Intermittent Non Start issue | FerrariChat
Discussion in 'Technical Q&A' started by jimshadow, Jun 17, 2008.
  1. jimshadow
    jimshadow F1 Veteran Lifetime Rossa Owner
    Feb 19, 2006
    6,255
    Indiana/North Carolina
    JIM
    Ok, I've had a few intermittent non start issues with my GT4 recently. The last two have been very inconvenient. ;) One was at the gas station and the other on my way home from a car show this past weekend. The car runs fine, its just once in a blue moon when I turn the key, nothing happens. All guages, lights, horn, etc...work, just won't turn over....no clicking, nothing! A little while later...voila, she acts like nothing was ever wrong. I'm thinking its a problem with the solenoid, however, I'm looking for some direction as to the order of troubleshooting that I should take. The starter on the GT4 is a BEEEAAATTTCCCHHH to get to from what I can tell/read. I've also read several other things in the archives such as a button, diode, etc... Where should I start? At the starter or at the key end? (I've already confirmed good clean connections to the starter switch...
    TIA,
    JIM
  2. Jdubbya
    Jdubbya The $10 Trillion Man Silver Subscribed
    Dec 28, 2003
    43,477
    PNW
    Check the ground cable to the battery and the engine ground first.
  3. DGS
    DGS Seven Time F1 World Champ Rossa Subscribed
    May 27, 2003
    72,718
    MidTN
    DGS
    Next time it won't start, try it with the headlights on. If they don't dim, you're not sending current to the starter. If they dim, the current isn't turning the starter.
    Meanwhile, check the service records. I just had a nine year old alarm system removed that caused a similar issue with my 328.
    But years ago, I also had a starting issue that came from a battery connector. When the car was cold, the connector fit tight. But when the battery area got warm, the connector expanded more than the battery post, and the connection got loose. I cleaned the connector and reattached it, coating it with the electrolyte gel they sell for spark plug boots. No more problem.
  4. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    It's always a good idea to confirm the battery ground cable and engine ground are in good condition but the fact that he said gauges, horn etc. work would indicate that they are probably okay (granted the starter pulls a lot more juice that these items).
    The positive side cables/connections should also be checked. People tend to fixate on ground connections/cables. Good + side connections are absolutely no less important than good ground connections/cables.
    Solenoid causing trouble due to heat soak is certainly a decent possibility.
  5. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    Good point although I doubt on this car there is much chance of that because the battery does not sit in the typical high heat area of an engine compartment.
    Actually I'm kind of guessing at that :) I assume the battery on a GT4 sits low down and in the middle towards the front of the car like on a 328 but I could be wrong. Not sure if radiator heat hits it either. On a 328 the radiator heat is routed up and out of the hood (not towards the battery location).
  6. Martin308GTB
    Martin308GTB F1 Rookie
    Jan 22, 2003
    4,280
    Black Forest Germany
    Martin N.
    wrong :) Another thing what's definitely better on the GT4 regarding access. I admit, I have just 'stolen' the picture from a different thread. Credits and thanks to Beta Scorpion for his thorough and detailed GT4 report.
    http://www.ferrarichat.com/forum/showthread.php?t=105874&highlight=battery+gt4
    Best Regards
    Martin
  7. DGS
    May 27, 2003
    72,718
    MidTN
    DGS
    The battery on a 328 gets plenty warm in summer, sitting directly behind the radiator. It was the 328 that had the thermal connector issue. On the positive cable (as you noted). And the gauges and lights still worked fine -- the loose connection could feed that much juice. But when you'd hit the starter, everything went dark.
    That's why the first test it to check the starter with the lights on. Either you don't have the current to turn the motor, or you're not sending current there.
    Like as not it's the solenoid or an older alarm/recovery system or a bad connector in the wiring to the solenoid.
    (I think I might have broken even. I paid to install the remote kill, paid even more to have it removed, nine years later --- but it saved me 25% off my comp insurance for many years in MA. (No discount for it in VA, though.))
    But intermittent bugs are a pain to track down. All you can do is check all the boxes.
    (I had an Alfa with dirty solenoid that would stick once in a while. The current through the wiring wasn't enough to move it -- but if you bridged the plus voltage from the battery lead with a screwdriver, it would kick the solenoid loose, and then it would start from the key. (The solenoid both switched current to the starter and pushed the starting gear out to mesh with the fiywheel .))
  8. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    So, same location as my Lancia Montecarlo. Not much heat there with my Lancia and probably not on a GT4 either.
  9. jimshadow
    Feb 19, 2006
    6,255
    JIM
    Well, luckily for me I befriended a guy in the neighborhood who is a total car nut! He is big into Corvairs and has 3 or 4 plus various other projects in his garage. I was telling him about my non-start issue while over at his house and of course it would not start. I explained where the starter was and that I would need to get it up in the air to get at it, so we push start the car and off I go to the pool to swim for a while. I get a call and he says..."Found ya a lift to use tonight..." WOW! We drove over and got it up in the air and WE COULD PULL ALL THE WIRES OFF THE STARTER BY HAND!!!!!!!!!!!!!!!! The lower nut is thrashed, but luckily has just enough threads left to get the wires on good and snug. The top nut was on fairly tight, but not like it should've been. The spade connections were pretty loose as well, so we took everything off, cleaned/degreased it and put it back together nice and snug. She fired right up and did not have the problem again tonight, even when hot. :)
    While I was under there I checked my throttle and clutch cables, tightened all my hose clamps (none were loose:) ) and checked tightness on my pan nuts. All looked good.
    Thanks again for all the help. This list is an amazing resource!!!
    JIM
  10. Jdubbya
    Dec 28, 2003
    43,477
    PNW
    Glad to hear it was an easy fix. Relish this one because the next one might not be so easy!!
