430 - Intake Manifold Removal to Carbon | FerrariChat
430 Intake Manifold Removal to Carbon
Discussion in '360/430' started by fstbiker, Dec 23, 2024.
  1. fstbiker
    fstbiker Formula Junior
    Jun 28, 2012
    510
    New Jersey
    I'm going to swap my standard intake manifold with a Carbon Scud version. Does the Rotating drum swivel connection just pop off, looks like it does? Its the one on the rear that goes to the actuator. Also the hose connections in the front of it under the intake holes has one extra than my standard 430. What would be best to plug that connector.
  2. swc5150
    swc5150 Formula Junior
    726
    Wisconsin
    Scott Calderwood
    Yes, the little ball and socket connection pops off. I used a needle nose behind it and pried it gently.
    flash32 likes this.
  3. jerbear27
    jerbear27 Formula Junior
    299
    CT
    Jeremy
    Takes quite a bit of pressure to pop it off. I used some right angle needle nose pliers that helped with the leverage part and kept me from mangling the metal finish.
    swc5150 likes this.
  4. Sj_engr
    Sj_engr Formula 3
    Sep 15, 2020
    1,621
    San Jose
    dc
    Details a bit fuzzy on my install but I believe I disconnected the plastic actuator first.(hose and bolts if I recall) Then I was able to angle it well such that I did not need any tools and it popped off fine. There were some other horror pics in searches I did where parts got mangled. Good luck!
  5. Pete Schweaty
    Pete Schweaty Formula Junior
    May 21, 2014
    281
    fstbiker likes this.
  6. Mario Andretti
    Mario Andretti Formula 3
    1,777
    Boston
    Does this change has a performance component to it, or is it purely esthetic?
  7. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,958
    The Cold North
    Tom
    Much much easier just to pull the entire unit, and separate on the bench. Plus you will be able to update the lower intake gaskets to the metal ones if they haven't been done yet.
  8. jerbear27
    299
    CT
    Jeremy
    not a bad idea. Also a good time to get the injectors serviced as well as the fuel rail has to come out to do it. Definitely a while you’re in there thing. Marren did a great job with my injectors.
    When I had my plenum repainted, I put the intake runners on first and kept them loose, then put the gasket and plenum on. Once I had it all aligned, I tightened everything down to spec.
  9. ItsAboutThatTime
    Apr 7, 2024
    101
    Arvada, CO
    Shane
    Can I ask where you acquired a carbon intake cover? I would love to do this as well at some point
  10. Sj_engr
    Sj_engr Formula 3
    Sep 15, 2020
    1,621
    San Jose
    dc
    The Scuderia lower intake manifolds are hand polished from the factory. The F430 ones are cast. So unless swapping the lower intake manifolds in also it is just for looks. (maybe tiny weight savings)
    Edit: I think I now recall what I did for the actuator. I unbolted it and then spun it until the end piece came off so I did not have to try and pry off while in the engine bay.
