'Incorrect paint job to blame for Heikki's crash' | FerrariChat
Discussion in 'Other Racing' started by jk0001, May 8, 2008.
  1. jk0001
    jk0001 F1 Veteran
    Oct 18, 2005
    6,706
    Sun Coast
    Jim
  2. 62 250 GTO
    62 250 GTO F1 Veteran
    Jan 9, 2004
    7,765
    Nova Scotia Canada
    Neil
    *Rolls eyes* Uh Huh.
  3. GuyIncognito
    99,955
    You gotta read pretty far into the Big Book of Excuses to find that one...
  4. jk0001
    jk0001 F1 Veteran
    Oct 18, 2005
    6,706
    Sun Coast
    Jim
    I had a girl friend that had that exact same problem! She needed a special brand of nail polish, she said that the cheap brands make her nails crack and split. Maybe she was on to something
  5. racerx3317
    racerx3317 F1 Veteran
    Oct 17, 2004
    5,701
    New York, NY
    Luis
    *Translation* We made the wheel too weak and it broke..
  6. ferraridude615
    ferraridude615 F1 Veteran
    May 4, 2006
    5,836
    Texas
    I didn't know you could translate from F1 BS to English :D
  7. racerx3317
    Oct 17, 2004
    5,701
    New York, NY
    Luis
    It's a talent...;)
  8. nopassn
    nopassn Formula 3
    Nov 19, 2003
    1,959
    Kansas City
    Roy
    "In running, the consequent loss of load caused the wheel to fret and distort, leading to its eventual failure."
    You'd think this "fretting and distortion" would have caused a noticeable and severe vibration... One that Heikki sure would/should have felt...
  9. kraftwerk
    kraftwerk Two Time F1 World Champ
    May 12, 2007
    26,826
    England North West
    Steve
    Well I hope they have discovered this as the fault, I would hate to see that to happen again.
  10. jm3
    jm3 F1 Rookie
    Oct 3, 2002
    4,364
    United States
    JM3
    That text sounds like a translation. I am speculating that clear paint was applied to the "wheel nut" surface on the wheel, allowing the wheel nut to get slightly loose, and therefore allow the wheel to "tilt" inward and rub the brake duct backing plate which cause the inner bead lip to shear off.
    Jay
  11. RP
    RP F1 World Champ
    Feb 9, 2005
    17,667
    Bocahuahua, Florxico
    Tone Def
    I had a friend that was a female, blamed all three pregancies on her nail polish. None were mine, so she might be correct.
  12. fatbillybob
    Aug 10, 2002
    29,070
    socal
    Actually totally plausible. The paint can cause failure to acheive lasting torque on the fastners that hold the wheel lip halfs. Then they come loose and parts are under way more stress than if clamped properly then blamo...
  13. TopElement
    TopElement Formula 3
    May 14, 2005
    1,540
    OC & Vegas
    A Montoya
    Pretty sure they're running 1 piece wheels. They wouldn't tolerate the extra weight of modulars!
    The wheel nut mounting surface likely had too much paint. Nut went on tight, the paint softened with heat, wheel became loose. Seems strange that it happened so quickly, although it was in a braking zone.
    Depending on the fit of the wheel drive pins, it could allow some freeplay to make wheel mounting faster/easier. The brakes are also mounted to these drive pins, but are a snug fit. When brakes are applied, the rotor tries to stop and that left front wheel keeps trying to turn counterclockwise. With some freeplay, the wheel could turn the nut a little. Not sure if that corner is regular or reverse threaded.
  14. Senna3xWC
    Senna3xWC F1 Rookie
    Nov 30, 2006
    3,152
    NYC
    and a useful one around here... :p
  15. icky
    icky Karting
    Jan 2, 2004
    179
    Anchorage, AK
    Jesse B.
    Well at least McLaren goes far enough to give mechanical excuses, unlike "there was a bump in the track" Ferrari.
    I didn't think it was directly a paint issue... I thought they said it was in fact a defective part, that was then lacquered? I didn't really read too thoroughly as it was pretty common sense that it was a defective wheel.
