Instument panel lights (308) | FerrariChat
Discussion in 'Technical Q&A' started by Pizzaman Chris, Feb 5, 2006.
  1. Pizzaman Chris
    Pizzaman Chris F1 Rookie
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    #1 Pizzaman Chris, Feb 5, 2006
    Hi everybody,
    I'm changing the lights on my panel using the directions from FCA site. Everything went smooth taking apart. But the 4 lights they're talking about are they the ones in all 4 corners where the 4 screws where? All i see are those 4 plus 1 (in the picture it's in the top middle of wheel section) I don't see anything on the speedo or tach. Plus the bigger bulbs (3893) don't match anywhere. Any help. Thanks
  2. f355spider
    f355spider F1 World Champ
    18,045
    The bulbs you are changing are in the speedo and tach...not the warning lights in each corner.
    Search the archives for more info...but is should be pretty self explainatory...
  3. spiderseeker
    spiderseeker Formula 3
    Jul 22, 2005
    1,718
    Colorado
    Steve
    I think the yellow wires are for the lights in the speedo and tach, look for them.
  4. Kingpin328
    Kingpin328 Formula Junior
    Nov 7, 2003
    433
    #4 Kingpin328, Feb 5, 2006
    I never bothered myself with the panel-illumination while in there (stupid, stupid me) but perhaps this pic is of any help .....
  5. Pizzaman Chris
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    #5 Pizzaman Chris, Feb 5, 2006
  6. tomberlin
    tomberlin Formula Junior
    849
    Bethesda
    tom berlin
    I sent the speedo and tach to Palo Alto Speedo Repair to get the lenses cleaned- well worth it. Brighter bulbs, bypassed the rheostat, and it looks like what I'd call a normal cluster at night now. What a pleasure.(78 308)
    They also calibrated the speedo.
  7. M.James
    M.James F1 Rookie
    Jun 6, 2003
    2,721
    Worcester, MA
    Michael.C.James
    I found the following post to be very helpful:
    http://www.ferrariclub.com/faq/dashlights.html
    My only problem is that the four-corner panel lights (the ones you pull out to get to the screws within the binnacle) are VERY loose, and required rubber cement/electrical tape to re-mount the the instrument panel so the plastic lenses rest flush with the instrument panel. If you don't, they just pop out and dangle there like christmas ornaments.
  8. enjoythemusic
    enjoythemusic F1 World Champ
    Apr 20, 2002
    10,676
    Worldwide
    Steven
    Agree. Must say the brighter bulbs are good, but BYPASS THE RHEOSTAT is key. i cleaned mine rheostat with top quality cleaner (Caig) and felt it should be good. WORNG, the stock rheostat stinks so just bypass it.
  9. tomberlin
    849
    Bethesda
    tom berlin
    Rheostat was sucking up 2 volts.
