Intake Plenum: 456 vs 550/575 vs 599 vs F12 | FerrariChat
Discussion in '456/550/575' started by Zedtt, Feb 6, 2016.
  1. Zedtt
    Zedtt Formula Junior
    May 29, 2005
    381
    Southern California
    Terry
    #1 Zedtt, Feb 6, 2016
    See attached images of intake plenums (plena?) from 456, 550, 575, 599 and F12. Observe that the 550/575 is the only series of the modern V12's in which there is a large central plenum. All the other cars have only the lateral plenums feeding through runners direct into the opposite bank. Why did Ferrari design the 550/575 intake that way? What did the 550/575 gain or lose in the design?
    I did see this write-up: https://www.ricardo.com/Documents/Downloads/pdf/wave_intake_system_analysis_ferrari.pdf
    Re: "Additionally, the intake system is
    characterized by 2 quarter-wave pipes (one
    for each bank) upstream of the 2 airboxes.
    These resonators were tuned in order to
    reduce the overall intake noise level."..... BTW I would like to INCREASE the overall intake noise level if you don't mind!
  2. tazandjan
    39,175
    The F133 engine family (550-612 OTO) was Ferrari's first V12 series with dual length intake tract, which upped hp considerably above about 6000 rpm. Took up some space doing it. If you look at cam timing, the 456 and 456M actually have wilder timing, but run out of air at a lower rpm.
    On the later V12s from the F140 family, Ferrari incorporated variable valve timing on the intake and exhaust cams, which effectively increased duration, and still incorporated dual length runners into the system without needing so much space to do it. The F12's Type F140F engine added resonance chambers on the ends of the intake tract for a little free overpressure. The F12 tdf removed them and used basic hot rod techniques, mechanical lifters and a higher rev limit to raise hp again.
    In the future, expect infinitely varying intake lengths to optimize over the entire rev range, similar to what VVT systems do now for cam timing.
  3. au-yt
    au-yt F1 Veteran
    Aug 13, 2006
    5,838
    Burradoo... Actually
    Graeme
    Thanks Taz Interesting insight
  4. Cribbj
    Cribbj Formula 3
    #4 Cribbj, Feb 7, 2016
    Terry, here's one way (and BTW, this used to be a stock 456 intake manifold)
  5. tazandjan
    39,175
    John- Yup, that should do it.
  6. 308 GTB
    308 GTB F1 World Champ
    11,722
    New Jersey
    Barry Wolinsky
    You oughta see her on a road course or a quarter mile
    This little modified ponton has got plenty of style
    She beats the gassers and the rail jobs, really drives 'em wild
    C'mon and turn it on, wind it up, blow it out 550
  7. tazandjan
    39,175
    Barry- Yup, pronounced five, five, oh.
  8. 308 GTB
    11,722
    New Jersey
    Barry Wolinsky
    Gonna save all my money and buy a 550
    Get a helmet and a roll bar and I'll be ready to go
    Take it out to Pomona and let 'em know, yeah yeah
    That I'm the coolest thing around, little buddy gonna shut you down
    When I turn it on, wind it up, blow it out 550
    John will have a 369 :)
  9. 360modena2003
    360modena2003 Formula 3
    Jul 11, 2009
    2,438
    Has this intake been installed on a 456 yet? Any footage of it running?
  10. Cribbj
    Cribbj Formula 3
    360, it's actually going on my 550's engine, which, as Barry suggests below is being punched out to around 366 in3 (5.99 liters), but isn't running yet.
    Barry you're a credit to Ronnie & The Daytonas!
    Now you've got me thinking about badging it as a GTO :)........
  11. 308 GTB
    11,722
    New Jersey
    Barry Wolinsky
    Just a little deuce coupe with a flat head mill
    But she'll walk a Thunderbird like she's standin' still
    She's ported and relieved and she's stroked and bored
    She'll do two hundred and twenty in the top end floored
    She's my little deuce coupe
    You don't know what I got
  12. Zedtt
    May 29, 2005
    381
    Southern California
    Terry
    Wow. Can't wait to hear her!
  13. 2000 456M
    2000 456M F1 World Champ
    Sep 29, 2007
    12,600
    Portland, OR
    Allan
    Will there be any kind of air filtration system? It is gorgeous, but I'd be paranoid about grit getting aspirated into the system.
  14. 308 GTB
    11,722
    New Jersey
    Barry Wolinsky
    She purrs like a kitten till the Lake Pipes roar.
  15. Cribbj
    Cribbj Formula 3
    Allan, I'm planning a set of SS screens on the trumpets for this setup, only for the initial breakin runs on the engine dyno, as the dyno room is pretty clean. After that, these 'Busa TB's will be changed out for a proper Jenvey setup, and if I decide to leave the ITB's open with individual intakes, I'll use individual foam Unifilters or K&N's on them.
    If my preferred engine air flow strategy (MAP+TPS) doesn't work out, then I'll enclose each bank of trumpets in a common air box with a long oval filter, a single inlet and a MAF sensor.
