Indicator stalks | FerrariChat
Indicator stalks
Discussion in '206/246' started by dinogtss, Oct 14, 2013.
  1. dinogtss
    dinogtss Karting
    Jul 14, 2013
    138
    Hi all anyone out ther know if ferrari 275 indicator stalks are the same as dino 246 indicator stalks?
  2. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,643
    Toronto / SoCal
    Rob C.
    I am almost certain that they are not the same. The closest is the stalk used by the Daytona but even then (depending on the year of Dino) it may require some modification. Later Dino's used stalks similar to those on the 308. It really does vary by serial number.
  3. dinogtss
    dinogtss Karting
    Jul 14, 2013
    138
    Thanks for your reply mine is a very late 73 early 74 72...... Serial
  4. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,643
    Toronto / SoCal
    Rob C.
    A very late car should have stalks that are totally different to the 275. I would suggest referring to the Dino Compendium for exact details. If you do not have it then order it today. No Dino owner should be without it.
  5. TKO
    TKO Formula Junior
    Oct 22, 2004
    790
    SoCal
    Tom Kearns
    Sorry to change the subject, but when will that project of yours be done Rob? I feel like I've been waiting forever ..... :)
  6. dinogtss
    dinogtss Karting
    Jul 14, 2013
    138
    Hi
    Can anyone here sell me a new set ? to suit a late dino
  7. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,679
    South East
    Jimmie
    Eurospares show 103518 which is a possible for USD 1250
  8. isuk
    isuk F1 Rookie
    Nov 11, 2005
    3,335
    Iain
  9. HMB-Dino
    HMB-Dino Formula 3
    2,307
    Pebble Beach, CA
    RonG
    I still have the one I took out of my Euro Dino, replacing it with the proper Euro version column switch assembly (it had the US version when I bought the car). It's in great shape with the exception of a very minor crack in the headlamp twist knob. I haven't put it on eBay yet as I was waiting to replace that twist knob first once able to source one (there are several variations of this knob). As of when I removed it from my Dino, it seemed to be perfectly functional. If my Dino wasn't a Platinum level concours car, I would've kept the US assembly in and saved the expense of replacing it with a correct one.
    As a general interest note, the Euro switch assembly I bought, which was in much better shape than the eBay one referenced, cost me about $800. Fully restoring it cost another $1100 or so.
  10. swift53
    swift53 F1 Veteran
    8,371
    E.S.
    Alberto
    Verell has a few switches that belong to me and were sent to him for restoration.
    There are more than I require, as the two for my needs have been restored.
    If you are interested, you might contact him and enquire if any are suitable for your application.
    Regards, Alberto
  11. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    #11 Verell, Oct 16, 2013
    dinogtss,
    What is your problem? Do you have a broken switch, missing stalk, or is everything missing?
    I can help with any of the above.
    The Eurospares 103518 appears to be a black stalk switch that was used in 308s. See their picture:
    http://www.eurospares.co.uk/userImages2/Medium/1476770.jpg
    My records show that at least 1 of swift53's switches should be correct for an E-series Dino. I will take a look tomorrow to verify.
    TLC is right, stalks are corroded, but look like they could be stripped & replated. Headlight & turn stalk pivot(switch) ends show cracking, must be replaced. The cracking is due to the plastic drying out & trying to shrink onto the incompressable metal stalk.
    Hard to tell about the wiper pivot end, but usually when the turn pivot end is cracked, the wiper will be also.
