Inner Door Handle Refinishing, 348 | FerrariChat
Discussion in '348/355' started by dertizjos, Sep 10, 2011.
  1. dertizjos
    dertizjos Formula Junior
    Jul 20, 2011
    453
    New Jersey
    #1 dertizjos, Sep 10, 2011
    I recently refinished my inner door handles. They were a little worn and looking a little ragged. The process was as simple as can be and I thought I would pass on my experience in the hopes it helps somebody out there.
    I removed the handles which is simple. Remove the bolt under the door pull handle, move the pull out of the way and then unscrew the bolt for the door handle. Handle then comes right off.
    The handles are metal with a coating so I just used a bench grinder with a wire wheel and took the finish down to bare metal.
    Prime, paint and reinstall. Good as new and a 30 minute project.
    Lifeboatboy likes this.
  2. VTChris
    VTChris F1 World Champ
    Aug 21, 2005
    13,259
    They came out perfect, great job!
  3. Dolcevita
    Dolcevita Formula 3
    Jul 5, 2011
    1,470
    Ontario, Canada
    Craig
    #3 Dolcevita, Sep 11, 2011
    I pulled mine last week and took them to a powder coating shop we use. Most of the original coating came off with a solvent but plastic blasting was used for the final removal. I had them coated with a semi-gloss paint. I will probably do them over with a satin or matte finish. The semi-gloss is a might be a bit too glossy.
  4. AceMaster
    Feb 6, 2009
    34,787
    Ontario, Canada
    OP - nice job.
    Craig - I think the semi-gloss looks good :)
  5. butch355
    butch355 Karting
    Jan 27, 2005
    114
    Denver
    Brent
    Try SEM trim black.
    13$ a can but worth it and great OE finish that most shops use. My paint show sells cases of the stuff each week. I am doing my 355 interior right now and is turning out great!
  6. Magnum6464
    Magnum6464 Formula Junior
    Mar 5, 2006
    319
    Quebexico, Canada
    Mario
    Mine seemed to be refinished based on the previous looking one you posted and are matte black. My entire interior was redone, nothing sticky...well all beside the interior of the ashtray.
    I would love to see what the handles look like just polished with no paint....
    Mario
  7. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
    We've done these threads a few times. There is a spray finish that is rubberized made by the same company that does the dip stuff for your tools. Home Depot carries it.
  8. AceMaster
    Feb 6, 2009
    34,787
    Ontario, Canada
    Plasti-dip?
  9. vvassallo
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
    I'll have to check the garage bins, but that sounds familiar. ;)
  10. Dolcevita
    Dolcevita Formula 3
    Jul 5, 2011
    1,470
    Ontario, Canada
    Craig
    The product is Plasti Dip and it has been discussed on here before. You can buy it in a can and dunk parts (I used it to colour code tool handles) or in a spray. I stripped my console parts two weeks back. I debated using Plasti Dip, but the underlying plastic had a fairly good finish. However, there are a few sink marks (slight indentations where the part is thicker, leading to different cooling / contraction rates) that might get covered up by a thicker coating. I also noticed that the mold finish (texture) varies between the HVAC Panel & the ashtray. The ashtary cover has a smoother finish, so it's not a perfect match.
    In the end, I may just pack the whole lot up and send them to Robbie at Sticky No More and be done with it. As much as I enjoy working on these odd bits, I doubt I will ever get anything to look as good as his work.
  11. AceMaster
    Feb 6, 2009
    34,787
    Ontario, Canada
    I saw one of these spray-cans and read the contents...it states that it gives rubber finish (akin to the pliers and other hand tools) but I thought it would give a hard plastic finish (hence the name "plasti")...I am wondering if over time this would turn to goo like the OEM crap that came on the handles to begin with...I wouldn't mind hearing from those that used plasti-dip on their handles
  12. 285ferrari
    285ferrari Two Time F1 World Champ
    Sponsor
    Sep 11, 2004
    20,976
    MD and NE
    Robbie
    I can tell you that any parts you touch on a regular basis coated with PlastDip will start to peel off over time. I have seen it 50 times....
  13. troppoveloce
    troppoveloce Formula Junior
    Jan 25, 2006
    268
    New Hampshire
    Tom
    #13 troppoveloce, Sep 12, 2011
  14. Magnum6464
    Mar 5, 2006
    319
    Quebexico, Canada
    Mario
    WOW, that is seriously nice.....my wife even commented how sharp it would be in mine.
    Mario
  15. vvassallo
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
    Robbie is correct about the longevity of the spray on stuff. Still it's an easy afternoon project if you are bored. Otherwise, send your stuff to a professional for a more permanent solution. Black nickel would be cool. Wonder who does that? ;)
  16. AceMaster
    Feb 6, 2009
    34,787
    Ontario, Canada
    Thanks Robbie...that's what Craig and I thought too.
    Bling bling!!!
