intake mainfold | Page 2 | FerrariChat
intake mainfold
Discussion in '348/355' started by DailyDrivenExotics, Nov 4, 2018.
  1. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,060
    Indio Ca/ Alberta
    Grant
    Just me but not sure you can trust the Hong Kong one be cause I have seensome pretty cool stuff come out of there which was not factory.
    I got a good friend over there and I thinkthey just tell us all that to make us jealous. Ha ha
    Dave rocks likes this.
  2. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,643
    Elliott Caras
    No these are factory. Confirmed via a experienced tech here as well that UK cars have cast plenums.
    Here is a link to some for sale: again from the UK. http://vi.raptor.ebaydesc.com/ws/eBayISAPI.dll?ViewItemDescV4&item=291709857695&category=36474&pm=1&ds=0&t=1541392113420&cspheader=1
  3. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,060
    Indio Ca/ Alberta
    Grant
    I bet the originals were cast and then the cheapened them up to plastic.
    Thats too cool
  4. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,643
    Elliott Caras
    I think so too. They are identical in every way and you would not be able to pick it unless you scratched the paint off to reveal the metal or you removed and felt the difference. They are much easier to refinish the metal too. You can sand back the stripes for a nice finish of exposed metal.
  5. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,060
    Indio Ca/ Alberta
    Grant
    Maybe the plastic ones stay a little cooler, nit sure but I had my car for 5 years before I did the first major and I thought they were aluminum that whole time.
    Sneaky buggers
    DailyDrivenExotics likes this.
  6. DailyDrivenExotics
    Nov 1, 2018
    19
    beverly hills
    Alex Choi
    I'm just going to sand it some tomorrow and paint it a high gloss black again.
  7. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,060
    Indio Ca/ Alberta
    Grant
    I thought mine was more of a flat,black
    What are others saying
  8. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,643
    Elliott Caras
    Paint it in VHT wrinkle or a heat proof flat/semi black
  9. SeattleM5
    SeattleM5 Formula 3
    1,267
    Kirkland, Washington
    Ettore Palazzo
    I attempted this method but after a couple of tries with different types of foam rollers I couldn't get the fins distinct enough for my liking (I clearly don't have the same painting skills as Dave!). I ended up masking everything off and spraying which was time consuming but I was pleased with the end result.
    Streetsurfer likes this.
  10. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    The motor in that photo is a later car though, it has the vacuum pump on the LH cylinder head.
    Agreeded - VHT wrinkle black
    Looks great, Ettore :)
  11. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Or made from plastic to reduce weight ;)
  12. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,859
    Lake Villa IL
    Interesting! Do you know if the lower half that attaches to the throttle bodies is aluminum as well?
  13. Enzojr
    Enzojr F1 World Champ
    Dec 12, 2013
    14,001
    West of PDX
    Tomy
    Check all the hoses that go into this tank (post #6) they can become clogged after 20 years.
    They are the small black ones about the size of a pencil.
  14. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,774
    phrogs likes this.
  15. kenneyd
    kenneyd Formula 3
    Sep 30, 2014
    2,037
    NE FL
    Ken
  16. kenneyd
    kenneyd Formula 3
    Sep 30, 2014
    2,037
    NE FL
    Ken
  17. F355Bob
    F355Bob Formula 3
    When I did my rebuild last year, I wanted the intakes to look like the casting on the throttle bodies. I always hate tge stock look of plastic. Look at older newer Ferraris and most are metal. The body shop sprayed a primer thst simulated tge cast look and painted over it. If you touch the Image Unavailable, Please Login intakes you would swear they are metal
    kenneyd likes this.
  18. kenneyd
    kenneyd Formula 3
    Sep 30, 2014
    2,037
    NE FL
    Ken
    I find it interesting that there is a fine line between hideous,( like the gloss red picture I posted 2 above) and tasteful awesomeness..., of course IMO
    I also used the krinkle valve cover paint on just the intake manifolds , I think it gives the engine bay what it was lacking from other models.
    DailyDrivenExotics and F355Bob like this.
  19. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,060
    Indio Ca/ Alberta
    Grant
    Just dont know if i like anything other than the original at this point but like all of you overtime things can change.
    Next fav is kens though kinda like the 360 and after.
  20. kenneyd
    kenneyd Formula 3
    Sep 30, 2014
    2,037
    NE FL
    Ken
    There is another member here developing a different manafold option usually found on the newest ferraris, I won't steal his thunder other than to say, they are absolutely amazing. Maybe he will post
  21. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,060
    Indio Ca/ Alberta
    Grant
    I myself am working on a carbon fibre but likely wont be for production
  22. DailyDrivenExotics
    Nov 1, 2018
    19
    beverly hills
    Alex Choi
    So I don't want to keep starting threads so I'll just keep posting in here. Maybe I'll try to get an admin to change my post title.
    So I'm just fixing some of the small stuff with the car since I got it.
    Can I change the little foam ring around the blower motor? Also is there something that should be covering the hole so you can't see the blower?
    Also I have looked here and exotic auto recycling for a master cylinder carpet cover but haven't had any luck.
  23. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Contact Ferrparts - I'd be shocked if they don't have one
  24. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,643
    Elliott Caras
    The divertor flap actuator or union might be broken, when you hit the recirculating button on HVAC control the flap should close sealing the outside air. If it doesn’t you will have to replace either the plastic union or the actuator itself as they strip the plastic internal gears.
  25. DailyDrivenExotics
    Nov 1, 2018
    19
    beverly hills
    Alex Choi
    BTW where can I find a 360 airbag? I'm switching out the steering wheel next.
