Installing cruise control on Mondial t, 348 | FerrariChat
Discussion in 'Technical Q&A' started by ProCoach, Dec 2, 2006.
  1. ProCoach
    ProCoach F1 Veteran
    Sep 15, 2004
    5,465
    VIR Raceway
    Peter Krause
    Ok fellows, I know I'm going to take a bunch of "stick" for putting this thing on my Mondial t Coupe, but I'm going to Savannah this week and I need to install this thing bacause I'm tired of my right shin cramping up on drives longer than a couple hours.
    I bought a Rostra electrically actuated servo system with a control panel I have put in my ash tray and I have no problems installing all of that. I can install a magnetic pickup sensor on the rear outer CV joint to generate a speed sensor signal if I have to, but I'd rather the solution be more elegant.
    I'm looking for information on how to identify the VSS (vehicle speed sensor) wire, I assume from the speedo sender to the cluster. The Rostra documentation states the pulse can be either a square wave or a sine wave.
    If anyone has worked through this or has any ideas in short order, pipe up!
    Thanks, Peter
  2. Miltonian
    Miltonian F1 Veteran
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    Briefly, the speed sensor (on a 348) is on the transmission case next to the left inner CV joint. It has two wires, with a plug next to the sensor. The wires run through a multi-pin quick disconnect fitting near the top of the left rear shock. I'm not sure if the Mondial T is exactly the same.
    I have never used the cruise control function on any of my cars, but I know that some people find them useful and convenient, so no "stick" from me.
  3. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Sounds like a great project!
  4. ProCoach
    ProCoach F1 Veteran
    Sep 15, 2004
    5,465
    VIR Raceway
    Peter Krause
    Thanks, Jeff. I was just wondering which of the two wires at the pickup was the VSS wire. It is the same for the Mondial t as for the 348 (and I assume the 355).
  5. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Jeff did a write-up on that some time ago that seems to point to the VSS as your red/white wire from what I can tell: http://www.the348.com/tech/348.html#Speedometer
