Intermittent 308 Speedometer | FerrariChat
Discussion in 'Technical Q&A' started by 328KNB, May 14, 2005.
  1. 328KNB
    328KNB Karting
    Jun 14, 2004
    59
    Hi All
    The speedo on my '76 308 GTB started playing up - one minute its fine and the next it stops working. Seems as if its losing an input signal somewhere. Is this a common problem and if so is it fixable or what does on have to replace to sort the problem?
    Ken
  2. mattboyd
    mattboyd Karting
    Dec 14, 2003
    140
    Fredericksburg, VA
    Matt Boyd
    When the speedo goes out, does the odometer also quit advancing?
    -matt
  3. Dr Tommy Cosgrove
    36,583
    Birmingham, AL
    Tommy
    If the 76 models are the same as the injected cars you either have a bad sending unit or connections to it. It is VERY VERY common and not a very expensive part that you can replace in your driveway.
    This is common enough that I rarely believe the milage on 308's (also because it so easy to unplug the thing)
    It screws in down by your right rear wheel
  4. ham308
    ham308 Formula Junior
    Nov 3, 2003
    358
    NE Switzerland
    Richard Ham
    Two years ago mine had the same symptoms and I found it was working loose. It screws in and the body of the sender seems to make the earth connection. Screwed it back in and luckily it has been fine since.
  5. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,661
    Toronto / SoCal
    Rob C.
    I'll bet anything that it is the sending unit. They are notorious on these cars for going bad. Located on the transaxle it merely unscrews and is easily replaced.
  6. 328KNB
    328KNB Karting
    Jun 14, 2004
    59
    Thanks for all the feedback. The odo has also packed up too so my guess is that there is no signal. Will check out the sensor and the connections.
    Cheers
    Ken
  7. pete04222
    pete04222 Formula Junior
    Nov 1, 2003
    613
    Maine, USA
    Peter Cyr
    I had to replace the one on my car also. It is called the speedometer impulse generator and is easiest to access if you take the right rear wheel off. I think I paid around $150 for a new one.
  8. f355spider
    f355spider F1 World Champ
    18,054
    The odo and speedo run off the same signal....so if the speedo is acting up, the odo will too. You can try removing the sender (unscrew it) and cleaning it with a can of aerosol electrical contact cleaner, using the nozzle to spray into all the openings and electrical connector. Reconnect and cross fingers. That seems to have worked for one or two people. Most just end up buying a new one (I did).
  9. Ricambi America
    Sponsor Owner
  10. LSU348
    LSU348 Formula 3
    Dec 19, 2003
    1,047
    Sugar Land
    I just replaced mine. I think yours is identical to mine. That said, it is on your transaxle/tramsmission, driver's side and is relatively easy to get to once you pull the right rear wheel off (I suspect you could get to it without removing the wheel if you have a stand. You can plainly see the electrical connector if you look under the right rear of your 308. Follow the lead to the large brass "bolt" head and unscrew. Taking the wheel off/replacing took the most time. I think it took 20 minutes to replace mine including head scratching time needed to figure out how to heck to get my wrench in there.
    Mine bounced like crazy then went dead.
  11. Dr Tommy Cosgrove
    36,583
    Birmingham, AL
    Tommy
    See how many so far have had a problem? NEVER believe what you see on the odometer on these cars. I can tell you at least another dozen or so stories.
    Be careful when buying one
  12. barbo1
    barbo1 Rookie
    Aug 21, 2004
    44
    Huntington beach ca.
    gerald barbisan
    Mike, help me locate. I had the wheel off yesterday and was looking for the sender, I could not find what your talking about. Yours is '85 right?
    Right now my speedo is about 15 MPH fast and the odometer is doubling the milage on the trip meter. I was able to determine that by driving my Suv around the block. The 308 registered doble the actual. I really need to get this sorted out.
    Thanks for the help
  13. Ricambi America
    Sponsor Owner
    #13 Ricambi America, Jun 13, 2005
  14. barbo1
    barbo1 Rookie
    Aug 21, 2004
    44
    gerald barbisan
    Thanks Daniel, ill be calling if I need the part, I appreciate your help!
  15. bernardo66
    bernardo66 The Crazy Cat Man
    Dec 14, 2003
    26,581
    Montreal Canada
    Bernie
    I too had the same problem last year. Speedo sending unit was the problem. As mentioned, very easy fix...as long as the pin that connects from the sending unit is not seized in the little pinion gear that sticks out of the transaxle.
    Try and guess who that happened to.
  16. barbo1
    barbo1 Rookie
    Aug 21, 2004
    44
    gerald barbisan
    Thats too bad, how were you able to fix it? Im hoping that mine goes the easy route.
    Thanks for the input!
  17. bernardo66
    Dec 14, 2003
    26,581
    Montreal Canada
    Bernie
    I removed the little pinion gear that sticks out of the axle housing and went down to my local garage. There, the mechanic heated the gear and quickly cooled it off. Afterwhich, the pin slid right out.
  18. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,209
    Austin, TX USA
    Greg
    Somebody above said this sender is on driver's side, then somebody else said remove the right rear wheel. That person must be in England!
    So, the sender appears to be on the clutch side, right?
    My speedo is suffering from the same problem every so often, so I figure I'll get in there and try to clean mine..
    Thanks,
    Greg
    77 308 GTB USA
  19. BigTex
    79,406
    Houston, Texas
    Bubba
    An intermittant speedo is usually the dash unit failing, if everything is working ..then it quits (odo also)
    The sender can fail...
    The dash unit can fail.
    or you can have a pinched wire at the metal frame loops, in between.
    I've never heard of "cleaning" anything making a difference, the pulse generator at the tranny either works...or not.
    The signal reaches the dash via wiring.....or not.
    The dash unit works.........or not.
    HTH
  20. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,209
    Austin, TX USA
    Greg
    Thanks BT. Post #8 said cleaning may work, so I guess I'm guilty of wishful thinking. Plus, mine is very rarely intermittent, seemingly only so at high speeds for a length of time, i.e.; on the highway. Hard to pinpoint why...
    Plus, it's only non-functional for about a mile or so, then it kicks back in. Weird, huh?
    Thanks,
    Greg
  21. BigTex
    79,406
    Houston, Texas
    Bubba
    No...that's the failure mode of the dash unit..
    Somebody here is deep into one, repairing it with a new IC chip........I'm no good with solder at that scale so it's Palo Alto Speedo for me......
  22. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,209
    Austin, TX USA
    Greg
    Oh great......
  23. f355spider
    18,054
    Disagree, the sender can go intermittent (did on my 308 and also on a friend's, though on my 355 it just completely crapped out). They are inexpensive enough, and easy enough to replace that I would go with that assumption first. IF it ends up it is the speedo, you now have a spare sender (they do fail every few years).
  24. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,209
    Austin, TX USA
    Greg
    Thanks Hugh G.!
    Here's hoping a little TLC will fix my sender.....
  25. Darolls
    Darolls F1 Veteran
    7,782
    Sparky
    +1
