Interior leather cleaners... | FerrariChat
Discussion in 'Ferrari Discussion (not model specific)' started by breakaway_16, Jan 24, 2008.
  1. breakaway_16
    breakaway_16 Karting
    Aug 31, 2006
    141
    Canada
    Hey guys, having an issue with my choices of leather cleaners....I have tried Eagle one sprays, armour all wipes and those spunge things, and a no name brand (hoping for a miracle). The problem is like a week after you apply it, it starts to smell. Maybe its the sun hitting it but it is getting frustrating. Any advise from the pro's. Thanks guys.
  2. 05F430F1
    05F430F1 F1 Rookie
    2,800
    Fort Lauderdale, Florida
    Todd
  3. M.James
    M.James F1 Rookie
    Jun 6, 2003
    2,721
    Worcester, MA
    Michael.C.James
    Leatherique.....although Leatherique is more well-known for rejuvinating old/dried-out leather and offering products to re-dye the leather to factory colors. I have used their cleaner and it appears to work very well. I have also used Lexol to clean leather with success. Wherever leather 'creases', however, dirt will work-itself into the crease and not come out just by wiping the surface - you need to use a brush.
  4. sparta49
    sparta49 F1 Veteran
    Mar 3, 2001
    7,802
    LA
    Frank
    Yes it does. Works great and smells great.
  5. tundraphile
    tundraphile F1 Veteran
    May 16, 2007
    5,083
    Missouri
  6. Bullfighter
    Bullfighter Two Time F1 World Champ
    Jan 26, 2005
    22,373
    Indian Wells, California
    Jon
    Does it darken the leather? I just ordered the spray-on product. My leather's new, just want to clean up the usual dust that comes through use.
  7. bill brooks
    bill brooks F1 Veteran
    5,228
    waynesburg,pa
    bill brooks
    you mean you actually drive that car? can't imagine where you acquire dirt.
  8. Bullfighter
    Jan 26, 2005
    22,373
    Jon
    I source it through Ferrari UK - it's original dust from the factory circa 1987. Expensive though. :(
  9. jmuriz
    jmuriz Formula Junior
    Dec 9, 2003
    395
    Arlington, VA
    What is the method used for applying the cleaner. When I try to apply Lexol with a rag I feel it doesn't get the dirt out...is there a special brush or sponge I should be using?
    Thanks for the suggestions...maybe the detail guys have a trick they can share.
  10. luv2detail
    luv2detail Formula 3
    2,289
    North Carolina & SoCal
    Jason
    + a billion.:)
    Leatherique is hands down the best.
    I just picked this stuff up too. http://www.detailersdomain.com/index.asp?PageAction=VIEWPROD&ProdID=207 Some people are saying that it works great. We'll see.
    Just to clarify, simply applying the cleaner doesn't make the dirt come out. You have to get the dirt out (not by force, just by using the proper tools). Try using a microfiber towel - it has a lot of grab to it. Keep flipping the towel or just grab a new one from time to time. As it becomes loaded down with cleaner and dirt, the surface of the towel becomes smooth and less effective and then you're just smearing cleaner on the seats. Kind of like brushing your teeth with your finger.:D Also, pick up a brush like this http://www.autogeek.net/vilescbr.html . It works great to loosen up the dirt.
  11. chris360hawks
    chris360hawks Formula Junior
    May 29, 2007
    477
    San Antonio, Texas
    Chris Hard
    Like the others said....Leatherique works wonders!
  12. Greg Nichols
    Greg Nichols Formula Junior
    Dec 7, 2007
    264
    Utah
    Greg
    Leatherique is wonderful stuff for restoration and deep re-hydration. It is not a quick process by any measure, and does not work well if its cold (like much of the USA right now). You NEED to follow the directions to the "T" for best results.
    If you want a monthly cleaner........Lexol is hard to beat for an OTC. Massage it in with your hands really well, helps.
    Leather is a porous material and loves to soak up everything. Use a cleaner, some light brushing and then wipe with your MF cloth turning it often to pick up the debris. If your seats are warm everything works better.........roll up the windows and let everything heat up, apply the rehydrate of your choice and let it dwell for a good part of the day, then wipe of excess. Leather rots from the inside out, so while the outside may look good you may have not given the leather a good hydration.
    Hope this helps.
    Cheers,
    GREG
  13. CavalloRosso
    CavalloRosso Formula 3
    Jul 12, 2007
    1,423
    Atlanta, GA/Vail, CO
    SVO
    I've used the Zaino bros. leather care/cleaner product and have been very happy with it. I think it works well and smells better than Lexol IMO.
  14. Arvin Grajau
    Arvin Grajau Seven Time F1 World Champ
    77,310
    Wurundjeri man.
    Arvin Grajau
    just be careful,some will strip colour if it has been applied over the original colour.
  15. bill brooks
    5,228
    waynesburg,pa
    bill brooks
    there's someting to be said for factory dirt.
    i built a new house last year and still have the original dirt on the floor where gabriella resides.
    of coarse hers was imported as you alluded to.
  16. f355spider
    f355spider F1 World Champ
    17,940
    A damp microfiber cloth can do an adequate job for most everyday cleaning on leather. Try not to use a brush. I have used Griot's interior cleaner when needed. Griot's Leather Care is not a super good cleaner, more of a all in one cleaner/moisturizer in one. I like it because it is very mild, not harsh, and leaves a pleasant leather smell.
    Leatherique products work well too, and the cleaner is okay. The Rejuvenator Oil is a mess to work with, I use it mostly for treating the dash on my 355. I soak it three or four times a year. 355 dashes are known for drying out, and the leather splitting and cracking. 11 years and mine looks great.
  17. PCH
    PCH F1 Rookie
    Apr 7, 2004
    3,007
    No experience with the spray-on however, the standard, (squeeze bottle) Leather Care showed no change in color tone. Just remember when applying, less is more.
  18. mgtr1990
    mgtr1990 Formula 3
    Mar 30, 2005
    1,580
    Naples Florida
    Martin Graham
    +1 had great sucess with all their products
  19. Jackmb1
    Jackmb1 F1 Rookie
    Dec 27, 2005
    3,329
    +2, I've had great results with it.
  20. MobileJay
    MobileJay Formula 3
    1,441
    Houston
    Jason Cavallo
    #22 MobileJay, Jan 25, 2008
    I have used Zaino Z-9 and Z-10. 9 is the cleaner and 10 is the conditioner. Smells amazing and works very very well. Here is a pic of a BMW that I did. Convertible and ALWAYS has the top down, so after years and years of driving like that it became nasty. Zaino, lots of it to clean and then condition.
  21. LRPMAN
    LRPMAN Formula Junior
    Oct 31, 2003
    383
    Aiken S.C. & FL.
    George Pavlisko
    Horses ? speaking
    The correct way to use our products is:
    1. Put the Rejuvinator Oil in a spray bottle
    2. Spray on leather
    3. Drink wine and relax
    4. After at LEAST 6 hours Put the Prestine Clean in a Spray Bottle ( I am CHEAP I just dump the first bottle back into the container and reuse it)
    5. Sray the Prestine CLean ON TOP of the Rejuvinator Oil and wipe with an old "T" shirt.
    6. Enjoy car
    The Rejuvinator Oil gets UNDER the dirt and floats it to the surface, the Prestine Clean removes that dirt.
    Got a show Saturday so I just MIST not a lot just a MIST of Prestine Clean and wipe with "T" shirt. Save the Micro Fibers for the paint, not needed. VERY DIRTY LEATHER, not in a Ferrari ever, use a tooth brush, not your wifes.
  22. luv2detail
    2,289
    Jason
    George, your stuff is the very best!:)
  23. LRPMAN
    Oct 31, 2003
    383
    Aiken S.C. & FL.
    George Pavlisko
    Thank you, just feel that every once in awile I need to set the records so that we can seperate fact from fiction.
