Intermittent A/C Operation | FerrariChat
Discussion in '308/328' started by BLR308, Jul 29, 2013.
  1. BLR308
    BLR308 Rookie
    Jun 21, 2013
    49
    Papillion, NE
    Bob Roegge
    My A/C works quite well when it comes on. The problem is the clutch does not engage when system is turned on half the time. Jump the clutch with 12 volts and it kicks every time. Can someone tell me what switch triggers the clutch? I have pulled out both the temp control and fan switches and fiddled with them to no avail. Any advice on what to check would be appreciated.
  2. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,875
    Mike 996
    Did you check the low pressure switch/associated connections on the dryer? If that switch is malfunctioning (or if the system is too low on refrigerant), the compressor won't engage.
  3. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,858
    Atlanta
    John!
    +1
    also, check the pressure in the system, it could be that your system is just barely having enough pressure to click the low pressure switch thus sometimes it does sometimes it doesn't.
  4. BLR308
    BLR308 Rookie
    Jun 21, 2013
    49
    Papillion, NE
    Bob Roegge
    I was thinking since air was cold when on that system was full. But, low pressure could be the problem. Two questions....
    Wouldn't bypassing the low pressure switch be a simple test to see if the compressor kicks in?
    Where is low pressure switch located?
  5. Ferraripilot
    May 10, 2006
    17,858
    Atlanta
    John!
    yup. that switch is located at the bottom of the union joining the dryer and expansion coil at the front of the car, passenger side.
  6. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,324
    but if it does kick in by by-passing the switch, don't run it for too long like that - its there to protect the compressor.
    It could of course be that the switch is faulty - but you'd only find that out by putting some gauges on the system
  7. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,367
    NY
    Just put a set of AC gages on it and you will tell if the system is low. Simple to do . Go from there also check the temps at the AC duct. A reasonable target is 20* lower then outside temps.
  8. BLR308
    BLR308 Rookie
    Jun 21, 2013
    49
    Papillion, NE
    Bob Roegge
    Thanks.......
    Jumpered the low pressure switch and compressor kicked on. Looking in sight glass there were bubbles initially and then clear. Suspect it is the switch as there is also an oily film on switch ( not on fitting ). Based on cold air I do not think system is low. Either way I will replace the switch which requires purging systema nd recharging.
