1. TommyA
    TommyA Formula Junior
    Oct 7, 2002
    549
    Atlanta
    Tommy A
    The in tank fuel filter has fallen apart on my 82 308. Has anyone been able to source the filter?
    Thank you
    Glad that I have decided to check the filter while everything was out.
  2. Steve Magnusson
    26,599
    Try a search using the term "fuel sock" for some prior threads -- this issue has come up before.
  3. DinoParts, Stefan
    Sponsor
    Mar 1, 2015
    139
    Eschwege, Germany
    Stefan Kratzer
    If you meassure the tube where it slides on I might have a solution.
  4. J-P
    J-P Formula Junior
    Nov 15, 2007
    338
    #4 J-P, Sep 10, 2020
    Saabguy likes this.
  5. J-P
    J-P Formula Junior
    Nov 15, 2007
    338
  6. J-P
    J-P Formula Junior
    Nov 15, 2007
    338
  7. TommyA
    Oct 7, 2002
    549
    Atlanta
    Tommy A
    Fuel filter ID 15mm
    OD 18mm
  8. mwr4440
    57,853
    Bavaria, The 'Other' Germany
    Mark W.R.
    #8 mwr4440, Sep 15, 2020
    Algar has the screen for sale.
    It is 100 or 120 mesh.
    A little on the steep side ($18.00) but if ya need it YA NEED IT.
    Frankly, I think Ferrari 'Screwed the Pooch' putting that thing on the INSIDE of the tank.
    The rats maze of sinks, rises and 'blind' allies inside of those tanks are AMAZING. Trapping dirt INSIDE Those Tanks is the LAST THING any SANE Person would WANT to Do.
  9. TommyA
    Oct 7, 2002
    549
    Atlanta
    Tommy A
    Actually my problem might work to my benefit. I was going with all AN hoses and fittings and MB is making a couple of complete units just like Porsche Image Unavailable, Please Login as long as the size of the nut is the same size..
  10. DinoParts, Stefan
    Sponsor
    Mar 1, 2015
    139
    Eschwege, Germany
    Stefan Kratzer
    I had a littel hope that you could use this one but the OD is 22 here. Probably I can modify it on the lathe if you need a quick solution.
  11. Glenn308QVturbo
    Sep 20, 2017
    34
    Glenn Orell
    I had the same problem on my 308 a few years ago. Mechanic friend recommended going down and getting a generic fuel strainer at Napa and zip tying it to the original tube. I was skeptical that the zip tie would dissolve in the gas but I tested it and worked out fine. The tank developed a leak in a weld a year later and while it was out I pulled the strainer and all was fine. Been driving it like this for three years and works great.
    thorn and Saabguy like this.
  12. TommyA
    Oct 7, 2002
    549
    Atlanta
    Tommy A
    I have checked with Algar and was told that is no longer available.
  13. mwr4440
    57,853
    Mark W.R.
    Sorry Buddy. :(
    But a good hardware store has it I bet.
    A fellow FChatter found 100 mesh over here that he is gunna use with no issue whatsoever.
  14. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    Any generic equivalent mesh is going to do the job just fine. No need to worry about NLA OEM.
  15. ferrariowner
    ferrariowner Formula 3
    Feb 21, 2014
    1,139
    Mansfield, TX
    Ron
    Which year model cars have these filters?
  16. TommyA
    Oct 7, 2002
    549
    Atlanta
    Tommy A
    Well.. mine is an 82. I believe the TR has it also
  17. Glenn308QVturbo
    Sep 20, 2017
    34
    Glenn Orell
    My car is a 83 QV but I would assume that most if not all 308's use a similar strainer. Don't know if it failed from age or ethanol fuel, but when it did it clogged the fuel pump destroying it. As our cars are all 35 to 45 years old its worth checking. It cost me a $300 fuel pump.
  18. ferrariowner
    Feb 21, 2014
    1,139
    Mansfield, TX
    Ron
    The part # is 116870. It seems pricy on the sites that list a cost, over $150 USD. And to answer my own question it looks like it fits all 208/308/328 variants.
  19. Dr Tommy Cosgrove
    36,282
    Birmingham, AL
    Tommy
    My 82 Alfa Spider has one.
  20. Steve Magnusson
    26,599
    Virtually every gasoline-powered car has some sort of "strainer" in the path from the gas tank outlet to fuel pump inlet (to catch the big stuff, if any).
    waymar likes this.
  21. RodC328gts
    RodC328gts Formula Junior
    Aug 17, 2021
    458
    Mexico
    Rod C
    I have not checked my screen. But I’m learning for future reference.
    other idea would be to remove that and install a external filter before the pump
  22. s219
    s219 Formula Junior
    Aug 26, 2021
    479
    Most external filters are meant to be on a pressurized line, whereas the in-tank strainer (and everything upstream of the fuel pump) is under suction. So that would be important to work out and make sure the external filter is appropriate. It would need to be fairly coarse media to work on a suction line.
    When I replaced the fuel pump on my 87 328, I looked inside the tank strainer from the outside with a lighted scope camera, and it looked fine visually. So I didn't mess with it. I recall reading of a few folks who broke it off when trying to remove, and that would turn into a much bigger job to deal with.
    RodC328gts likes this.
  23. Steve Magnusson
    26,599
  24. bill308
    bill308 Formula 3
    1,224
    Windsor, CT
    Bill Sebestyen
    I need to deal with this issue too. One thing to remember, flow is from tank to pump. A Soft sock filter would tend to collapse and choke flow entering the end of the tube. The filter needs to be stiff or otherwise supported. The purpose of this filter is to prevent relatively large chunks of debris from obstructing flow.
    I was going to cut and form a cylinder of stainless steel screen with one end capped. I could overlap and silver solder the edge seam. Bond or wrap the cylinder with safety wire to the fitting. Seems like a lot of work. My work around is to install the current tank fitting without a filter, but fit a down stream, transparent, disposable filter. This could be placed before or after the fuel pump. The tanks are clean.
    Du_Man likes this.
  25. s219
    s219 Formula Junior
    Aug 26, 2021
    479
    Well, the filter needs to be before the fuel pump, because the main purpose of the in-tank filter screen is to protect the pump (there is a proper fine-scale filter after the pump that is meant to protect the rest of the system, whether carbs or fuel injection). The in-tank filter screen mainly prevents larger debris from affecting the pump.
    And as I mentioned up above, the filter needs to be capable of handling suction. Those transparent plastic fuel filters are not and may collapse and/or suck down the filter media. Definitely check the specs of any external filter to make sure it can handle the suction of the pump (you can lookup ∆P and flow rate specs for most fuel pumps to get an idea).
    Most of the socks I have seen mentioned here are meant to be stretched over a screen or strainer frame of some sort. Should work OK as long as they are properly supported over a large surface area.
