Intake Port? | FerrariChat
Intake Port?
Discussion in '308/328' started by Imatk, Aug 28, 2024.
  1. Imatk
    Imatk Formula Junior
    May 6, 2007
    769
    So I noticed one of my vacuum lines had come off and split from the intake port.
    I was going to just replace it, but it turns out the thing snakes down into the driver rear wheel well and then into a hole that goes... somewhere?
    There also appears to be a metal piece inside the tube. I'm guessing it's some kind of filter but I have no idea.
    So running down to the parts store to get vacuum hose isn't going to cut it.
    I was hoping someone could tell me what this is for and where I would be able to
    1. find a replacement hose
    2. where the heck does it go and what does it connect to on the other side
    I've included a picture of the port that the hose attaches to, it's on the left side looking from the back of the car.
  2. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,741
    The twilight zone
    It sounds like it might be the vacuum line for the ignition system, those units were driver's side trunk on my QV. That needs to be working for you to have the correct ignition advance at lower power conditions....when its unplugged or leaking you get max ignition advance all the time.
    Imatk likes this.
  3. Imatk
    May 6, 2007
    769
    Do you know where it connects on the other end, or have a part number?
  4. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,741
    The twilight zone
    It you pull up the trunk floor on the left you should find the Marelli ignition boxes, the hose is teed to connect to both boxes iirc
    Imatk likes this.
  5. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,810
    Cerritos, CA.
    Imatk likes this.
  6. Imatk
    May 6, 2007
    769
    It has some sort of metal filament in it... do you guys have the part number for it. I can't find it on any parts site
  7. Imatk
    May 6, 2007
    769
  8. Rifledriver
    37,101
    Does not belong there. It should just be a plain rubber vacuum hose.
    Imatk likes this.
  9. Imatk
    May 6, 2007
    769
    Awesome thank you!
