increase in compression/increase in HP | FerrariChat
Discussion in 'Technical Q&A' started by etip, Aug 31, 2007.
  1. etip
    etip Formula 3
    Apr 4, 2004
    2,406
    Washington State
    Eric
    I am rebuilding my motor in my 308 and am curious what kind of HP and torque increase I will get out of raising the compression ratio to about 10.25/1. The car is an '80, it is getting euro heads (no emission equip), tubi exhaust, fresh everything.
    Thanks,
    etip
  2. Telerding
    Telerding Formula Junior
    Sep 30, 2004
    362
    Santa Maria/CA
    Tom Elerding
    I recently rebuilt my 72 Daytona motor; Carobu engineering, in Costa Mesa, CA did the work.
    Stock Daytona motor is supposed to put out 352 Hp. They had measured one at 330 or so before rebuilding.
    Stock compression ratio is around 9:1. I had them put in 10:1 pistons. They also ported the heads a little, added optical ignition. Car is a Euro, which has VERY NICE tuned headers.
    My engine put out 415 Hp on the engine dyno. This is without air cleaner. When they added the air cleaner, they had to rejet the carbs, and the motor put out 395 Hp. That's a pretty nice bump over stock. I believe the first five race Daytonas were putting out about 425 Hp.
    I have been told that at least on my engine, the best thing you can do to increase Hp is to go to higher compression.
    Good luck.
  3. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,791
    The twilight zone
    Most of you hp is most likely from the porting and although you didn't mention it, I'm guessing a cam change.
    Bumping the compression helps keep the low end strong with longer duration cams and or better flowing heads, but by itself doesn’t do an awful lot…I have to look the formula up, but it’s an exponential decay relationship I think, so going from 9 to 10 does a fraction of what 8 to 9 does which does a fraction of 7 to 8, ect. The main thing is keeping the cylinder pressure up when the cylinder is not filling well at low rpm.
  4. Air_Cooled_Nut
    Air_Cooled_Nut Formula Junior
    Nov 25, 2004
    952
    Portland, Oregon
    Toby Erkson
    Increasing compression is a good method for increasing power across the board...but it also increases heat generation. BTW, a higher octane fuel will be necessary unless the car already takes 91.
  5. blkprlz
    blkprlz Formula 3
    Mar 24, 2007
    2,169
    Tampa bay
    Bruce
  6. TopElement
    TopElement Formula 3
    May 14, 2005
    1,540
    OC & Vegas
    A Montoya
    The power gain from a compression increase depends on where you make peak power. And I think US Daytona's were even less than 9:1.
    If peak power is at 6000rpm, you might gain 25hp. With a peak at 7000, you may gain 40hp. A lot of variables, but higher compression is definitely good all around.
  7. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,791
    The twilight zone
    I've never found that to be true and is not supported by any theory I am aware of either.
  8. TopElement
    May 14, 2005
    1,540
    OC & Vegas
    A Montoya
    Just the basic HP equation. The higher the rpms with the same amount of torque, more horsepower is made.
  9. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,912
    Atlanta
    John!
    I have to disagree with such a low figure. 5-10bhp at the flywheel with a drastic change in compression from 8.8:1 to 10.25:1 has yielded excellent results. My reasons are experiences with another Italian engine, but a very cut and dry result was netted.
    I rebuilt a Maserati Merak ss engine a few years ago which was dyno'd at the rear wheels at 179rwbhp only months prior to rebuild and in excellent condition. The engine is rated in stock form @ 220bhp at the flywheel by the factory with 9:1 compression. This engine in prior rebuild state had approx 30k miles on it until it dropped a valve, hence the rebuild. The only modification added to this engine were 10:1 custom Ross racing pistons and all rotating components were balanced. The Ross pistons were considerably lighter than stock. End result was 197rwbhp once jets were mated with the new setup for performance. Drivetrain loss with the Citroen gearbox on the Merak ss is about 15%. Not a bad increase once it was tuned correctly.
    I am not well versed with the Bosch injection system used on the 2 valve cars, so I do not know how easily tuned it is for such modifications. I bet if 10.25:1 pistons were used in an early carb car with early carb cams, 15-20bhp at the flywheel would be easily attainable with correct tuning. The only difference between the carb motor I just described and the LM engine would be the P6 cams. Carobu made 277bhp at the flywheel with P6 cams and 10.5:1 cpr
  10. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,791
    The twilight zone
    Compression ratio is not in the hp equation.
    It's in the thermal efficency equation, which does not contain rpm. Compression ratio is not in the hp equation. It's in the thermal efficiency equation, which does not contain rpm.
  11. etip
    etip Formula 3
    Apr 4, 2004
    2,406
    Washington State
    Eric
    Hey all,
    Thanks for the input. I am going to have to replace the pistons and go 10 over bore after all, so it's a no brainer to me to go up in C.R.
    I'm going with Weisco pistons, pins, and rings.
    I'm going to be using my stock cams; I just can't swing any more since this rebuild IS breaking my bank. I'll check the port matches on the heads, intake, and exhaust. My headers are being ceramic coated for increased thermal efficiency.
    We'll be degreeing in the cams, using the aluminum gears.
    What else is inexpensive while I'm in there???
  12. Ferraripilot
    May 10, 2006
    17,912
    Atlanta
    John!
    how about main and rod bearings at about $400 a set each?
  13. etip
    etip Formula 3
    Apr 4, 2004
    2,406
    Washington State
    Eric
    Yes, I'm doing the bearings. I am not cutting corners on the rebuild. What I meant was what other little things can be done to tweak or improve the motor when I'm in there?
    Thanks again for everyone's input and advice.
    etip
  14. tatcat
    tatcat F1 World Champ
    Sep 3, 2001
    11,013
    panama city beach FL
    rick c
    mill the heads for higher compression. polish and relieve the manifolds and heads. fire trench the pistons. balance all moving parts.
  15. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    If you are rebuilding, use new pistons for increasing cr and avoid milling the heads. Both JE and Wiseco have done pistons for Ferraris.
    Agree with port and polish, but recommend someone with a flow bench do it. If the car is driven on the street, would max flow to point of max velocity. I've heard just a good multi angle valve job makes a big difference as well.
    You biggest flow restriction to max hp is your injection system, which in naturally aspirated form will peak out at delivering about 270 hp or so if everything else optimized. There is a lot bantered about regarding larger throttle bodies & plenum opening, but I'm not sure and never saw really good numbers.
    While increasing CR may not affect top output as much as you might hope, I believe you will really feel it in the lower rpm range where these cars need it.
    Fchatter Pogibm (?) did a similar work up on his injected 2v (CR, p&p, etc) and got spectacular results for a 2v. There is precedent.
    good luck!
  16. etip
    etip Formula 3
    Apr 4, 2004
    2,406
    Washington State
    Eric
    Russ,
    Thanks for the input. Yes, I'm using new Weisco pistons for increased CR, I'm not going to mill the heads. Doing a good three angle valve job, as well as new valves and guides.
    I understand that I'm limited by the injection. This is a street car and I'm actually on a pretty tight budget, so I'm not going to do any exotic carb or injection set up.
    I'll update as the build progresses.
    etip
  17. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,791
    The twilight zone
    replacing the induction system and cams`wii make a pretty big difference on that engine, but can really be done any time...so after the budget recovers :)
  18. Telerding
    Sep 30, 2004
    362
    Santa Maria/CA
    Tom Elerding
    From mk e: "Most of you hp is most likely from the porting and although you didn't mention it, I'm guessing a cam change. "
    Based on the rebuilder's comments, compression ratio provided most of the Hp change. CAMS were NOT changed.
    Heads were flow ported, but little was needed. That is NOT true for US cars; they have a built in restriction in the exhaust ports.
    I'm sure that some of the Hp gain was due to their "tuning" of the cam timing, distributors and carburetors.
    It is also possible that the Euro cars normally put out MORE than the listed 352 HP.
    Whatever the reasons, I am really happy with the car, except for one minor nagging problem.
  19. etip
    etip Formula 3
    Apr 4, 2004
    2,406
    Washington State
    Eric
    yeah, that's what I was thinking.....
  20. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    I am very admiring of your Daytona rebuild and Tate has referenced it several times in our many discussions on engine fine tuning. Some of the lessons that your rebuild and others have taught me is that while you CAN do things one at a time, the effect and matching of several measured changes really can work together.With yours, the cr change with tuning the cam timing, adding some head flow and then matching the Weber jetting all were part of a matched set.
    I've done mine fairly piecemeal up until now with small changes and have been happy as well. With the current project - 44DCNF carbs, ported head, larger intake valves, 10.5 CR, .400 lift cam and Tubi Euro headers, I am trying for a set piece. Although each change is not anything large by itself, I am hoping they all come together well.
    As to etip's rebuild, I would still see if I could find about $2K and do the carb conversion...on a 2v it would be especially easy and a bolt on affair. Between the Webers and and cr increase, just the change in throttle response ALONE would feel like 100hp although he will probably pick up around 40+ even with stock cams with the cr, porting and Webers. The breathing and response in the lower rpm ranges would really wake up. I've also learned that on the street this is FAR more important than chasing some peaky dyno number to show off.
    And then there is that Weber sound thing, NEVER to be underestimated... :)
    Best to all
  21. etip
    etip Formula 3
    Apr 4, 2004
    2,406
    Washington State
    Eric
    Yes, I would love to do the carb conversion or a tunable FI set up, but it's really NOT in the budget this time around. I'll probably be toying with it for a while to come, at least the guts will be up to snuff so that when I do it will be all bolt on stuff.
  22. bill308
    bill308 Formula 3
    1,225
    Windsor, CT
    Bill Sebestyen
    Basic thermodynamics predicts increases in efficiency directly proportional to compression ratio. This means, all else assumed the same, torque and power will scale directly with the increase in compression ratio. So, an increase in compression ratio from 10:1 to 11:1 should yield a 10% increase in torque and hp. Mathmatically, assuming 200 hp at 10:1, should result in 220 hp at 11:1 The resulting power=11/10(200)=220 hp (similarly with torque) if I have my math right.
    This assumes, of course, that the engine is not flow limited over the rpm range, 0-7700 rpm and that one has not entered into the region of detonation. If this is the case, benefits will be realized up to the point of the flow limit or be impeaded by detonation.
    This also means that fuel consumption will be reduced for a given power output by 10%. Increasing compression ratio is the single most efficient way to improve engine performance provided one can satisfy the octane requirements. You never get anything for free.
    Bill
  23. etip
    etip Formula 3
    Apr 4, 2004
    2,406
    Washington State
    Eric
    this is what I like to hear!!! I'm going from the stock 8.8 (really 7.??) to 10.25. I'm psyched!!!
  24. oss117
    oss117 F1 Rookie
    Jan 26, 2006
    4,185
    Plantation, Florida
    Alfredo
    This is all true to a point though, as any increase in compression ratio slows down the speed at which the flame front travels.
    At high compression ratios sometime it is necessary to use 2 spark plugs per cylinder to offset the problem.
