Installation of sliding window rubber seals | FerrariChat
Discussion in '365 GT4 2+2/400/412' started by Cazna, Nov 2, 2015.
  1. Cazna
    Cazna Karting
    Aug 6, 2013
    72
    Sydney, Australia
    Robert
    Can anyone suggest or recommend the best way to install the sliding window profiled seals on the two front doors of a 365 GT4 2+2?
    Is there a You Tube or similar site I can see what is best?
    I've secured the proper profiled rubbers but need help on the install.
    Thanks in advance.
  2. theobordeaux
    theobordeaux Formula Junior
    Jan 13, 2011
    482
    Bordeaux (France)
    Theodore
    Hi Robert, drag them into the slot reserved for them is difficult. I solved the problem by cutting into two slides. First I introduced the lower one inside the door and then the top one. the door panels must be removed.
    Theodore
  3. Ak Jim
    Ak Jim F1 Veteran
    9,638
    North Pole AK
    Where did you get these?
  4. Cazna
    Cazna Karting
    Aug 6, 2013
    72
    Sydney, Australia
    Robert
    Hi Theo, A local parts supplier in Sydney has them and well as Lyle Tanner in USA.
    Are you after both sides as I may be able to supply a spare set I have?
  5. bundas
    bundas F1 Veteran
    Dec 31, 2005
    7,090
    lexington ky usa
    mitchell barnes
    I sure need those seals. that is the only thing I have not found. please post a photo of what you are using and a part number. thanks
  6. theobordeaux
    Jan 13, 2011
    482
    Bordeaux (France)
    Theodore
    "Are you after both sides as I may be able to supply a spare set I have?"
    Sorrrry Robert, I don't undestand that you say
  7. willrace
    willrace Three Time F1 World Champ
    35,088
    North Tay-has
    Kurt
    #7 willrace, Nov 3, 2015
    Are these the seals on the outside of the window frame that seat against the door opening, or those inside the window frame in which the window slides?
    Pic of the first (which is what I'm trying to find for both 400GT and similar for the 512BBi):
  8. bundas
    bundas F1 Veteran
    Dec 31, 2005
    7,090
    lexington ky usa
    mitchell barnes
    #8 bundas, Nov 3, 2015
  9. willrace
    35,088
    North Tay-has
    Kurt
    Mitchell, that looks about like what I need.
    Not sure that's what the original post was about, but it might be. Cazna, could you confirm one way or the other, please?
  10. SouthJersey400i
    SouthJersey400i Formula 3
    Mar 14, 2007
    1,679
    Romulus, NY (Finger Lakes)
    Ken Battle
    He sells all of these rubber parts; gets them from Italy. Quality is good and priced reasonably, especially those that he can buy a continuous length and sell by the foot.
    Ken
