348 - Intake project discussion | Page 2 | FerrariChat
348 Intake project discussion
Discussion in '348/355' started by Ferrarium, Sep 9, 2023.
  1. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    #26 Ferrarium, Sep 12, 2023
    Lots of issues doing that for sure. Thinking large airbox, probably new intake runners since that's the easy part, 70mm TB, all going to stock air box, some new semi rigid hoses. Literally drop in, no wiring or plumbing or fabrication changes. If you can get the chips flashed that would be good.
    Waiting for TB I bought and I have MAF's so I will measure but I am pretty sure the MAF ID is largesr than that TB ID at least to my eye ball. So a TB with throat the size of the MAF ID or slightly larger is a good starting place.
    Actually I know the 348 TB size, let me go measure the MAF
  2. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    #27 Ferrarium, Sep 12, 2023
    Yep the MAF has 13mm larger ID than the TB. I recall from old TB porting threads that alone got 22% more air.
    Then in you look into the intake (thanks Ernie) you can see the air smacks into the intake runners, no trumpets or anything like the 355 has, it seems if the TB flange had a bigger ID as well as a bugger TB it would be not insignificant.
  3. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    The issue is if you go too big you need EM, the trick is just big enough to increase flow, efficiency, response and some power without having to stick new EM/ECU in. I mean if your putting new EM in like the Maxwell intake needs that they don't bother telling you, like Kevzep wans to do then hell ya.. dual 102mm TB's!
  4. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    SoCal LA/OC/New Mexico
    Tim Dee
    As far as a bigger plenum alone thats 30 year old band aide LOL
    I got most my gains from weak areas in the engine assembly by taking it apart and just looking at it
    Bigger TB and ported, matched ports on head vs intake, changed the vacuum balancing from emission to performance design. Free flowing exhaust with cats. Adjustable fuel system. Less is more. 4 port injectors were too much. Lots dyno time with a plan, document document document. Adjust repeat rinse repeat.
    The power sweet spot also yielded least emissions.
    Couple guys out here seen mine on the dyno and several on the emission dyno. (sworn to secrecy) I'm in that prisus range for emissions LOL
    I'm very happy with the powerband and can walk most 355s.
    Next level up would be ITB's with a standalone ECU, coil packs and new heads. All I need is the heads and a couple months, whenever LOL
  5. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    #30 Ferrarium, Sep 12, 2023
    Makes sense, thinking larger plenum with larger or ported TB which is probably all that is needed since larger than the maf's is not doing much anyhow. More air and more efficient into the engine is about all that is needed. That and the chips I still need from you :).
    Covid got in the way so never made it out there, kid got out of Marines already so is no longer in Pendelton.
  6. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    Tim Dee
    PM me your address I'll send them over. I have like 20 new blanks left. I have my programmers out as I was giving 2 of the older ones away to the school here so anyway they are out might as well program some up. I always buy the latest greatest, like crack LOL
  7. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    With new workshop coming and engine rebuild done I need a new project. Even if I never install an intake just designing and making it would be fun, my brain must have a problem at all times and problems I know I can solve are no fun. Not sure I can solve this which makes it irresistible. :)
    Were talking small hobby grade workshop here, bench top equipment but I have skills. :p
  8. ChoonHound
    ChoonHound Formula 3
    2,273
    Saint Michaels, MD
    Lucas
    Are there meaningful (50hp+) *documented* gains to be had on the factory tune?
  9. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Doubt you can get more than 10 hp from stock tune. I have seen dynos showing 50-100 hp over stock same dyno at wheels though. Think they had chips tuned, exhaust, TB porting, adjustable FPR etc but it was the Motonic 2.7 ecu none the less not aftermarket ECU's. I'd be happy with 350 at the crank. So were talking +30 over Spider that's not trivial to do despite Capristo and other exhaust mfg's boasting to the contrary. Bolt it on and get 25. Ya right. More like 10 downhill with the wind and no cats.
    AndyW's Spider was one such car. It was this one.
  10. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    Tim Dee
    Yes and then some. Few different approaches with natural aspiration.
    Currently I'm running a street tune that does not need more then 6500-7000 rpm shifts to carry globs of momentum without upsetting the car.
    If you never try it will never happen :)
  11. ChoonHound
    2,273
    Saint Michaels, MD
    Lucas
    Who did the tuning? That’s the key. And are they still alive?
  12. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Yep Tim is alive he's posting with you right now. He is the guy. :)
    AndyW had his done in Maryland forget the shop name but its a big well known one.
  13. ChoonHound
    2,273
    Saint Michaels, MD
    Lucas
    Oh, cool. So Tim you burned a new eprom? Or can the Motronic be flashed? I have no idea. What software did you use? Im very curious!
  14. User-C3
    User-C3 Karting
    Aug 29, 2018
    240
    Detroit
    Trevor
    I would be interested in some chips Tim. I have removed all the emissions equipment and also rerouted the vacuming, and test pipes with tubi. Would be fun to plug in some chips and see the difference from optimized tune until I can get to the deep dive of 355 ITB's. How much$ ?
  15. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,631
    The Brickyard
    The Bad Guy
    #40 ernie, Sep 18, 2023
    I went down the big plenum route, as in open plenum breathing through both throttle bodies = it LOST power.
    Why?
    Because the stock Motronic cannot adjust the fuel needed at WOT. When I dyno tested it, it was wicked lean, something in the range of 16:1+ afr.
    Tim even ran my plenum on his car for a while and had a hard time getting the dual Motronics to run it. They kept fight each other iirc.
    The F119 can breath big time. The problem is getting the the fuel and ignition timing it needs. The engine tuning is key.
    Here is what I suggest,
    Get a stand alone ECU + wiring loom.
    Get that FIRST, get the engine tuned and running flawlessly in stock trim, and THEN you can begin the modifications.
    If you want to get 21st century upgraded performance you NEEDED 21st century engine management. The Motronic was designed in the 1980s! Upgrade the engine management FIRST!
  16. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Open plenum meaning no top half and the intake runners exposed? The tb"s bolt to the top half of plenum so having trouble visualizing what an open plenum is.
  17. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Pretty sure the 355 itb conversion plugzit did had the same issue, not enough fuel up top. Definitely have to deal with that aspect.
  18. Johnnieblack115
    Johnnieblack115 Karting
    Nov 18, 2022
    220
    Massachusetts
    Jonathan Walker
  19. Finpat
    Finpat Formula Junior
    Sep 17, 2021
    251
    Finland
    Kari Lehtinen
    Converting ITBs from a F355 to a 348?
  20. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Putting 355 ITB on the 348 is discussed. It has been done.
    This is a 348 intake thread not a 355 intake thread. Modifying 348 inake is the topic, the thread has nothing to do with a 355.
  21. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,771
    Take a look at a McLaren M8D intakes.
  22. Johnnieblack115
    Nov 18, 2022
    220
    Massachusetts
    Jonathan Walker
    Sorry, took a bit to become cogent this morning. As you were!
  23. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    No worries!
  24. fatbillybob
    Aug 10, 2002
    29,377
    socal
    That's the only answer...or short burst about +100HP with nitrous oxide and fuel for under $1000
  25. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    #50 Ferrarium, Sep 18, 2023
    btw, I am not thinking 400hp with new EM and new injectors, thinking more along lines of 330 range with minor mechanical changes, actually working on new TB's right now actually. Pretty sure injectors will support up to 350 hp at the top end at 90%. Won't happen without some Motronic changes however, anyhow... it's fun designing stuff will prototype in CF alloy, trick is not to go to far or you open new rabbit holes. Previous 355 ITB project was shooting for the moon. Won't be doing itb's. :)
    If I do anything at all, right now its just design and prototyping part time but the thread provides information and insights along the way. If I do it I will dyno before and after.
