INTAKE VALVES TOO? | FerrariChat
INTAKE VALVES TOO?
Discussion in '308/328' started by absostone, May 22, 2016.
  1. absostone
    absostone F1 World Champ
    10,070
    When replacing sodium exhaust valves is it necessary to change out the intake valves? Yeah I know the whole while your in there routine. Any known problems? Disadvantages ? Thx
  2. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    Not big bucks to change them out too, you can get these made by Manley.
  3. absostone
    10,070
    Yes but the not big bux are adding up to b big bux!
  4. absostone
    10,070
    Is there a part number for Manley? Or how does one get pricing.
  5. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    I just contacted the uk agent for mine, send a sample and they will make to the sample.
  6. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    Perhaps more important would be looking at the valve guides, specifically valve to guide clearances.
  7. absostone
    10,070
    Yes understood about the clearances of guides. Was curious if there is any known problems with the intakes if all is good.
  8. wda24729
    wda24729 Formula 3
    Sep 22, 2014
    1,000
    Devon, UK
    Graham
    I just had my heads refurbished. On direction from the shop they said not to bother with the inlet valves as they were in perfect order, in fact so were the exhausts but still changed them. Changed all the guides though.
    And yes, although not big ££'s, it does all start to add up when your in that deep!
  9. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    No known issues. How much wear versus the labor to go in again is always a consideration.
  10. Albert-LP
    Albert-LP F1 Veteran
    8,177
    around Modena, Italy
    Alberto Mantovani
    while you have the heads removed, better change them all (and all the guides...)
    ciao
  11. Martin308GTB
    Martin308GTB F1 Rookie
    Jan 22, 2003
    4,259
    Black Forest Germany
    Martin N.
    #11 Martin308GTB, May 23, 2016
    Regarding this 'throw it away, while you are in there'-philosophy:
    The intake valves are not sodium filled, so they neither are hiding any bad surprises nor are they that time-bomb like the sodium filled exhaust valves.
    This means, they can be checked for dimensions, for pitting on the seats, etc.
    If they are within specs after thorough cleaning, measuring and examination I would not hesitate for one second putting them back in. Freshly cut in with maybe new guides.
    Best Regards
    Martin
  12. Mike Florio
    Mike Florio Formula Junior
    Jun 19, 2003
    599
    NW Rural Nevada
    Mike Florio
    +1
    My intake valves were completely in spec - just a kiss of the valve grinder and a kiss of the seats and they looked and sealed fine.
    I got my replacement exhaust valves from Manley Performance Products, Inc. They are actually a special stainless steel alloy they call Gen II 2600. They cost $80 each, about twice what plain stainless ones cost from Superperformance UK. My machinist uses these valves exclusively in the blown Nitro and Alcohol engines he builds, and swears by them. I could have insisted we use the Superperformance ones, but at this point arguing over $150 and pissing off the machinist, whom I trust, doesn't make much sense.
    Presumably new intake valves would cost about the same.
  13. Albert-LP
    8,177
    Alberto Mantovani
    this is true, of course. But, as you have to take them out, as the OEM guides are poor and very likely need replacement, as the final cost of the opeation in very big (unless you can do it by yourself, not very common) I think that you can change the intake valves too without increasing too much the final cost. But Martin is right: they probably don't need replacement.
    ciao
  14. absostone
    10,070
    Ok cool. I'll wait till its apart and see what is needed. I read florios post about engine removal
    I copied his engine stand!!! I was aware the intakes are not sodium but wants to be sure if I did reuse them. Thx everyone
  15. absostone
    10,070
    Anyone have experience with si valves?
  16. Ak Jim
    Ak Jim F1 Veteran
    9,640
    North Pole AK
    Any need/reasonson to change the valve springs while your in there?
  17. waymar
    waymar Formula 3
    Sep 2, 2008
    1,354
    Northeast, PA - USA
    Wayne Martin
    When I went over my heads and not knowing what the PO did before selling. I replaced ext and intake valves, springs, seals. Just gives me peace of mind.
  18. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    Specs are in the WSM. Replace if needed.
  19. absostone
    10,070
    I had a feeling the valve springs were gonna come up ! Any one have experience with SI valves?
