Ingenuity, the tiny Mars helicopter that could, will keep flying | FerrariChat
Discussion in 'Aviation Chat' started by NYC Fred, Aug 31, 2023.
  1. NYC Fred
    NYC Fred F1 World Champ
    16,061
    Fort Lauderdale, FL
    Fred C
    Pretty cool. They're working on version 2, which will fly out, collect soil/rock samples and return them to a rocket to bring them to Earth.
    (HTH does this thing cost 80 mil?)
    CAPE CANAVERAL, Fla., Aug. 30 (UPI) -- Ingenuity, the tiny $80 million helicopter that has hovered over Mars 55 times since April 2021, will continue mapping the planet's surface as long as it can still fly, the former team lead at NASA's Jet Propulsion Laboratory in Pasadena, Calif., told UPI.
    Most people, "even at JPL, wondered about flying a helicopter in an atmosphere with a pressure that's barely 0.7% of Earth," Anderson said. "There was a huge question of whether you could actually do something useful with a helicopter on Mars."
    As it turned out, propeller blades spinning between 2,400 and 2,900 rpm did the trick. They are not just run-of-the-mill blades; they are made of carbon fiber specifically designed for the Martian environment.
    Given Earth's greater atmospheric density, helicopter blades run between 225 and 550 rotations per minute, depending on aircraft shape and size.
    The little helicopter has now covered 41,024 feet of ground and stayed aloft for nearly 98 minutes on its 55 flights, mission team members wrote on the chopper's flight log. And a repositioning 56th flight is imminent.
    https://www.upi.com/Science_News/2023/08/30/Mars-helicopter-ingenuity/3461693248312/
  2. tazandjan
    39,159
    Wonder what the speed of sound is on Mars? Have to look it up. The denser the atmosphere, the faster sound travels.
    Not as big a difference as I would have thought. About 800 fps on Mars, about 1100 fps here at sea level.
  3. Solid State
    Solid State F1 World Champ
    10,568
    Maximus Decimus Meridius
    Colossal waste of money. $81M ? Why was it such a guess if it would work at 0.7 atmospheres when they have the largest thermo-vac chamber on earth to pump down to the exact pressure. Begs the question if it didn't work then how do you would explain trashing that much money. o_O
  4. tazandjan
    39,159
    I can think or a lot worse ways to spend $81M and so can politicians.
