Intermittent Brake failure on 458 | Page 10 | FerrariChat
Discussion in '458 Italia/488/F8' started by eberro, Jul 16, 2015.
  1. LVP488
    LVP488 F1 Veteran
    Jan 21, 2017
    6,188
    France
    I don't know where it's going here, it's becoming so confusing I need to revisit my understanding...
    Which is (in simplified terms) : there is an issue with the brake booster in the 458 and 488, which could make it inoperant if some brake fluid goes into the booster (which is in no way a normal situation). The recall was a workaround to prevent this to happen, with the fuel cap change to make the brake fluid less prone to go into the booster (for whatever physical reason) and a software change that is more sensitive to the loss of brake fluid (assuming the missing fluid could have gone into the booster and potentially cause the booster failure).
    As a side note, the failure does not cause a total loss of braking power, it unexpectedly requires the braking system to be operated as a system without booster (with far more pressure required on the brake pedal).
  2. SoftwareDrone
    SoftwareDrone F1 Veteran
    Sponsor Owner
    Jan 19, 2004
    7,883
    San Jose, California
    Could you quantify this statement? I am asking sincerely. I want to know if there are other brake problems besides the booster/acute brake failure issue.
  3. AhmetUz
    AhmetUz Karting
    Aug 11, 2022
    160
    Hello,
    As everyone knows, CCM (carbon ceramic brake system) is standard on 458s. It is true that when you first start driving the car, that is, when you want to slow down the vehicle by applying the brakes while the brakes are cold, it feels like the brakes are not really working (this is a common feature of ceramic brake systems), but after a few braking times, the brakes start to warm up and carbon ceramics have serious braking power. I was wondering why you got the impression that the car's brakes were ineffective?
    Have a nice day.
  4. Hopeful
    Hopeful Karting
    May 31, 2019
    159
    Vero Beach, FL
    Tony M.
    There are apparently 2 separate problems. One primarily (only?) affects 458s whereby the pedal intermittently loses boost (goes "hard") and the brakes are much less effective but braking power is subsequently recovered. The other primarily (only?) affects 488s which involves loss of brake fluid into the booster resulting in a total loss of brakes (pedal goes to the floor with no braking effect) and braking power is not recoverable without replacement of the booster/master cylinder.
    Anyone who denies that either of these problems exist is grossly misguided.
  5. Eric C
    Eric C F1 World Champ
    11,136
    St. Louis, MO
    Eric
    Here's a good video that everyone should watch that explains a lot.
    mdrums likes this.
  6. LVP488
    LVP488 F1 Veteran
    Jan 21, 2017
    6,188
    France
    I thought the 458 and 488 had the same braking system and therefore the same problem.
  7. Eric C
    11,136
    St. Louis, MO
    Eric
    No. The above video explains the differences. The 488 is a turbo car so it can't use the same vacuum source as the N/A 458. It has to use a vacuum pump.
    mdrums likes this.
  8. Tony91505
    Tony91505 Formula Junior
    Apr 13, 2005
    424
    So cal
    Tony
    The brakes on my car would would work normally more often than not, however, at times, with no pattern to be discerned, would need lots of pressure while the braking would suffer. when taken to the dealer, they stated everything is working as intended. That said, I found the brakes sub par in comparison to a Pcar ceramics of the same vintage. This is my personal experience and hope that helps.
  9. Tony91505
    Apr 13, 2005
    424
    So cal
    Tony
    #234 Tony91505, Aug 20, 2024
    I have had multiple cars with ceramic brakes and am well aware of the limitations in cold weather. this is basic knowledge as well as burnished brakes et cetera. I would not call what I felt an "impression", even if does not fit your narrative.
    best
  10. eberro
    eberro Karting
    Jun 23, 2015
    54
    It is.
