Instabile gauges, bleeding issues 308 | FerrariChat
Discussion in '308/328' started by Andreas Engesvik, Aug 20, 2024.
  1. Andreas Engesvik
    Mar 4, 2020
    148
    Oslo, Norway
    Andreas Engesvik
    My 77 dry sump overheats - and I am familiar with all the fantastic instructions, around bleeding the system, that I have have found here (Birdmans) and so on! I am bleeding, changing rad caps etc. Last night the car was running in the garage and I noticed that the water temp dropped - 5 - 10 degrees celsius when I turned off the main lights? After a short drive yesterday I also checked the surface temp on the engine with an IR lamp - the termostat housing was 65 - 70 degrees celcius - and the gauge showed 100 degrees celcius? Greatfull for insights here.
    JuLiTrO likes this.
  2. Steve Magnusson
    BANNED Lifetime Rossa
    26,822
    #2 Steve Magnusson, Aug 20, 2024
    This is a little bit "normal" -- when the dash lights are "on", the ground signal at the gauges goes up a little because the wiring for the gauge ground is not a large gauge wire and/or its connection to the chassis might be a little corroded (and the dash bulbs share the same ground wire). You should see the same thing with the oil pressure gauge for lights "on" vs lights "off". If the needle movement is more than a needle width, or so = maybe justifies cleaning the ground for the gauges or adding another ground wire in parallel for the gauges.
    This is not so normal, but IR guns aren't super-accurate (although the have great resolution which conveys a false sense of accuracy ;)), and the emissivity of the surface measured affects the measurement. One thing you can do is do a search on "104628" (the part number for the thermister that senses the coolant temp for the gauge). It's used on many, many F models, and I know that others have posted temperature vs resistance data for this 104628 thermister so you could check that (like in a pot of boiling water), or just buy a new one to see if it makes any difference (I think it's not super-expensive).
    Andreas Engesvik likes this.
  3. offtheworkigo
    offtheworkigo Karting
    Feb 23, 2016
    237
    Rockwall
    Dave Hoffer
    My temperature gauge acts a little funny. Most of the time my gauge runs slightly below the 90 Celsius mark but once in a while, it will climb up about 110. If I tap on the gauge a little bit hard, it just quickly returns back to about 90 Celsius. Do you think that’s a ground problem or something wrong with the gauge? Anybody else have that problem or try tapping on your own temperature gauge and see it it moves it climbs above normal. Also what do you consider running too hot? 85 Euro 308
  4. Andreas Engesvik
    Mar 4, 2020
    148
    Oslo, Norway
    Andreas Engesvik
    thanks for your insights! I have ordered some parts from England - and a EZbleed - screw, if that doesn't work I will try to flush the entire system.
  5. Andreas Engesvik
    Mar 4, 2020
    148
    Oslo, Norway
    Andreas Engesvik
    So easy to change the thermostat - and I have been bleeding like a mad man;). It has been very irratic - opening half way - not opening etc. I also found the reason for a change in the sound from the standard exhaust - will try a quick fix and then get it welded this winter. I like the standard exhaust and that is not so noisy!
  6. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,871
    Mike 996
    There is no magic or weird maneuvering required to bleed a PROPERLY functioning cooling system. When the cars were in production, owners were not taking them to the dealer every few weeks/months to have the cooling systems bled. If it needs bleeding between coolant changes, something is wrong in the system.
    Rifledriver and Andreas Engesvik like this.
