Intermittent 308 Speedometer | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by 328KNB, May 14, 2005.
  1. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,209
    Austin, TX USA
    Greg
    Thanks..
    Greg
  2. tvine
    tvine Formula Junior
    Jul 19, 2006
    270
    Cadillac, Michigan
    Tom Vine
    Mine did too; '79 GTB. The sender is a pulse generator and I figure the brushes wear out. At first they make contact some times then they quit all together.
  3. stephenofkanza
    stephenofkanza Formula Junior
    Mar 5, 2005
    542
    Kansas
    Stephen LeRoy Sherma
    Same thing happened to me. I was lucky cleaning was all it needed.
    Be sure that you clean the leeds (can't spell). I removed the spade male and female from the nylon cases and cleanded with contact cleaner b4 reasembleing. I then wrapped the connectors with black plastic electrical
    tape to protect the connection from road cr@p. Also be sure to run the leed thru the guide (mine was wire tied to the guide not thru the guide).
    Lucky as part in the parts manual for the 81 was not the correct part.
    and correct part was more twice the price of the part listed in the book.
    stephen
  4. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    #29 Brian Harper, Dec 13, 2006
    While cleaning up the engine I noticed that the wires on my sender were bent over at a harsh angle right where they exited the potting on top of the sender. One wire was almost half broken off. This is probably from as much from mechanics crushing it tying to reach into tight spaces as anything else, but just left that way I assumed it would eventually break. Because it is potted there aren't a lot of nice options for making this right. As a preventitive measure I did a little repotting with epoxy. I also added a little heat shrink tubing to help distribute the stress along more of the wire. And then I used a little too much epoxy. But until then it was going well! About half as much would have been fine. I should have used a clear tape as my mold and not masking tape that I couldn't see through. At least it can't really be seen on the car by anyone but me. I also upgraded from brittle yellow to tape to brand new orange tape because that is what I had.
  5. bergxu
    bergxu Formula 3
    Aug 16, 2005
    1,307
    OnTheSerpentMound
    Aaron
    Driver's side? Right rear wheel? You in England man?
  6. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,209
    Austin, TX USA
    Greg
    I was wondering the same thing!!
    Greg
