Indicator Relay | FerrariChat
Indicator Relay
Discussion in '308/328' started by Sigmacars, Dec 13, 2022.
  1. Sigmacars
    Sigmacars Formula 3
    1,220
    Dos the Indicator Relay control front and back and where is it located
  2. ferrariowner
    ferrariowner Formula 3
    Feb 21, 2014
    1,155
    Mansfield, TX
    Ron
  3. Steve Magnusson
    26,846
    If you mean the flasher for the direction and hazard indicator lights on a 328 = yes, it does the all the flashing (front and rear and for the hazard function also). If any light is flashing correctly, the flasher is OK (and, if a front light is flashing OK, but a rear light is not, or vice-a-versa, the problem isn't the flasher). It's item 22 here (on the backside of the passenger footrest panel):
    https://www.ferrariparts.co.uk/diagram/ferrari/328-gtb-gts-(1985)/116-electrical-system-cables--fuses-and-relays
  4. Sigmacars
    Sigmacars Formula 3
    1,220
    Thank you I like to change all my indicators to LEDs so in need to change the relay to stop hyper flash so I need to know the relay position that controls the indicators
  5. dave80gtsi
    dave80gtsi Formula 3
    1,921
    Ohio
    Dave Meredith
    Why not just turn on your emergency flashers and follow the 'click-click' sound beneath the dash?
