Indy light switch and back axle | FerrariChat
Discussion in 'Maserati' started by OFFtrack, Mar 13, 2014.
  1. OFFtrack
    OFFtrack Karting
    Jan 4, 2013
    185
    Berlin
    Dirk R.
    Hey,
    Have 2 questions:
    A few months ago the light switch in my Indy fell into pieces. Had to replace it with a temporary modern version from a Mercedes or so to get it working until i get the replacement from MIE. Unfortunately i wasnt able to take pictures of the cables and what was the right position so when i try to reconnect i only get to switch on the parkingblight but the lights wont come up. Does anyone have a pic or a plan of the correct combination? Thanks.
    When i reconnect the MB substitute everything works fine
    Also, the salisbury rear axle is making a mid frequency noise between 100-120kmh
    Probably difficult to tell without a detailed explanation but is it common, that the differential is a bit on the noisy side or should i have it checked/overhauled?
    Thanks a lot
    Dirk
  2. bundas
    bundas F1 Veteran
    Dec 31, 2005
    7,090
    lexington ky usa
    mitchell barnes
    NOISE allowed in Italian cars. really, the axle should b the same sound through the range. you need to do whatever you are going to do before you drive another foot. as to stalks. Indy's. have and early and late. more bend on early units. I have a new late one used on single pod models. $1,200 usd
  3. Froggie
    Froggie Formula Junior
    Sep 27, 2017
    536
    Belgium
    Serge
    May I ask what is meant by "single pod"?
    Are the ones pictured here under of the single pod later model?
  4. thecarnut
    thecarnut F1 Rookie
    3,230
    Atlanta
    The Car Nut
    He was referring to the interior layout of the dash. The early cars had a "dual pod" layout, like the photo below. I do not know the differences in switches on an Indy.
    Ivan
  5. Froggie
    Sep 27, 2017
    536
    Belgium
    Serge
