Installing modern fuel injectors in the 465 2.7 Motronic | FerrariChat
Discussion in '456/550/575' started by Dr1ve, Dec 25, 2023.
  1. Dr1ve
    Dr1ve Rookie
    Feb 2, 2022
    20
    Norway
    Ole-Jakob Nilsen
    #1 Dr1ve, Dec 25, 2023
    Hi all!
    This winter I've decided to upgrade the injectors in my 456.
    I had the original Bosch EV-1 injectors tested at a mate's workshop and discovered that 10 out of 12 fuel injectors weren't delivering enough fuel.
    I could have refurbished the injectors, but instead I started looking into replacing them with newer and more modern injectors. It's been 30 years now since the car was new and technology has progressed quite a bit since the car was produced. I'm hoping that a newer generation injector will atomize the fuel better, giving better performance and better fuel economy.
    I'll post a list of parts and part numbers below.
    New injectors:
    After some research I found out the Bosch 62391 injector from a Chrysler 3.5 V6 has the same flow rate at 240 cc/min.
    The Chrysler injectors are EV-14 style/generation injector. The injector body is much slimmer compared to the EV-1's fat body and they are also much shorter. The electrical connector is also different and will need an adapter.
    A set of 12 cost me less than 400 USD, which is way less than the 1200 USD for a set of new old stock EV-1 injectors for the 456 cost.
    Fixing the fuel pump rubber and check valves:
    I also had some issues with the check valve on the fuel pump leaking and not holding pressure in the fuel rail over time. This was adressed at the same time. New check valves were ordered for a sum of 30 USD each: BOSCH 1 587 010 536.
    After removing the fuel pumps, I discovered the anti-vibration pad underneath the basket was shot. So was the rubber holding the fuel pumps in the basket. New pads were ordered from Eurospares and fuel pump holders were ordered from Fiammenghi in Italy.
    Anti-vibration pad in tank:
    Installing new injectors:
    So on to the point of installing the injectors.
    As mentioned earlier, the new injectors are shorter and need to be lengthened by 14 millimeters. I ordered a set of 12 short injector top hats from Speedingparts.eu .
    I had also purchased a set of 12 USCAR (injector) to EV-1/Jetronic (engine wiring) wiring adapter. Initially this was a short type, but turned out this didn't work out due to the adapter fouling the intake manifold. I therefore needed to get another type of adapter with wires, which was more flexible.
    Installing the injectors was straight forward, just make sure to lube all the o-rings.
    Engine started easily and ran perfectly. Throttle cable had to be adjusted and the intake had to be balanced, but that was on the to-do list before starting on the injectors. I have yet to test this set-up on the road, but that will have to wait because winter conditions.
    Don't use these electrical adapters:
    Old injectors:
    Size comparison:
    New electrical adapter:
    Installed on the engine. I admit the wiring could've looked better. I would've been as well if I could use the shorter adapter for the electrical socket.
    Engine balancing.
    Parts:
    Injector parts
    Injectors: Bosch 62391
    14mm Injector spacer
    Electrical adapter EV6 to EV1
    Fuel check valve: BOSCH 1 587 010 536
    Fuel pump support
    scowman and Qavion like this.
  2. Dr1ve
    Dr1ve Rookie
    Feb 2, 2022
    20
    Norway
    Ole-Jakob Nilsen
  3. Qavion
    Qavion F1 World Champ
    13,780
    Ian Riddell
    When I was looking for alternative injectors for my F355, I started to worry about spray pattern. I don't really understand how it works on my car. I assume the fuel is atomised before it hits the intake tract walls as the injectors point directly at them.
    Looking at the image, it seems that if the spray pattern was too wide, most of the fuel will end up on the intake walls. Perhaps it depends on the incoming airflow.
    I don't know if the setup is the same on the V12s.
    I gave up looking because I couldn't find the same flow rate and because of unknown spray patterns. How many holes do the OEM injectors have. Are the new ones the same?
    epb0 likes this.
  4. Dr1ve
    Dr1ve Rookie
    Feb 2, 2022
    20
    Norway
    Ole-Jakob Nilsen
    The OEM has 4 holes that directs the fuel towards both intake valves. The new injectors have the same.
    The fuel is atomised immediately when exiting the fuel injector.
    Choosing a injector with a larger flow rate could lead to cylinder wash, due to over fuelling. However a newer ECU should be able to compensate a slightly bigger injector based on lambda values.
  5. Qavion
    13,780
    Ian Riddell
    Interesting. Thanks.
    On my F355, the adjustment limit is about 10%, but I believe lambda values are only valid during closed loop operation (when the car has warmed up) and not when the car is warming up or during wide open throttle. At these times, the car relies on airflow data and ECU tables.
  6. Dr1ve
    Dr1ve Rookie
    Feb 2, 2022
    20
    Norway
    Ole-Jakob Nilsen
    That sounds about right with the 10%. I did have a look at some bigger injectors at Summit Racing, but backed out from that idea.
    That's when I found the 240cc injectors which are the same as the OEM ones
    Qavion likes this.
  7. Timmo
    Timmo Formula Junior
    Aug 26, 2017
    631
    Continental Europe
    Interesting. My 550 has 4 holes too but my F355 (2.7) is the previous generation with what seems like a needle valve, and I would have thought that the earlier 456 with the Motronic 2.7 used the same injector technology, but no.
    On another car I replaced the original Bosch EV1 injectors with EV14 units (along with the ECU) and have not noticed any adverse effect from the change in spray pattern, for what it's worth.
  8. Dr1ve
    Dr1ve Rookie
    Feb 2, 2022
    20
    Norway
    Ole-Jakob Nilsen
    You're probably correct about any adverse effects from the changes.
    On another note, I have gotten all new injectors for a fraction of the cost of new OEM injectors!
