interior carpet removal question | FerrariChat
Discussion in '308/328' started by DrScientist, Mar 5, 2025.
  1. DrScientist
    DrScientist Rookie
    Feb 3, 2012
    31
    is it possible to remove the carpet (and reinstall new carpet) on the firewall without removing the fabric pieces on the ledge under the window.
    reading through previous posts, getting those fabric pieces out seems so difficult and fiddley (removing windows? groping around the engine bay?) like the kind of task that would make me delay putting in this new carpet set. :(
    '82 gtsi
  2. ragtop1
    ragtop1 F1 Veteran
    5,241
    Ontario
    Larry Warren
    One small nut/bolt attaches to the window ledge carpeting. It is accessed from the engine side of the firewall, in the centre. No need to remove glass.
  3. Miklas
    Miklas Karting
    Dec 10, 2018
    84
    Luxembourg
    For my 79 GTS I had to remove the windows as it was not enough to just undo the central bolt.
    You could try to remove the carpet without touching the ledge and then see if you can tuck the new carpet back under the ledge before fixing it in place. If it fails you have to remove the ledge.
  4. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,566
    San Carlos, CA
    Mitchell Le
    82 gtsi? Glass removal is necessary to do a real good and neat job on that carpet.
  5. LLynn
    LLynn Rookie
    Feb 16, 2025
    20
    L. Lynn Gardner
    Good Morning Folks, Having recently acquired a 1988 328 I am wondering who sells the best carpet kit for the car. Thanks in advance for your thoughts.
    Cheers,
    L. Lynn
  6. ragtop1
    ragtop1 F1 Veteran
    5,241
    Ontario
    Larry Warren
  7. LLynn
    LLynn Rookie
    Feb 16, 2025
    20
    L. Lynn Gardner
  8. ragtop1
    ragtop1 F1 Veteran
    5,241
    Ontario
    Larry Warren
    Beautiful! Thanks for sharing. I'm envious of your garage & lift. :)
  9. LLynn
    LLynn Rookie
    Feb 16, 2025
    20
    L. Lynn Gardner
    Thank you, the lift has become a necessity for me as I've gotten to the point in life that I can't /won't work on a creeper anymore ;-) The garage is the reason we moved recently, that being said, I can't find anything now.... I know, definitely a first world problem.
    ChevyDave likes this.
