Injector and Seal Question:308QV | FerrariChat
Discussion in '308/328' started by PhilB, Jan 17, 2010.
  1. PhilB
    PhilB Formula 3 Owner Silver Subscribed
    Feb 17, 2004
    2,314
    Southern New Jersey Shore
    Phil
    I just finished the major, cam seal, belt change job, and figured I have some time until the weather breaks so I'd like to change the injectors, they are still original to the car. The car is a US Spec 308QV, June 1984 build. I also recently changed every single hose, sleeve and vacuum line in the car, thanks to Dave Helms. The car now runs unbelievably great, I can't get over it.
    Anyway, for anyone who changed their injectors already, I just want to confirm the injector is a Bosch #0437502047, right? These folks look to have the best prices around for these:
    http://www.autohausaz.com/search/product.aspx?sid=ftfqfs45oc5cgr55h40ongyw&partnumber=0437502047
    Also, it looks like there are two seals available for this injector (W0133-1642075 and W0133-1643510):
    http://sd.autohausaz.com/autohausaz/detailw.jsp?sid=qphr41bgdhvep2eyet5ru545&partner=autohausaz&product=3430210606
    I haven't removed any of the injectors yet, and I won't until the new parts are in hand. So I'm unsure if I need both these seals, or only one of these? If one, which did you use?
    Thanks in advance,
    Phil
  2. Steve Magnusson
    Steve Magnusson Two Time F1 World Champ Lifetime Rossa
    26,784
    Correct
    The Bosch PN for the "donut" seal is 3430210606 -- if you search at Autohauz on that part number it brings up two alternatives, but not the ones that you show ;). Those may still be OK, but I'm only sure about the Bosch PN.
  3. ClydeM
    ClydeM F1 World Champ Owner Rossa Subscribed
    Nov 4, 2003
    11,883
    Wayne, NJ
    Clyde E. McMurdy
    Did my '83 QV several years ago. Your # is right. Found the Bosch injectors from a Mercedees Dealer for $5 each - was a phenomenal deal.
    The donut seals where another thing. There seems to be two styles in use at the time. I pulled an inject out to find mine were the fat kind & I bought them from GT Car parts.
