Inspecting timing belts in Testarossa | FerrariChat
Discussion in 'Technical Q&A' started by Rossa a nord di, Jul 20, 2008.
  1. Rossa a nord di
    Rossa a nord di Karting
    Apr 30, 2008
    210
    Barrie, Ontario, Can
    Brent Pilon
    Hello
    I just purchased a 1990 TR that runs great but has not had a major service since 1999 (15 000 miles ago).
    My 308 had a triangular wedge missing from one of it's timing belts after being changed 4 years previously.I am terrified of the consequences.
    I am planning on a major service in the Winter (doing it myself....with help), but until then, I was wondering if there was a way to visually inspect the timing belts for signs of wear so that I can drive it for the Summer.
    I am thinking of removing the small covers facing the back of the car to inspect the belts, but these covers will only move an inch or so based on my parts manual. They are the little covers that bolt into the back of the main cam belt covers.
    Is there a way to inspect them without removing the engine, or is it just a chance I take until the major service. Any info would be appreciated.
    Thanks again. Brent.
  2. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Pretty hard to see much in there.
  3. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    If it were mine I wouldnt even try to start it, and I would disable the ignition until the issue was resolved. But thats just me.
  4. jratcliff
    jratcliff Formula 3
    Sep 7, 2004
    1,024
    Texas
    #4 jratcliff, Jul 20, 2008
    I've used a bore scope to look at things I couldn't get to. The problem though I'm not sure I would trust what I was looking at. You would only be able to see portions of the belt and I'm not sure how you would determine if it was good. I would agree with Paul. The cost of the major is a lot less than the cost of an engine rebuild.
  5. FandLcars
    FandLcars F1 Rookie
    Aug 6, 2006
    3,057
    Tempe, Az
    Rick Schumm
    +1... I totally agree. I know you'd like to drive your new purchase, Brent. But what could you see that would convince you that the belt will not break before winter? I don't think there's any way to inspect the entire belt, and even if you could, it's still 9 years old. If it breaks, it would be VERY expensive. For me, it wouldn't be worth the risk.
  6. Rossa a nord di
    Apr 30, 2008
    210
    Brent Pilon
    Thanks for the input.
    On my 84' 308 I can see the belts at the top, I place the engine in neutral with the Right rear tire off and have someone crank the engine on the 36 mm nut and rotate the belts to fully inspect them. I recently changed the belts on it.
    I was hoping that if I could see a portion of the belt, I would crank the engine while in neutral and inspect the belts inch by inch.
    Sounds like wishful thinking. The owners manual for the TR says to change every 30 000 miles and visually inspect every 15 000 miles. I would find it hard to believe that they would pull an engine just to look at the belts without changing them, but maybe I did not fully understand the manual.
    Thanks alot for the advice, I appreciate it.
    Brent.
  7. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    #8 2NA, Jul 20, 2008
    Since that manual was printed, Ferrari has changed their recommended belt replacement service interval to 3 years regardless of mileage.
  8. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    There's two important aspects to the belt. The first is that the teeth are hanging on and won't strip off. You have a slight chance of seeing this with a visual inspection. The other important aspect of the belt is the fiberglass or kevlar strands running through the middle of the belt that give the belt its strength and resistance to stretching. Those don't really lend themselves to an outside visual inspection.
  9. Jagbuff
    Jagbuff Formula 3
    Jan 13, 2004
    2,267
    Site of US F1 Race!
    Franck
    I would be more concerned about the tensioner bearings than the belts ...unfortunately, you can't assess them visually!
  10. Llenroc
    Llenroc F1 Veteran
    5,428
    Colorado
    Vern
    #11 Llenroc, Jul 22, 2008
    That is not true, the teeth of a belt coming off is one of the problems of a fatigued belt, if you loose 1 or 2 teeth that can allow the cams to move enough to cause interference with the pistons.
    There really isn't anyway to effectively inspect a belt with the engine the car. Even if you could the problem that might be there doesn't show itself visually until maybe a 1000 revolutions later, when your not looking at it, and old belt is an old belt I would never rely on a visual inspection. It seems these belts look great or are broken no in between.
    It is not like the old fan belt days when you could visually see a belt gradually going bad and then replace it when it was down to a couple of threads hahaha. And if you didn't and it broke what was the worst that could happen?... the alternator light comes on. I would rather change the belts now vs. pulling valves out of pistons later.
  11. Brian Harper
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    I agree with what you wrote. What part of my quoted material do you think is not true?
  12. parkerfe
    parkerfe F1 World Champ
    Sep 4, 2001
    12,887
    Cumming, Georgia
    Franklin E. Parker
    Only to increase profits for its dealers...as long as the car is driven regularly, the cam belts and tensioner bearings should last 10 years and 50k+ miles...
  13. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    We've been down this road endlessly.
    I suspect that Ferrari made the recommendation change to keep the "blood-sucking lawyers" off their backs. ;)
    The bottom line here, this car is overdue for a belt service even by your standards.
  14. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    I remember many many years ago strolling through a junk yard in the early 80's when Fiats were still very popular. I can still recall a row of Fiats and Yugos (Yugos are the same car, same engine). Out of approximately 40 cars, well over 2/3 of them had a shreded belt, with no other outward signs of any other damage to the car. Anyone who was around back then turning wrenches on that stuff know's the belts on those cars were a critical issue. And of all the things that pushed Fiat out of the USA, I believe those belts could have been a big factor.
    To recap, starting in the early 80's the US EPA required all motor vehicles to carry a 5 year 50K mile warrantee on emission control equipment, and the belt was considered an emissions part. I dont know why Fiat and Ferrari kept on using the (by then) antiquated belt they were using, instead of following the rest of the world and moving to the HTD design, but they didnt. And the fact is, that old style belt is the cars weakest link.
    Some of you guys really have your head buried in sand to expect that belt to perform to the EPA's requirement, or romanticising Ferrari simply trying to make a buck. The EPA arent engineers, and Ferrari arent the evil car company. Fiat said 30K on thier belts back in the early 70's, and to my knowedge it never changed. I have no clue why so many of you persist in pushing this issue. Broken belts and broken engines dont help anyone.
  15. gblogger
    gblogger Formula 3
    May 2, 2004
    1,612
    N.E. Florida
    Gee Blogger
    ^^^^^^^^^^^^^^^^ Toyota, Chrysler, VW and Chevy recommendations for belt replacement are from 100-120,000 miles.
  16. mrpcar
    mrpcar Formula 3
    May 27, 2007
    1,114
    Chino hills, CA
    Robin
    Toyota, Chrysler, and Chevy all uses timing chain as far as I know. I think the belt they are referring to is the serpentine belt. Even with the serpentine belt you should replace it at 60k miles.
  17. gblogger
    gblogger Formula 3
    May 2, 2004
    1,612
    N.E. Florida
    Gee Blogger
    #18 gblogger, Jul 23, 2008
    Nope, not for all models. I replaced mine at 54K when my waterpump went. It was recommended at 100-120k miles, but for just the cost of the belt, it saves doing the same work later. It was a belt, a timing belt, which is the discussion of this thread. A serpentine belt is like the old style a/c, alternator, p/s pump belt......for turning accessories.............a different issue entirely.
  18. Brian Harper
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    Toyota, Chrysler and Chevy all make/made cars with timing belts. A incomplete sample:
    Toyota - Tercel, Avalon, RAV4, Camry, Celica, Carolla, Cressida, Highlander, MR2, Paseo, Sequoia, Solara, Tundra (these vary by year, some years belt, some chain)
    Chrysler - New Yorker, Neon, K-Car (eeek!), 3.0L V6 enignes (includes a bunch of mini vans)
    Chevy - Aveo, Metro, Nova OHC, and some Chevy engines have both a belt AND a chain (S-10 apparently)
    So now you know different.
  19. FandLcars
    FandLcars F1 Rookie
    Aug 6, 2006
    3,057
    Tempe, Az
    Rick Schumm
    On my 348, I feel a key advantage of doing belts more often is that you also have the opportunity to inspect other things such as belt and oil pump chain tensioners, and also have an easier time adjusting valves, replacing seals, etc. etc. I understand that paying a dealer for these services is expensive, and so some may want to put it off as long as possible. But fixing things after parts have failed can get much more expensive than preventive service costs.
  20. Llenroc
    Llenroc F1 Veteran
    5,428
    Colorado
    Vern
    Sorry Brian, I was reading your post(#9) as if you saying that teeth don'/can't get stripped off. My response was saying that they can. If I miss read I apologize.
  21. mrpcar
    mrpcar Formula 3
    May 27, 2007
    1,114
    Chino hills, CA
    Robin
    My bad, you are right Toyotas do have timing belt in some of their cars come to think of it I had a Toyota Supra one time, and it uses timing belt. Now I remember why I never worried about the timing belt in my Supra, it is a non-interference motor, so if the belt breaks no damage to the valves. I wonder if the Chrysler and Chevy are the same non-interference design, this would make sense to not to worry about changing the belt so often.
  22. PAP 348
    Dec 10, 2005
    100,199
    Mount Isa, Australia
    Pap
    #23 PAP 348, Jul 24, 2008
    Lol! :p:p
  23. Serpent Driver
    Serpent Driver Formula Junior
    Jul 4, 2004
    324
    Norway
    I would not be to concerned about the bearings because they have only been there for 15.000 miles, and they don't "age" like the rubber in the belts
  24. thecarreaper
    thecarreaper F1 World Champ
    17,967
    Savannah
    sorry, but i would not have bought the car in the first place, if you cannot either do the major RIGHT NOW yourself, or just pay to have it done and factor it in to the price of ownership. pinching pennies and trying to wait until winter with a $25,000 engine explosion waiting to occur is foolish to me.
    a 308 engine rebuilt from t rutlands is around $15-$18k, if you have a good core.
    figure a used, not rebuilt TR engine is $25k, and a transaxle with the 512 Tr mod is another $15k, plus gaskets, fluids and assuming you are doing all of this work yourself.
    no disrespect, but if you got the Tr at a better price because the major was due, then pay the piper and have it done ASAP, so you can enjoy it, or mothball it and do the work this winter.
    i could care less about the toyota / domestic car timing belt service life. that has nothing to do with how these ferrari engines work, and the vibrations and stresses these engines are under. i have had 140+ cars, and comparing jap and domestic mass produced service intervals to ferrari is utterly ridiculous.
    i have thousands of hours of training on Rolls-Royce Spey and Tay turbine engines, having been with Gulfstream for 10+ years now. you cannot mix and match manufactures service standards.
