Incorrect water temp dial reading | FerrariChat
Discussion in '308/328' started by Transient, Dec 22, 2016.
  1. Transient
    Transient Karting
    Sep 6, 2007
    114
    Sydney Australia
    transient
    Hi guys,
    Just a quick question before the Chrissy holidays, after normal driving conditions and a bit of traffic, the water temp reading on the dial is getting really high, like almost 120 degrees, but the reading on my temp gun reads normal temperatures, between 90 and 95 degrees.
    Can anyone shed some light on this discrepancy please? Could the temp reading sensor be faulty? And where is this located?
    The location of where i point my temp gun is the expansion tank, the radiator cap, and the engine itself, all readings are very close (90 to 95 degrees C).
    The reading on my oil temp gauge is again very close to the reading on my temp gun, and i point this at the oil filter to get my temp reading.
    Any help is, as always, greatly appreciated...
  2. Rifledriver
    37,130
    Any external measurement will always be lower. It isn't a valid test.
  3. GordonC
    GordonC F1 Rookie
    4,163
    Calgary, AB, Canada
    Gordon
    My coolant temp gauge is suspect, I have had issues with it indicating too warm, ~220F, on occasion. There are a few of us here with similar issues. At this point, I suspect the gauge is the problem.
    I've done infrared temp gun readings as well, but I use the thermostat housing, or the aluminum coolant pipes on the right side from the water pump, or the coolant pipe on the left side, compared with gauge reading and the operating state of the radiator fans. I have found that the coolant pipes when the engine is fully warmed up (after driving) will be at around 90-92C, maybe 94C when the fans comes on - but the gauge can be reading 195 or 220 or in between, without consistent correlation.
    Recognizing Brian's point that an external reading is not directly comparable to the sensor reading in the coolant flow stream, it's important to establish consistent reading points and compare external temp readings for different operating conditions - gauge indicating normal, gauge indicating high, radiator fans operations, etc.
    On occasion, I've seen where the coolant temp gauge is indicating high (220), then will suddenly drop to 195 - in the space of 1 second, like a clock ticking, so not indicative of a stuck thermostat opening where the drop would be less rapid.
    After having searched here and read many threads about the coolant temp, I have reached the tentative conclusion that the fault lies with the gauge itself. Several members have written of similar issues that were resolved by removing the gauge panel and cleaning the electrical connections on the back of the coolant temp gauge, and also cleaning the wiring harness ground connection points under the dash. I have put off doing that myself until the gauge LED lights arrive so I can convert the instrument panel lighting to LEDs (any day now!), I will be checking the coolant temp gauge at that point.
    I haven't read of the coolant temp sensor giving problems of false readings or inconsistent, randomly changing readings, but that is still a possibility. I'd be interested to know of problems with that component.
    Each case will be different, though, and I wouldn't want to lead you to an assumption that it's just the gauge and that you don't have an overheating issue. You want to be sure that your thermostat is functioning correctly, and that the rest of your cooling system is in good shape - radiator, hoses, water pump - before focusing on the gauge.
  4. Rifledriver
    37,130
    Check that you have a really good 12v+ at the gauge. That is the cause of many of the problems you describe. On some cars when the lights or rad fan goes on the gauge will suddenly move. It is due to a voltage drop on the circuit. The instruments are very voltage supply sensitive and is what that kit that TacElf makes for the oil pressure is designed to solve.
  5. GordonC
    GordonC F1 Rookie
    4,163
    Calgary, AB, Canada
    Gordon
    Agreed, that's my plan along with cleaning the gauge contacts.
    I know there is a voltage drop issue to the dash gauges, right now when I turn on the running lights my fuel level, oil pressure, and coolant temperature needles all go up by a few needle widths! (The oil temperature gauge in the console doesn't move)
  6. ferrariowner
    ferrariowner Formula 3
    Feb 21, 2014
    1,155
    Mansfield, TX
    Ron
    I notice my temp gauge fluctuating over the last 25 years. It is indeed a voltage issue. My car has EFI and uses a separate temp senser from the one in the dash. The EFI system logs all parameters including water temperature. It is rock steady while the factory gauge tends to move around. I am always concerned when the dash gauge goes up. It is comforting that I don't see a corresponding change on the EFI temp reading.
    However, I think you will see your dash gauge change within a range of readings. If it gets above that range, definitely take precautions and check it out.
  7. Transient
    Transient Karting
    Sep 6, 2007
    114
    Sydney Australia
    transient
    Thanks everyone for your replies.
    I went out for a long drive today, here in Sydney we are in the middle of summer so in the heat and traffic the car went well, no overheating issues.
    When i parked at home i checked the temps at the gauge and the temp gun, all the same readings! Very weird, but good...
    Readings were a little high but consistent with the conditions, oil temp around 100 degrees C, water temp between 100 and 105 degrees C...
