Instrument Panel Question | FerrariChat
Discussion in '360/430' started by cfasullo, May 18, 2014.
  1. cfasullo
    cfasullo Karting
    Aug 18, 2013
    55
    #1 cfasullo, May 18, 2014
    Any idea on how to resolve this to bring it somewhere in the middle and is safe to drive the car? Sorry i dont know anything about cars and i know its a rookie question. Thanks in advance!
  2. BrettC
    BrettC Formula 3
    Aug 13, 2012
    2,117
    Calif
    Brett
    WELL, the gauge shows oil temp way too high...is the coolant high also? can't see that in your pic. If it is high also don't drive it, if only the oil temp, check oil level and don't drive it....better to see if it just the gauge or not before damaging anything. Oil pressure looks ok at idle.
  3. London
    London Karting
    Aug 29, 2009
    189
    London
    Is your low oil pressure light ON? It should not be on, even at idle.
  4. mello
    mello F1 Veteran
    5,493
    CA Bay Area
    Steve
    You need to post more pictures of the status of the gauges in order for us to get a better understanding of your problem.
  5. English Rebel
    English Rebel Formula 3
    Aug 13, 2013
    2,158
    Piedmont Area of NC
    Alan
    If I'm not mistaken Ferrari use the same sending unit for both the water and oil so both have been known to go bad and send false readings. However as others have said if the water temperature is also high then you either have both sending units going bad at the same time (highly improbable) or you have a problem.
    Alan
  6. vrsurgeon
    vrsurgeon F1 World Champ
    16,544
    Charleston, SC
    Curt
    First... take a deep breath. It probably.. probably.. will not be that bad on the wallet.
    Second. It's probably just a bad sensor. Although, I wouldn't drive it assuming its a just a bad sensor. Can you do work on it yourself? You can check the oil pressure sender behind the oil filter. The oil temperature sender is on the drivers side of the car below the oil filler. Does it do this immediately when you start it?
    If you don't know where the oil filter is (just being facetious).. just bring it in. It probably something simple.
  7. cm2
    cm2 Formula 3
    Sep 26, 2012
    1,451
    SF Bay
    Nathan
    Can you explain how you were using the car before the picture?
  8. cfasullo
    cfasullo Karting
    Aug 18, 2013
    55
    #8 cfasullo, May 26, 2014
  9. mikeyr
    mikeyr Formula 3
    Jun 17, 2004
    2,154
    Santa Barbara, CA.
    Mike Rambour
    since the oil pressure is normal and more importantly the water temperature is normal, I am going to vote for a bad sending unit, should be cheap and easy to replace (UNLESS its some where deep in the car that requires removal of a lot of stuff).
  10. up4speed
    up4speed F1 Rookie
    3,697
    Long Island, NY
    Chris
    Based on your gauges, and nothing else, I'm going to agree with Mike that it's "probably" a bad sending unit. I would say that it definitely is a bad sending unit (or bad gauge), but unless it is tested I can't be sure so I don't want to give you bad advice.
  11. English Rebel
    Aug 13, 2013
    2,158
    Piedmont Area of NC
    Alan
    #11 English Rebel, May 27, 2014
    If I'm not mistaken it's item 83 -- listed as an oil thermistor and it looks to be easy to get at it although it seems as if it's on the transmission -- someone else chime in.
    Alan
  12. vrsurgeon
    16,544
    Charleston, SC
    Curt
    Alan is correct above. #83. At like $20 from ricambi, I'd buy one and unplug it without unscrewing the old one from the engine. Then, I would take the plug and connect it to the new one, with the old one still screwed into the engine. Turn on the car. If the oil temp needle remains on "0", you've found the solution. If it jumps back up.. its possibly the gauge or the wiring harness (in which case keep the part, its good to have anyway). Either way you've got a $20 diagnosis.
    To get at it looks like its on the drivers side of the car, if you reach down in front of the air box and under the shield by where the rear axle meets the transmission, it should be there.
  13. cfasullo
    cfasullo Karting
    Aug 18, 2013
    55
    I forgot to mention that i have mismatching ecu's so that can be why it is reading it wrong?
  14. rustybits
    rustybits F1 Rookie
    Jan 28, 2007
    2,509
    Somewhere, anywhere
    Eddie B
    Likely the sender, it lives in the transmission just back from the starter. Also check the wiring, the black cable for the sender passes through the starter support bracket and can go to ground, which will also cause that reading. You need to drop the under tray for access.
