In-Tank Fuel Filter | FerrariChat
In-Tank Fuel Filter
Discussion in '308/328' started by rwbolt1, Mar 26, 2025.
  1. rwbolt1
    rwbolt1 Karting
    Sep 10, 2006
    215
    Boerne, TX
    Rodney Bolt
    Doing fuel related work today (pump, filter, crossover hoses, etc) and was surprised to see the in-tank fuel pre-filter seems to be in good shape even after 35 years. I prodded firmly on the mesh and cage and it doesn't seem to be brittle. Only the adhesive attaching it to the nozzle has disintegrated. If I'm not mistaken, these filters are no longer available. Should I continue using or replace using the "sock filter method"? If I do continue to use, what adhesive (to reattach to the fitting) is compatible with being immersed in fuel? Any advice from your experiences is appreciated.
  2. Sergio Tavares
    Sergio Tavares Formula 3
    Nov 15, 2018
    1,308
    Sergio Tavares
    fuel resistant gasket seaaler, was permatex grey but now is permatex pea sop color
    rwbolt1 likes this.
  3. Imatk
    Imatk Formula Junior
    May 6, 2007
    768
    Mine was disintegrated so I had no choice. I replaced it with a sock filter and have had no issues.
  4. Steve Magnusson
    26,801
    I would say "none" if you rely on the adhesive to provide both mechanical strength and sealing. Using the best possible adhesive for the sealing is OK, but I'd add some sort of mechanical attachment (like drilling some small holes and using some metal wire to literally "tie" the strainer onto the metal tube) -- JMO.
    ChevyDave and rwbolt1 like this.
  5. ProvaMo
    ProvaMo Formula Junior
    Jun 29, 2004
    351
    Mid West
    Paul John
    The original sock on mine (1979 US/NA) was pretty disintegrated, a good fit for me was a new 1970's (+/-) GM sock (5/16 ID or ~8mm). I was concerned about retention, but when I installed the new sock (with the tank out) looking through the fuel level sensor hole, the far end of the sock nicely rested against an internal structure, acting as solid retention method (i.e. I didn't use an adhesive)
    rwbolt1 and Du_Man like this.
  6. Imatk
    May 6, 2007
    768
    I used something similar on mine, but I had to drill out the hole so it would fit onto the fitting. Then I zip tied it after.
