inertia switch issue on the first hour!? | FerrariChat
Discussion in 'California(Portofino)/Roma(Amalfi)' started by ForeverNA, Dec 1, 2016.
  1. ForeverNA
    ForeverNA F1 Rookie
    Dec 14, 2014
    2,622
    #1 ForeverNA, Dec 1, 2016
    Just took delivery the HS 2 days ago. The wait has definitely been more gruesome than my other cars! I drove for 30 mins and parked the car in front of a restaurant. Then I realized the emergency lights were blinking. I went back and saw the message of "inertia switch triggered". I had to press that button to reset it underneath the driver seat after googling it myself. I then went on to drive for another 3 hours without issues before returning it to the dealer for wrap.
    My question: Is it something I should worry at all? Thanks!
    p.s. The car has been great and the handling is a tad sharper than my porsche gt cars while it is a lighter. The chassis was able to filter some unwanted info that I got from the other cars while it was able to accentuate some info as well. I like it a lot.
  2. 4th_gear
    4th_gear F1 Rookie
    Jan 18, 2013
    4,425
    Michael
    The first miles in a new car will bring out many potential build issues with it. So expect to insist the dealer check and sort out any surprises. The inertia switch should NEVER self-trigger. Imagine what would happen if it happened while you were driving... or if you did not have access to the Internet. It could be as simple as a flaky switch or bad wiring connection.
    FWIW, I discovered an annoying problem with the HELE option intermittently cutting out ever since I took delivery... it was a pain but they finally sorted it - a bad electrical connection inside the steering wheel. Car's solid now.
    OTOH, glad you enjoyed your new CaliT HS. ;)
  3. good2go
    good2go Formula Junior
    Feb 9, 2016
    939
    Make sure the car is plugged into a battery tender. I found that my car had a few lights go on for no reason. After I plugged in it took 2 days to get battery tender to green. I have not had any lights come on since battery has been plugged in. I put 7500 miles on my California T this summer.
  4. ForeverNA
    ForeverNA F1 Rookie
    Dec 14, 2014
    2,622
    okay. Will tell the dealer. Thanks! you guys are awesome and a great source of info to a newbie to Ferrari.
  5. tomc
    tomc Two Time F1 World Champ
    Apr 13, 2014
    26,056
    DFW, Texas
    Tom C
    2 days?!? Holy smokes. Mine typically goes green in a couple of hours.
    OP... Definitely report it, so there is a record, even if it never reappears. +1 on a battery tender, even overnight, just to keep it fully juiced up. Good luck and hopefully it'll be smooth sailing from here on out...T
    Edit - to get around the possibility of no bandwidth, you can get a copy of the owner's manual at Ferrari of Fort Lauderdale.
    https://www.ferrarifl.com/owner-manuals.htm
    I have an iPhone and so keep a local copy on iBooks. It's keyword searchable. On several occasions it's kept this newb owner from freaking out when the F-chat brain trust couldn't be reached! [emoji3]
  6. ForeverNA
    ForeverNA F1 Rookie
    Dec 14, 2014
    2,622
    Thanks! Does anyone else have issue with the inertia switch?
  7. kevinof
    kevinof Rookie
    Jul 26, 2015
    44
    Shame there is no manual for th Cal T. anyone know where I can download one?
    ta
  8. tomc
    Apr 13, 2014
    26,056
    DFW, Texas
    Tom C
    You're welcome. I have not, mine is a 2011, and would probably freak the heck on out if that message popped up. Isn't this switch only supposed to be activated in the case of a crash or rollover?
    T
  9. tomc
    Apr 13, 2014
    26,056
    DFW, Texas
    Tom C
    I've not been able to find a PDF manual for the T.
    T
  10. LeoNewland
    LeoNewland Karting
    Jun 2, 2007
    170
    Fort Worth
    Leo Newland
    Kevin, I just put my California T Owner's Manual (.pdf) in a public folder in my Dropbox for anyone who wants it. You can access it at:
    https://www.dropbox.com/sh/ot3szcgyxhy6jnp/AAA6G0WbCoIyqP7topaDdU2ia?dl=0
    The manual is about 28 MB and the 'zip' version is just over 23 MB.
    Leo
  11. 4th_gear
    4th_gear F1 Rookie
    Jan 18, 2013
    4,425
    Michael
    Excellent! Thanks Leo, I had wanted to peruse the CaliT manual for some time. ;)
  12. good2go
    Feb 9, 2016
    939
    I logged in to myFerrari portal and downloaded a manual. I then copied to my cell phone so I always have it.
