intermittent light issue | FerrariChat
Discussion in '308/328' started by Ferraripilot, Sep 28, 2006.
  1. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,862
    Atlanta
    John!
    I just got back from a drive and noticed that the red light with a 'G' on it turns on and off when I hit my brake pedal. AS in, on when I hit the brake pedal and off once I release the brake pedal. Is this an alternator issue or a brake light switch issue? anyone? thanks much
    john
  2. Ferraripilot
    May 10, 2006
    17,862
    Atlanta
    John!
    allright folks. I am stumped on this one. anyone have a similar experience with this?
  3. barcheta
    barcheta F1 Rookie
    Nov 15, 2003
    3,738
    Maryland
    Jim
    have you tried adding brake fluid? I had a problem like that... adding fluid stopped it. There was another thread on here recently where someone had a problem with the brake switch.
  4. Steve Magnusson
    26,865
    I'd put the highest probability on a fuseblock problem. There are three wires hooked to the tops of fuses #1, #2, and #3 that should all be well-connected together electrically (by the straps/rivets on the back of the fuseblock itself), and they should all be at the same voltage when the engine is running and when you step on the brake pedal. Sometimes these wires get switched around inadvertently, but the way it should be is:
    +12V power comes into the top of fuse #2 on the large A (light blue) wire;
    this gets bridged over to the top of fuse #1 and exits out the top on the G (yellow) wire to run the ignition system (and current flowing down thru fuse #1 runs the brake lights);
    the +12V power coming in on the A wire also gets bridged over to the top of fuse #3 and exits on a GN (yellow/black) wire and goes to one side of the alt. "G" warning light.
    If the straps/rivets are not well-connected electrically (i.e. they have a small resistance), this can cause the voltage to drop when a large current is flowing (i.e., when you activate the brake lights).
    Measure the voltage on the GN wire and the A wire (both relative to chassis ground) with the engine running both with the brake lights on and off -- if the voltage on the GN wire "droops" below the voltage on the A wire when the brake lights are "on", this is the problem.
    If your alt "G" warning light also flashes with the turn signal lights (or anything else that draws large current from fuse #1) this would be another indication that this is the source of the problem.
    Good hunting -- let us know what you find...
  5. tvine
    tvine Formula Junior
    Jul 19, 2006
    270
    Cadillac, Michigan
    Tom Vine
    I am not an expert, but I thought I would post because not many have responded to your question. Those who know more please correct anything I get wrong.
    Sounds like a short to ground. The red light is your alternator light (G for Generator I think). Sounds like that when you hit your brakes, a short circuit path is created making the indicator read less than normal amps. If you need a procedure for troubleshooting this send me a note. There are others on this site much more electircally oriented that I that may have other ideas.
    Another thought. What is your RPM when this happens. My alternator light begins to flicker when the RPMs drop below about 1000 indicated (about 700 actual).
    As friendly advice, determine the cause (or causes) of the problem before you start changing parts. The fuse block may be the cause of the problem but verify this before changing it. Even if it is not the cause you may choose to change this anyway. You need to be able to reproduce the problem at will before you know you have it.
  6. Ferraripilot
    May 10, 2006
    17,862
    Atlanta
    John!
    ok Steve, allow me to understand more clearly. If the voltage changes when I hit the brake light with the GN and A wire, then the issue may be a poor connection with the straps/rivets etc causing the alternator light to come on. If this is the issue, a temporary fix might be to tighten the straps and rivets and hope for the best. at least until I get a birdman fusebox. I will let you know what I diagnose.
    One more thing, I am having no issues with the alternator light when I use my turn signals.
    And Tvine, I am going to flex your idea as well. will let everyone know shortly.
  7. Steve Magnusson
    26,865
    Even if that isn't your problem (and the turn signals not causing the same situation is a sign it's not), making a good reliable connection between the tops of fuses #1, 2, and 3 is always a good idea IMO. I soldered some busbar across the base of the three male tabs pointing upward, and others have reported soldering the plates and rivets directly (although in both cases it's not easy to get enough heat to melt the solder without hurting the plastic).
    If it is just an alternator current capacity problem, I'd have guessed that turning on any high current gizmo (like the headlights) would cause the same result -- does it?
  8. Ferraripilot
    May 10, 2006
    17,862
    Atlanta
    John!
    No, the issue is only when I hit the brake pedal....
  9. Ferraripilot
    May 10, 2006
    17,862
    Atlanta
    John!
    all right folks. I fixed it. After exhausting all possible scenarios with a multimeter and a testlight, I decided to check the simple things. Why I did not do this first escapes me. I retraced my steps the night the issue occured. That night, I used my headlight which I rarely use, but I make sure ot get them up and down at least every couple of weeks to keep things moving. I think the light came on due to all the other electrical components lightly overloading the alternater, and hitting the brake pedal was the trigger. The problem stopped this morning after not driving it for a couple days. To prevent any further possible overloading, I replaced the battery. I am glad it was that simple, and I am glad to know that my wiring in that department has been very well kept.
