Inside an F355 Fob | FerrariChat
Inside an F355 Fob
Discussion in '348/355' started by Robb, Dec 23, 2014.
  1. Robb
    Robb Moderator
    Moderator Lifetime Rossa Owner
    Feb 28, 2004
    14,336
    Robb
    #1 Robb, Dec 23, 2014
    So I picked up some extra batteries for my brother's GTS key fob. I'll plan on carrying an extra battery with a small screw driver in the car in case there is trouble with a battery in the future. Didn't know if the group had seen the insides so here goes.
    Robb
  2. Robb
    Robb Moderator
    Feb 28, 2004
    14,336
    Robb
    #2 Robb, Dec 23, 2014
  3. 0.0.1.99
    0.0.1.99 Formula Junior
    Jan 14, 2012
    424
    Carolinas
    Ken
    It is also worth pointing out that we should not store our spare fobs with the batteries installed. If the batteries leak and your fob electronics are affected, there is no inexpensive way to get back to 3 fobs (or whatever your starting number is). I think it even makes sense to travel with a spare fob in the car somewhere in case the primary fails.
    I am looking forward to the day that the immobilizer system can be rendered inert. The early models got it right.
    Ken
  4. Robb
    Robb Moderator
    Feb 28, 2004
    14,336
    Robb
    Great point Ken! Thank you for that.
    I learn some good habits and new info EVERY DAY here. :)
    Robb
  5. Robb
    Robb Moderator
    Feb 28, 2004
    14,336
    Robb
    Wonderful post from Rob4092xx in the 360 section on red vs black fob's
    THANK YOU Rob!
    See below:
    Robb
    Programming a Ferrari Alarm ECU with New Fobs:
    Alarm and Fob Basics: Ferraris arrived from the factory with three alarm remote fobs,
    one red master fob, and two black slave fobs. The red fob contains the Alarm Electronic
    Control Unit (ECU) Personal Identification Number (PIN) and an identification (ID)
    number. The black fobs contain only an ID number. The red and black fob ID numbers
    are combined with a rolling code to prevent compromise by thieves using a radio receiver
    and recorder to duplicate the ID and code and use those to gain entry, just like modern
    garage door openers use rolling codes to prevent compromise.
    The Alarm ECU PIN is provided with the car, or with a new set of fobs, on a small piece
    of two layer paper, the top layer of which must be removed to read the PIN. A red fob
    can be used to program other black fobs using the same procedure outlined below for
    programming a new set of fobs, if a black fob is lost or becomes inoperative. The Alarm
    ECU does not use the PIN except when the car is started with ignition key and PIN alone
    (fobs lost or inoperative), or when reprogramming the ECU to accept new fobs. In normal
    use, the Alarm ECU uses only the fob IDs and rolling codes. Reprogramming the Alarm
    ECU for a new set of fobs is an extension of starting the car with ignition key and PIN
    only.
    In normal practice, use the black fobs and keep the red fob in a safe place where it will
    not be lost or damaged. This will ensure replacement black fobs can be programmed into
    the Alarm ECU using the red master fob, if necessary.
    The Alarm ECU will only accept the red fob PIN and ID and two black fob IDs during
    reprogramming. Note the fobs are transmitters only. They have no receiver capability.
    European and US/Canadian fobs use different transmitter frequencies and are not
    interchangeable.
    Ferrari recommends changing the 23A/A23/MN21 12 volt battery in your fobs every six
    months. This is easily accomplished with a small Phillips head screwdriver to remove the
    screw holding together the two fob halves.
    If you only have alarm key fobs and no PIN, you cannot reprogram your Alarm ECU to
    accept new key fobs. (It is possible to clone extra key fobs to provide back-ups. Do a
    search in Ferrarichat.com.) Ferrari North America, through its authorized dealer network,
    can provide you a new Alarm ECU, a new set of three matching fobs, and the PIN
    number as an ultimate, but costly, solution.
    With the alarm and engine immobilizer armed, pressing a key fob will disarm both alarm
    and immobilizer. After 120 seconds, the engine immobilizer will rearm if the car is not
    started. Starting the car will require one additional push on the fob to disarm the
    immobilizer after 120 seconds have elapsed since disarming the system. If you remove
    the key and open a door after returning from driving and do not arm the system with a
    fob, the immobilizer will arm 60 seconds after the door is opened. To reprogram the
    Alarm ECU to the new PIN in the red fob, make sure the immobilizer is armed and the
    alarm is disarmed.
    Starting a Ferrari without a Key Fob: The first step in reprogramming the Alarm ECU
    to accept new key fobs is the same process used to start a Ferrari if all remote alarm fobs
    are lost, inoperative or unavailable and you only have the ignition key and know the four
    digit Alarm ECU PIN. This procedure is spelled out in the Alarm System Manual
    supplied by Ferrari. Here is the procedure spelled out in the Ferrari copyright Alarm
    System Manual:
    If this seems rather cryptic, here is what it means:
    Drive your car to make sure the battery is fully charged in case you foul up the procedure
    so you do not run down your battery.
    Remember the times important in this sequence. Key off-on-off cycles representing PIN
    numbers must be made in less than two seconds. After PIN numbers are entered by the
    required number of key off-on-off cycles, a pause of more than 2 seconds and less than
    20 seconds must be made before entering the next PIN number. If your PIN has a zero, it
    is represented by 10 off-on-off cycles of the ignition key. If you foul up, you must wait at
    least 20 seconds before starting over. So here is the procedure after you have driven the
    car and waited 60 seconds after removing the key and opening the door or 120 seconds
    after removing the key and not opening the door so the immobilizer is armed.
    PIN Code 3204 is used as an example for this case. This is different from the code 3324
    in the Ferrari illustration above. Ignition switch position “0” mentioned above is off and
    position “II” is on.
    1) Insert the ignition key and wait at least 20 seconds with the ignition key in off.
    2) Turn the key from off to on and back to off as quickly as possible (less than 2
    seconds for all PIN numbers) 3 times (count to 3 out loud) for the first PIN
    number “3”.
    3) Count to 5 out loud (a good compromise between more than 2 and less than
    20 seconds) before starting the second PIN number.
    4) Turn the key off-on-off 2 times for the second PIN number “2”.
    5) Count to 5.
    6) Turn the key off-on-off 10 times for the third PIN number “0”.
    7) Count to 5.
    8) Turn the key off-on-off four times for the fourth and last PIN number “4”.
    9) At this point, after 2 seconds or a bit more, the alarm light emitting diode
    (LED) will go off and you can start the car. Starting the car confirms you can
    correctly enter the PIN, the first step in reprogramming the Alarm ECU to
    accept new remote alarm fobs. Keep trying if you do not succeed the first
    time, remembering to wait more than 20 seconds before the next attempt.
    Programming the Alarm ECU for New Fobs: Ferrari also provided procedures for
    reprogramming the Alarm ECU to accept new remote alarm fobs. This process is
    described as putting the Alarm ECU in “self-learning” mode in Ferrari Workshop
    Manuals, the first step of which is entering the Alarm ECU PIN as described above.
    Again this is a bit cryptic, but the times for entering the PIN numbers still apply and less
    than 2 seconds is what you need to remember for the following ten key cycles noted
    above.
    Again PIN number 3204 is used as an example and the first eight steps for starting a car
    with PIN and ignition key alone (no fob available) are identical but given here as a
    complete checklist for reprogramming the Alarm ECU. The steps following PIN entry
    rely on watching the Alarm LED cycle from on to off ten times and eventually flashing
    when “learning mode” is fully enabled and the new alarm fob PIN (red fob only) and IDs
    (red and black fobs) can be entered into the Alarm ECU memory.
    1) Insert the ignition key and wait 20 seconds with the ignition key in off.
    number “3”.
    5) Count to 5.
    7) Count to 5.
    9) Count to 5.
    10) Turn the key to on and count “1” out loud. The Alarm LED will come on and
    then go off.
    11)As soon as the LED goes off, turn the key from on to off and back to on in
    less than 2 seconds and count “2” out loud.
    12) Repeat the key cycles and LED cycles until the count reaches 10 cycles.
    13)After the 10th cycle, turn the key back on and the LED should start flashing.
    14) Press the red fob button until the LED accelerates its flashing and then stop
    pressing the red fob button. The LED will resume flashing slowly.
    15) Press the first black fob button and the LED will again accelerate its flashing.
    Stop pressing the black fob button and the LED will resume flashing slowly.
    16) Press the second black fob button and the LED will accelerate its flashing one
    last time. Stop pressing the second fob button and the LED will stop flashing
    completely.
    17) The Alarm ECU is now programmed to recognize all three remote alarm fobs
    and the fobs should be checked to ensure they are operational.
    Note: Reports have been made of the number of cycles of the LED varying from 12 to 20
    or more before the LED started flashing. My Alarm LED flashed on the 11th time
    the key was turned to on, exactly as stated in the WSM extract above.
    Although this process sounds very involved, the actual ECU programming process takes
    less than five minutes from start to finish, assuming you make no mistakes. This is even
    if you are unlucky and have a couple of zeros in your PIN.
    _horatio_ likes this.
  6. Robb
    Robb Moderator
    Feb 28, 2004
    14,336
    Robb
  7. cuneo
    cuneo Formula 3
    2,469
    I like my '95 too, for many reasons aside from these crazy alarm procedures! Glad your car dreams have come true Robb.
  8. ferrari 512 tr
    ferrari 512 tr F1 Rookie
    Nov 16, 2008
    4,180
    Australia
    Paolo
    this thread is top class
  9. wrxmike
    wrxmike Moderator
    Moderator Owner
    Mar 20, 2004
    7,674
    There is a video on youtube that shows how to program the ferrari immobilizer, also start the car with the code.
  10. TrojanFan
    TrojanFan F1 Veteran
    Nov 17, 2008
    5,158
    So. CA & NV
    Peter
    I know that it has been discussed before (I'm to lazy to search) but it there a way to track down the original Alarm ECU pin? I received only one black fob when I purchased the car and had a second cloned by gobble. I would be nice to have the pin for backup.
  11. Steve355F1
    Steve355F1 F1 World Champ
    Aug 26, 2011
    17,160
    Adelaide, South Aust
    Steve
    This is excellent information in the event of a major problem.
    However, I can't believe the amount of over the top drama that the '96+ alarm system generates on this website.
    Mine has never failed me, and has been incredibly simple to own and operate.
    I also don't know any other owner who has ever had a problem with theirs.
    Frankly, I'm sure my dopey Labrador could "get it" after 5 minutes of instruction.
    Change the batteries regularly. Press the button before you start the car if the light is flashing.
    And most importantly, don't **** around with it if you don't know what you're doing.
    The end.
  12. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,664
    South East
    Jimmie
    It's Christmas and even the lazy get goodwill for their honesty !
    Give FNA several hundred bucks and you may or may not get a number that may or may not work
    Or send your ECU to Australia with even more money and they will extract it
  13. StacyB
    StacyB Rookie
    Feb 21, 2023
    3
    Brian Bee
    Has anyone programmed-out the immobilizer all together? I believe there are companies that do this. Is there a plug in reversable solution? Suggestions? Please no lectures on how important it is to have an immobilizer. Where I park NO ONE will touch the car TRUST ME on this one.
    I just want it to start on the key, with no beeps and fanfare and no terror of the fob breaking or not working. Thanks yall!
  14. _horatio_
    _horatio_ Karting
    Apr 25, 2024
    50
    Just got a '95 F355 and love it too! It didn't come with any key fobs though. Did all F355 left factory with a key fob or am I to understand that only models from '96 to '99 came with one?
  15. Robb
    Robb Moderator
    Feb 28, 2004
    14,336
    Robb
    Alarm fobs only came on 96-99
    metal decorative key fobs were sometimes included by the dealer at car delivery to a new owner or owners added them from the merchandise shop.
    Robb
  16. _horatio_
    _horatio_ Karting
    Apr 25, 2024
    50
    Wow didn’t know that! Thanks very much Robb for this clarification. I thought all fobs had been lost during the life of the car. So glad to discover that it actually didn’t come with any. By the way it’s a ‘95 euro specs, I’m assuming that the no-fob-at-delivery rule still applies. Thanks again!
  17. Qavion
    Qavion F1 World Champ
    14,262
    Ian Riddell
    The fobs are only found with cars with Motronic 5.2 engine management systems, although cars with Motronic 2.7 systems (installed on cars from the earlier years) did have some provisional wiring for an immobiliser (which was never used).
    The 2.7 cars have two engine ECUs which can be found in the engine bay and separate intake trunking for each engine bank (no Y-piece).
