Installing rear side window | FerrariChat
Discussion in '206/246' started by pshoejberg, May 20, 2016.
  1. pshoejberg
    pshoejberg Formula 3
    1,827
    Denmark
    Peter H
    #1 pshoejberg, May 20, 2016
    Gents, help is needed again! I'm just about to install the rear side windows and would like a simple "how to do" instruction. I have the following parts ready and just need the correct running order for how the parts should be installed:
    1. Window glass
    2. upper / rear chrome frame TAV111-13
    3. Bottom chrome list TAV111-15
    4. Vertical B-post polished stainless steel list TAV111-17
    5. 3/4 surrounding rubber gasket TAV111-19
    6. Bottom gasket TAV111-14 (Black rubber Sealant)
    7. Vertical U-profile rubber edge for B-post polished steel list 9x5x2 mm TAV111-16
    8. Vertical 10x15 mm foam profile TAV111-18
    Thanks in advance
    Peter
  2. pshoejberg
    1,827
    Denmark
    Peter H
    #2 pshoejberg, May 22, 2016
    For reference: Did the install by using the "trial and error" method and figured out that the following assembly order works very well:
    1. Window glass
