Interior Noise | FerrariChat
Interior Noise
Discussion in 'FF/Lusso' started by Zaius, Apr 9, 2015.
  1. Zaius
    Zaius Formula Junior
    May 8, 2014
    863
    #1 Zaius, Apr 9, 2015
    At speeds above 100mph on the highway when the surface isn't too even I can hear an annoying noise on the inside coming from the passenger side. It sounds like a license plate type metal shuffling around....
    Anyone experience something similar? Could it be something underneath the car stuck in the tray?
    Car has 1300 miles on it. F12
  2. Zaius
    May 8, 2014
    863
    I seem to have narrowed it down to the passenger seat. Its a race seat with the electric adjustment...
  3. SVCalifornia
    SVCalifornia F1 Rookie
    2,571
    Silicon Valley
    Keith
    Not the seat belt buckle hitting the racing seat shell??
    SV
  4. PhilNotHill
    PhilNotHill Two Time F1 World Champ
    Jul 3, 2006
    27,855
    Aspen CO 81611
    FelipeNotMassa
    Check and see if it does it above 200 mph. ;)
  5. Zaius
    May 8, 2014
    863
    It ended up being lose luggage straps.
  6. PhilNotHill
    Jul 3, 2006
    27,855
    Aspen CO 81611
    FelipeNotMassa
    Great news.
  7. SVCalifornia
    2,571
    Silicon Valley
    Keith
    Happiness is tight... Luggage straps!
    8^)
    SV
  8. RickLederman
    RickLederman F1 Rookie
    2,837
    Swanton Ohio
    Rick Lederman
    Happiness is going fast enough to know your luggage straps are loose !
  9. Zaius
    May 8, 2014
    863
    The noise wasn't the straps it is the plastic covers under the body. Will have dealer look at it.
  10. Entropy
    Entropy Formula 3
    Jul 10, 2008
    2,149
    After an annual on our 458, we had a high-frequency clattering under the passenger seat above 70mph.
    First diagnosis was that one of the front winglets was bumping against the front end; turned out that one of the bolts holding the under tray was a bit loose. At those speeds, was just enough to get air in there and cause it to flap. I had thought one of the (numerous) drain lines were hanging down in the airflow. When I got under there, the under tray seemed secure, but it was just loose enough (and perhaps the aero effect stronger than I thought) to cause the issue.
    A few turns of a wrench and problem solved.
  11. patekswiss
    patekswiss Formula 3
    Mar 31, 2014
    1,174
    New York City
    Lorenzo
    It's a bedrock principle of physics. At sufficiently high velocity, *nothing* is tight.
  12. Tupps11
    Tupps11 Formula Junior
    Jan 7, 2009
    560
    My noise came from that removable interior rear boot lid cover.
    Once i opened the boot and removed that piece, it became a much nicer noise free cabin...except for that V12 of course!
