Buy
Inner Door Handle Mondial 8
Discussion in 'Technical Q&A' started by sjmst, Mar 22, 2004.
  1. sjmst
    sjmst F1 Veteran
    Jul 31, 2003
    9,852
    Long Island, NY
    Sam
    Anyone know where I can fine one? Ferrari of LI says they are No Longer Available.
    Sam
  3. Modificata
    Modificata F1 Rookie
    Apr 27, 2003
    2,654
    Hampton, England
    Andy Rasool
    Try Ferrari UK Classic parts. They may have in stock.
  4. 4rebob
    4rebob Karting
    Nov 3, 2003
    173
    Alaska
    Robert Taylor
    Ferrari UK Classic parts:
    60631200 RH INTERIOR DOOR HANDLE £88.05
    60631300 LH INTERIOR DOOR HANDLE £0.00 (not available)
  5. sjmst
    sjmst F1 Veteran
    Jul 31, 2003
    9,852
    Long Island, NY
    Sam
    Thanks!
  6. sjmst
    sjmst F1 Veteran
    Jul 31, 2003
    9,852
    Long Island, NY
    Sam
    ARE THE RIGHT AND LEFT 82 MONDIAL INNER DOOR HANDLES INTERCHANGEABLE?
    They look like they should be. Anyone know???
    Sam
  8. ninot
    ninot Karting
    Feb 7, 2004
    225
    Sunny Staffordshire
    Nino
    If the handles are the same as the Uk spec 1989 Mondial 3.2 then they are the same as a Fiat Uno. Could be worth a look.
  9. sjmst
    sjmst F1 Veteran
    Jul 31, 2003
    9,852
    Long Island, NY
    Sam
    Thanks>
    I think they changed them from the 8 to the 3.2. I did find some RIGHT ones, which Ferrari of LI was able to fit on the left side, and it works fine.
    Thanks again,
    Sam
  10. michaelthuber
    michaelthuber Karting
    Mar 4, 2003
    150
    Cincinnati, Ohio, US
    Michael Huber
    Actually I just did this on my Mondial. Don't go with a Mondial Rt handle although you CAN make it work. Go instead with a PT # 257.30.810.02 I think this may be a 400i handle but it an exact match for the Mondial only the design of the release lever is different. Here is the good part.
    PT# 60631200 MONDIAL RT Handle $362.84
    PT# 257.30.810.02 Pininfarina door handle $153.96
    I assume that the top of your handle is broken or that the cast tray that bolts to the armrest is broken. If so and the release lever is intact all you need to do is the take 257 part above and replace the lever by taking 1 nut off. It works perfectly. If you choose the Mondial Rt side handle you have to flip the lever over and kind of do a little bending to get it to work.
    BTW I got mine from T.Rutland's, AKA Maranello Parts. I would check out one of our sponsors to see if they have the parts. They didn't when I checked.
  11. michaelthuber
    Mar 4, 2003
    150
    Michael Huber
    I was trying to edit this message, but I ran beyond the 60 min. limit.
    I was wrong about using the Rt side Mondial handle. Actually you have to also drill and mount the lever mounting bolt onto the other side of the handle. This will require making a spacer. You can see in the pics that the levers mount on opposite sides of the casting for Driver's and Rt side handles.
    If all you need to replace is the actual handle strap then either part will work fine as a donor. Just drive out the pin and use the handle and spring.
    I have enclosed some pics to help clear this up. I replaced the 275 lever because the Mondial's lever already had the bushing and bolt pressed in and it was easier than trying to press them out and press them back into the new lever.
  13. sjmst
    sjmst F1 Veteran
    Jul 31, 2003
    9,852
    Long Island, NY
    Sam
    Great info. Thanks!!!!
