Installing F430 Capristo Headers / Manifolds | FerrariChat
Discussion in '360/430' started by fezza, Aug 5, 2015.
  1. fezza
    fezza Rookie
    Nov 23, 2004
    46
    North East - UK
    Andy
    #1 fezza, Aug 5, 2015
    I've Just completed fitting Capristo headers to my 2007 F430 coupe.
    Just a couple of pointers which may help fellow members choosing to also fit themselves.
    My new header were full of some sort of compound, possibly polishing compound so I did spend a good 45 minutes cleaning them out to avoid blasting it into the primary cats.
    Sadly no instructions supplied by Capristo and I spent an hour or so trying to pass the left hand header through the gap between the chassis and engine as this is the route I took the original headers out. This proved impossible! I read all sorts of stories about jacking up the engine and gearbox and removing compressors etc. I did none of this. Very simply I just removed the plastic inner wing and the fuel tank heat shield and passed it straight in through the rear wheel arch (see pic).
    Once in position it's important that all nuts are tightened up evenly a few turns at a time. See the pic of the only tools I used to install the new header to cylinder head nuts. I did use a few more tools for removing the original headers (they are well documented by Aldous Voice). If you need any advice drop me a message.
    Finally, does it sound awesome? Hell bloody yeah!
    I'm very happy with the investment/insurance and enjoyed fitting:)
    Joe430, QSA and jerbear27 like this.
  2. fezza
    fezza Rookie
    Nov 23, 2004
    46
    North East - UK
    Andy
    I haven't included any pictures of the heat blankets but they are fitted along with the Capristo exhaust brackets :)
  3. Perkins
    Perkins Formula Junior
    Dec 22, 2013
    702
    Sacramento
    Rick
    Congrats on the install and thanks for the photos.
  4. f355spider
    f355spider F1 World Champ
    18,044
    Looks awesome...correct four into two, into one design. ;)
  5. RonnieRenaldi
    RonnieRenaldi F1 Rookie
    Aug 16, 2004
    2,686
    Video please :)
  6. ncm6cabrio
    ncm6cabrio Formula Junior
    Jul 28, 2011
    303
    Fayetteville, NC
    Mike M.
    Great info! This is on my list for next spring!
  7. blackbolt22
    blackbolt22 F1 Veteran
    5,808
    Boca Raton, FL
    Mr. Anderson
    Did you keep the rest of the stock exhaust? How much louder/better sound than stock headers? Any problems at highway cruising speed? I don't want it too loud.
    I'm thinking of making this change also.
  8. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,268
    Mel
    Great write-up, THANX ... but there may come some Q's ... :) Any gaskets renewed too ... oem or Capristo ? Did you exchange the nuts for new ones ?
    Can we see photos of the end result (blankets on etc ?)
  9. fezza
    fezza Rookie
    Nov 23, 2004
    46
    North East - UK
    Andy
    Yes I replaced the manifold to head gaskets and all new nuts with genuine Ferrari. New doughnut gaskets connecting up to the cats come with the manifolds. I'll try and sort a picture with the blankets :)
  10. martiy1971
    martiy1971 Formula Junior
    Jun 2, 2015
    647
    Alberta
    Robert Martineau
    need sound or video clip asap!!
  11. DJSHIP
    DJSHIP Rookie
    Jul 9, 2018
    4
    Just completed Capristo header install on 2005 Berlinetta. Stock cats and S line exhaust, no valves.
  12. Cairndog
    Cairndog Rookie
    Jun 6, 2021
    15
    Scotland
    Iain Cairney
    I wish I had read that two hours ago. Thanks for the advice, much appreciated and god bless Ferrari Chat.
  13. gonigon
    gonigon Rookie
    Aug 11, 2022
    15
    Galicia, Spain
    Gonzalo
    Hello everyone,
    To avoid creating a new post I try to writte here trying to find more info about this topic.
    I am 90% decided to change my OEM manifolds for Capristo ones.
    I would like to know experience with heat blanket and manifold over the years (any problem).
    Some advice if it´s better to install first the manifolds and then the heat blanket, or put everything together.
    Thank you so much for your answers,
    Best
  14. DJSHIP
    DJSHIP Rookie
    Jul 9, 2018
    4
    Have had no problems with the Capristo headers and heat blankets. The blankets have no deterioration after 8,000 miles of use. The heat blankets are easily installed after the headers are bolted in place.
    Previous other headers and heat blankets (not Capristo) I installed resulted in the heat blankets turning to powder in less than 1,000 miles.
    gonigon likes this.
