info on 308 engine leakdown readings | FerrariChat
Discussion in 'Technical Q&A' started by groovzilla, Nov 28, 2003.
  1. groovzilla
    groovzilla Karting
    Nov 28, 2003
    117
    seattle, wa.
    william
    can anyone please let me know what the comprssion leakdown readings would be on a carburetted 308 motor...please relay what excellent/good/bad readings would be for a high mileage engine (74K) and a low mileage engine(36k)...i am looking at 2 cars and these answers would help a great deal!!...thank you so much!!
  2. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,702
    San Carlos, CA
    Mitchell Le
    My 308 engine, right after the rebuild, with new rings, and honed cylinders, register 180 psi across the board. I have not checked it lately but the car runs good so I really don't care.
    The important thing is to have good compression (140-160 psi) with an old broken in engine, to have them fairly even across all cylinders (145-155 psi all across is better than 165 for 6 cylinders and 120 for 2 cylinders). What is more telling is the percentage leak down (if you do a leak down test).
  3. groovzilla
    groovzilla Karting
    Nov 28, 2003
    117
    seattle, wa.
    william
    thank you so much for your post...i will be having a "leakdown" preformed when i have the buyers inspection done...if leakdown is based on a percentage, what should these figures be on a an excellent/good/poor 308 engine for both a high miles(74K)and low miles(36K) motor..
    thanks...
  4. pma1010
    pma1010 F1 Rookie
    Jul 21, 2002
    2,559
    Chicago
    Philip
    My data:45K mile engine
    Leakdown 5 - 7 percent. One cyl at 12 - 14.
    Compression: 185 +/- 5
    HTH
    Philip
  5. thecarreaper
    thecarreaper F1 World Champ
    18,163
    Savannah
    excellent thread...... i too am searching for a carb 308. thanks for the info. micheal
  6. 4re gt4
    4re gt4 Formula 3
    Apr 23, 2002
    2,279
    Roseburg, OR
    Hans E. Hansen
    Note that gauges can vary, and altitude seems to make a difference. Mine read 165 +/- 5, but I heard of a car measured at Denver that was a consistent 135. Leakdown showed it to be in good condition. Also, if a cam's timing is a bit off, it can affect readings. Several here have had sizeable differences front-to-rear, with all cylinders on a given bank similar. They invariably found a cam that wasn't timed correctly.
    Also, cams with high overlap give lower readings. Early '80s cars will give somewhat higher readings than mid-70s cars for that reason.
