intermittent carb popping 330 GT | FerrariChat
Discussion in 'Technical Q&A' started by mibi, May 31, 2015.
  1. mibi
    mibi Karting
    Apr 20, 2010
    246
    Atlanta
    Michael
    Under load, even when warm, my car will OCCASIONALLY get some annoying carb popping at 3-4K RPM, typically 3rd gear, under load. Thats when I notice it most.
    Idle is fine. Cruising at 75mph is fine.
    I need some guidance- the "occasionally" thing has me puzzled and I dont know where to look.
    is this a Fuel mixture, exhaust valve, Fuel delivery, timing or what issue?
    michael
  2. brian.s
    brian.s F1 Rookie
    Nov 3, 2003
    3,809
    Midwest
    Brian
    My first guess, timing curve on one or both distributors. Popping is generally a lean symptom, but it could be a jetting issue with this wonderful stuff they call gasoline today. Welcome to the magic of Weber tuning.
  3. mibi
    mibi Karting
    Apr 20, 2010
    246
    Atlanta
    Michael
    Today and yesterday i drove about 100 miles.
    I now feel confident its carb related.
    Its 3rd gear mostly, light to moderate load. as soon as I step on it, it goes way. the problem is, it occurs in light to moderate traffic, when I can't get on it. so it stumbles.I think its too lean and I guess I need to pull out the weber books, and check out the acceleration circuits. if anyone has other ideas, let su know Thanks brian- I am sure the crappy gas is part of it too. Ill focus on the webers first.
    Michael
  4. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Look at ignition first. Don't fiddle with carbs until you know it's not an ignition problem.
  5. 330BRC
    330BRC Karting
    May 4, 2007
    136
    Seattle, Washington
    Brian Conlan
    I had popping on my 330. A "sunk" carb float was the culprit. One of the brass carb floats had collected fluid inside. I replaced the float, made sure all of the jets were clear, adjusted the idle mix and sync. Not that difficult.
    Wise advise to make sure everything else is good first, however, the carb floats can be checked without changing any carb settings.
  6. mibi
    mibi Karting
    Apr 20, 2010
    246
    Atlanta
    Michael
    OK good advice. My car was converted to electronic ignition in the 80s, so there are just a few things I can check but I will look that over first.
  7. mibi
    mibi Karting
    Apr 20, 2010
    246
    Atlanta
    Michael
    it was a few things-- not rich enough on a few carbs, 2 carbs out of sync with air flow, and the master brake booster service port had a leak so was loosing vacuum on the rear carbs.. all fixed and running great now!
